Reading: Siemens PLC Comparator Logic
Inst Tools > Blog > PLC Tutorials > Siemens PLC Comparator Logic
Implement Siemens PLC Comparator logic like equal, not equal, greater or equal, less or equal, greater than in S7-1200 PLC using ladder diagram language.
Last updated: November 3, 2023 2:52 pm
This article shows the different types of Siemens PLC Comparator Logics and their ladder diagrams.
Siemens PLC Comparator LogicProblem DiagramProblem SolutionList of Inputs and OutputsLadder diagram for comparators used in S7-1200 PLCProgram DescriptionTest Cases
Problem Description
Implement equal, not equal, greater or equal, less or equal, greater than, check validity, and check invalidity comparators in Siemens S7-1200 PLC using ladder diagram language.
Problem Diagram
Comparator used in Siemens S7-1200 PLC.
Problem Solution
Comparators are used for comparing two values. Say, If we want to compare two physical quantities (temperature, pressure etc.).
We can use the equal instruction to determine, if a first comparison value is equal to a second comparison value or not.
We can use the not equal instruction to determine, if a first comparison value is not equal to a second comparison value or not.
We can use the greater or equal instruction to determine, if a first comparison value is greater than or equal to a second comparison value or not. Both values to be compared must be of the same data type.
We can use the less or equal instruction to determine, if a first comparison value is less than or equal to a second comparison value or not. Both values to be compared must be of the same data type.
We can use the greater than instruction to determine, if a first comparison value is greater than a second comparison value or not. Both values to be compared must be of the same data type.
We can use the less than instruction to determine, if a first comparison value is less than a second comparison value or not. Both values to be compared must be of the same data type.
Output List
  • Result 1 = Q0.0
  • Result 2 = Q0.1
  • Result 3 = Q0.2
  • Result 4 = Q0.3
  • Result 5 = Q0.4
  • Result 6 = Q0.5
Memory
  • MW0 :- Comparator 1
  • MW2 :- Comparator 2
  • MW4 :- Comparator 3
  • MW6 :- Comparator 4
  • MW8 :- Comparator 5
  • MW10 :- Comparator 6
Siemens PLC Comparators Logic
Program Description
In this program, we have used Siemens S7-1200 PLC and TIA Portal Software for programming.
Network 1:
If value in MW0 is equal to 2, result 1 (Q0.0) will be ON.
Network 2:
If value in MW2 is not equal to 2, result 1 (Q0.1) will be ON.
Network 3:
If value in MW4 is greater or equal than 2, result 3 will be ON.
Network 4:
If value in MW6 is less or equal than 2, result 4 will be ON
Network 5:
If value in MW8 is greater than 2, result 5 will be ON.
Network 6:
If value in MW10 is less than 2, result 6 will be ON
Test Cases
Siemens Comparators
Author: Bhavesh
  • Separate Different Size Objects using PLC
  • PLC Tank Heating Control using Heater
  • Implement 1 to 8 Demultiplexer using PLC
Peripheral Inputs and Outputs in Siemens PLC
Finding the Best PLC for Your Project – Tips and Tricks
What is Motor Jogging ?
  • Miss mysterious says:
    June 8, 2021 at 12:31 pm
    If we want to control this logic continuously without assistance,what should we do?
208kSubscribersSubscribe
PLC Project Examples for EcoStruxure Machine Expert
PLC Light Sequence Control using Bit Shift Registers
What is Siemens TDC? – Siemens Control System
Parking Garage Indicator: PLC Automation System
FB Block in Siemens PLC Programming
Function Module in Siemens PLC
What is Function Module in Siemens PLC?
Functional Block Diagram in PLC for Oil and Water Process
Relay Symbols
Relay circuits
0 to 10 mA Current Loop
What is Live Zero in 4-20 mA Current Loop ?
Types of PLC
FIFO and LIFO Sequences in PLC
What are FIFO and LIFO Sequences in PLC?
Principle of Operation of PLC
DeadWeight Tester
DeadWeight Tester Questions
What is Hydraulics
What is Hydraulics?
Omron PLC programs
Magnetic Float Level Sensor Principle
Magnetic Float Level Transmitter Working Principle
Baffle Nozzle Assembly Sensitive Mechanism
How do you select a Pressure sensor
How do You Select a Pressure sensor?
Level Gauge Interface Measurement
Level Gauge Interface & Temperature Problems
Turbine Supervisory Instrumentation
What is Turbine Supervisory Instrumentation (TSI)?
