Reading: Schematic Diagram
Inst Tools > Blog > Electrical Theory > Schematic Diagram
Schematic Diagram
Last updated: July 22, 2018 11:19 pm
Electrical Theory
1 Min Read
Schematic diagrams are the standard means by which we communicate information in electrical and electronics circuits. On schematic diagrams, the component parts are represented by graphic symbols. Because graphic symbols are small, it is possible to have diagrams in a compact form. The symbols and associated lines show how circuit components are connected and the relationship of those components with one another.
Schematic Diagram
Figure 9 Schematic Diagram
As an example, let us look at a schematic diagram of a two-transistor radio circuit (Figure 9). This diagram, from left to right, shows the components in the order they are used to convert radio waves into sound energy. By using this diagram it is possible to trace the operation of the circuit from beginning to end. Due to this important feature of schematic diagrams, they are widely used in construction, maintenance, and servicing of all types of electronic circuits.
AC Generator Theory
Power in Balanced 3 Phase Loads
DC Machines Construction
Classification of Transformers
Apparent Power, True Power, Reactive Power & Total Power
Single Phase Power Wiring Schemes
Electrical Wiring Terminology
Moving Iron Vane Meter Movement
Ampere Hour Meter
DC Motor Theory
AC Generation
DC Motor Torque
Multimeter & Megger Principle
Magnetic Circuits
Shunt-Wound DC Motor
Shunt-Wound Motor Operation
Parallel RLC Circuit
Impedance in RLC Circuits
Parallel Circuit Unknown Resistance
Simplified Formulas for Parallel Circuit Resistance Calculations
Squirrel-Cage Induction Rotor
Induction Motor
Series - Wound DC Motor
Series-Wound Motor
Left-Hand Rule for Generators
DC Generator Theory
DC Machine
DC Generator Internal Losses
Generator Action in a Motor
What is Synchroscope ?
Control systems in industrial projects
Interactions With Process Control Systems Philosophy
Strain Gauge Pressure Sensor Principle
Electromagnetic Flow Meters Working Principle
Control Speed of an Induction Motor using Analog Output of PLC
Control Speed of Induction Motor using Analog Output of PLC
Difference Between LED and LDR
Difference Between Sensor and Transducer
What is the Difference Between Sensor and Transducer?
Analog Measurement using Ladder Logic
Choppers Quiz
