Reading: PLC Programming for Sequential Batch Mixing System
Inst Tools > Blog > PLC Tutorials > PLC Programming for Sequential Batch Mixing System
This article discusses Sequential Batch Mixing systems with weighing functions using the Omron PLC programming for process control.
Last updated: September 26, 2024 5:52 am
7 Min Read
This article discusses Sequential Batch Mixing systems with weighing functions using the Omron PLC programming for process control applications.
Sequential Batch Mixing SystemProject IOPLC Programming
The PLC system has 2 buttons, the START_SYSTEM (0.00) button is used to Turn On the system, and the STOP_SYSTEM (0.01) button is used to Turn Off the system.
Before the PLC system is started, the “Set Value” in the memory words SV_LIQUID_PREMIX (D1) and SV_LIQUID_MIXER (D3) needs to be Set. This is used as the maximum liquid content value in the PREMIX and MIXER tanks.
When the START_SYSTEM (0.00) button is pressed, the Output VALVE_INPUT_PREMIX (100.00) will OPEN to carry out the liquid filling process in the PREMIX tank. The Output VALVE_INPUT_PREMIX (100.00) will CLOSE when the value in the memory word PV_LIQUID_PREMIX (D0) is equal to SV_LIQUID_PREMIX (D1).
When the value in the memory word PV_LIQUID_PREMIX (D0) is equal to SV_LIQUID_PREMIX (D1), then the Output MIXING_PREMIX (100.01) will be ON for 10 seconds to carry out Mixing process in the PREMIX tank.
After the Mixing Process in the PREMIX tank is completed, the Output VALVE_INPUT_MIXER (100.02) and VALVE_OUTPUT_PREMIX (100.03) will OPEN to drain the liquid from the PREMIX tank to the MIXER tank.
The Output VALVE_INPUT_MIXER (100.02) will CLOSE when the value in the memory word PV_LIQUID_MIXER (D2) is equal to SV_LIQUID_MIXER (D3).
The Output VALVE_OUTPUT_PREMIX (100.03) will CLOSE when the value in the memory word PV_LIQUID_PREMIX (D0) is zero “0”, this indicates the PREMIX tank is empty.
When the value in the memory word PV_LIQUID_MIXER (D2) is equal to SV_LIQUID_MIXER (D3), then the Output MIXING_MIXER(100.04) will be ON for 20 seconds to carry out the Mixing process in the MIXER tank.
After the Mixing process in the MIXER tank is completed, the Output VALVE_OUTPUT_MIXER (100.05) will OPEN to empty the liquid in the MIXER tank. The Output VALVE_OUTPUT_MIXER (100.05) will CLOSE when the value in the memory word PV_LIQUID_MIXER (D2) is zero “0”, this indicates the MIXER tank is empty.
When the MIXER tank is empty, the system will be OFF and will Run again when the START_SYSTEM (0.00) button is Pressed.
Mixing Batch PLC Program Sequenced With The Weighing Function
Project IO
CommentInput (I)Output (Q)Memory BitsMemory WordTimers
START_SYSTEM0.00
STOP_SYSTEM0.01
VALVE_INPUT_PREMIX 100.00
MIXING_PREMIX 100.01
VALVE_OUTPUT_PREMIX 100.03
VALVE_INPUT_MIXER 100.02
MIXING_MIXER 100.04
VALVE_OUTPUT_MIXER 100.05
SYSTEM_ON  W0.00
VALVE_INPUT_MIXER_CUTOFF  W0.01
VALVE_OUTPUT_PREMIX_CUTOFF  W0.02
VALVE_OUTPUT_MIXER_CUTOFF  W0.03
TIMER_PREMIX    T0000
TIMER_MIXER    T0001
PV_LIQUID_PREMIX   D0
SV_LIQUID_PREMIX   D1
PV_LIQUID_MIXER   D2
SV_LIQUID_MIXER   D3
PLC Programming
RUNG 0 (START_SYSTEM)
In this Rung, when the START_SYSTEM (0.00) button is pressed, the memory bit SYSTEM_ON (W0.00) changes to an ON state. Because it uses “latching” the memory bit SYSTEM_ON (W0.00) remains ON even though START_SYSTEM (0.00) button has been Released.
The memory bit SYSTEM_ON (W0.00) will be OFF if the STOP_SYSTEM (0.01) button is Pressed or when NC contact of the memory bit VALVE_OUTPUT_MIXER_CUTOFF (W0.03) is HIGH.
RUNG 1 (VALVE INPUT PREMIX)
In this Rung, the Output VALVE_INPUT_PREMIX (100.00) will be OPEN when NO contact of the memory bit SYSTEM_ON (W0.00) is HIGH and the value in memory word PV_LIQUID_PREMIX (D0) is less than SV_LIQUID_PREMIX( D1).
The Output VALVE_INPUT_PREMIX (100.00) will CLOSE when value in the memory word PV_LIQUID_PREMIX (D0) is greater than SV_LIQUID_PREMIX (D1) or the NC contacts of VALVE_OUTPUT_PREMIX (100.02) and MIXING_MIXER (100.04) are HIGH.
RUNG 2 (MIXING PREMIX)
When NO contact of the memory bit SYSTEM_ON (W0.00) is HIGH and the value in the memory word PV_LIQUID_PREMIX (D0) is equal to SV_LIQUID_PREMIX (D1), then the Output MIXING_PREMIX (100.01) will be ON and the Timer TIMER_PREMIX (T0000) starts counting up to 10 seconds. The Output MIXING_PREMIX (100.01) will be OFF when the TIMER_PREMIX (T0000) Timer reaches the “Set value”.
PLC sequential control logic
RUNG 3 (MIXER INPUT VALVE)
When NO contacts of the memory bit SYSTEM_ON (W0.00) and TIMER_PREMIX (T0000) are HIGH, the Output VALVE_INPUT_MIXER (100.02) will be OPEN.
When the value in the memory word PV_LIQUID_MIXER (D2) is equal to SV_LIQUID_MIXER (D3) and the memory bit VALVE_INPUT_MIXER_CUTOFF (W0.01) is ON, then the Output VALVE_INPUT_MIXER (100.02) becomes CLOSE because of the “Interlock” of the memory bit VALVE_INPUT_MIXER_CUTOFF (W0.01).
RUNG 4 (VALVE OUTPUT PREMIX)
When NO contacts of the memory bit SYSTEM_ON (W0.00) and VALVE_INPUT_MIXER (100.02) are HIGH, the Output VALVE_OUTPUT_PREMIX (100.03) will be OPEN.
When the memory word PV_LIQUID_PREMIX (D0) is equal to zero “0” and the memory bit VALVE_OUTPUT_PREMIX_CUTOFF (W0.02) is ON, then the Output VALVE_OUTPUT_PREMIX (100.03) becomes CLOSE because of the “Interlock” of the memory bit VALVE_OUTPUT_PREMIX_CUTOFF (W0.02).
PLC sequential batch mixing logic with timers
RUNG 5 (MIXING MIXER)
When NO contact of the memory bit SYSTEM_ON (W0.00) is HIGH and the value in the memory word PV_LIQUID_MIXER (D2) is equal to SV_LIQUID_MIXER (D3), then the Output MIXING_MIXER (100.04) will be ON and the Timer TIMER_MIXER (T0001) starts counting up to 20 seconds.
The Output MIXING_MIXER (100.04) will be OFF when the TIMER_MIXER (T0001) Timer reaches “Set value”.
Sequential batch control PLC program
RUNG 6 (MIXER OUTPUT VALVE)
When NO contact of the memory bit SYSTEM_ON (W0.00) and TIMER_MIXER (T0001) is HIGH, the Output VALVE_OUTPUT_MIXER (100.05) will be OPEN.
When the memory word PV_LIQUID_MIXER (D2) is equal to zero “0” and the memory bit VALVE_OUTPUT_MIXER_CUTOFF (W0.03) is ON, then the Output Output VALVE_OUTPUT_MIXER (100.05) becomes CLOSE because of the “Interlock” of the memory bit VALVE_OUTPUT_MIXER_CUTOFF (W0.03).
  • PLC Product Sticker Machine with Weighing
  • Pump and Mixer Operations PLC Example
  • Waste-Burning System Omron PLC Example
  • Product Painting with Omron PLC Program
  • Schneider PLC Logic for Star-Delta System
How to Download GX Works? Mitsubishi PLC Software
Introduction to Functional Block Diagram in Studio 5000
Automatic Motor Forward and Reverse Control using Timer
What is Motor Jogging ?
PLC Basics – Manual Control, Closed Loop, ON-OFF with Hysteresis
Steps in PLC System Design
Schneider Electric PLC Timer Problem: Vacuum Cleaner
Memory Structure of Siemens PLC
How to Use ModScan Software for Testing Modbus Communication?
Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
#20 PLC Best Practices – Identify Critical Alerts
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
SFC Language in PLC Programming
PLC Crane Movement Control with Limit Switches
Playground Swing Logic Exercise Program in PLC
Relay Wiring
Add an alarm display to the graphics.
How to Configure an Alarm in InTouch SCADA?
Ladder Logic Example of Two Motors
Ladder Logic Example of Two Motors Interlinked with another Motor
Structured Text PLC Program for Sequential Process Data Storage
Structured Text PLC Code for Sequential Process Data Storage
PLC Program three-phase electric motor
Identify the Problem in the PLC Program
Simatic S7 PLC Backup Steps
How to take Backup from Siemens S7-300 PLC?
What is meant by the Batching Process
Batch Simulator PLC Example Program using LogixPro Simulator
SIS System Testing - Safety PLC Control System
SIS System Testing – Safety PLC
State Variables & Linear Discrete Time Systems
Flammable Gases and Vapors Class 1 & Class 2
Gas Detectors Standards
Level Sensors
Advantages & Disadvantages of Level Measurement Systems
Electrical Maintenance Engineer's Biggest Enemy
Electrical Components Overheating – Causes, Troubles, Prevent
Plant Engineering Drawings
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 1
Swiss Screw Machining
Things You Should Know About Swiss Screw Machining
5 Tips to Pass CFSE Exam
