Reading: Safety PLC Coding Practices – Programming Recommendations
Inst Tools > Blog > PLC Tutorials > Safety PLC Coding Practices – Programming Recommendations
In this article, we will learn the Safety PLC coding practices and the best tips you can follow when programming a safety PLC function.
Last updated: March 14, 2023 4:30 pm
Mahmoud Salama
12 Min Read
In previous articles, we talked about safety PLCs, and we showed how to use some of the most commonly used safety instructions that are built into the safety PLC, such as ESTOP instruction, SFDOOR, and Two_Hand_EN.
Programming a Safety PLCRecommendations for Safety PLC Hardware ConfigurationsSelect Suitable Safety PLCKeep the Safety Code Cycle Time in your MindProtect your Safety PLC against Unauthorized AccessConsistently Upload your Safety PLC CodeSafety PLC Programming Best Practices RecommendationsDefine a Structure for your Safety PLC LogicCall levels of Safety FCs and Safety FBsCall Sequence of BlocksUse Suitable Data TypesUse Proper CommentsUse Functional Naming of VariablesStandardize your Code BlocksData exchange between standard user program and safety programPrevent Automatic RestartingDon’t allow automatic Reintegration of safety modulesConclusions
But what if you need to perform a certain safety functionality that is not necessarily available as a built-in function? That is not a problem. We can just use basic instructions like AND, OR, COMPARE, and TIMERS.
To create whatever safety function you want to achieve. In this article, we will learn the Safety PLC best practice tips and guidelines you can follow when programming a safety PLC function to ensure your code complies with safety standards.
Contents:
  • Programming a safety PLC.
  • Recommendations for Hardware Configurations.
  • Recommendation for software programming.
  • Conclusions.
When programming a safety PLC, you can find all instructions available for programming a safety function in LAD or FBD with the configured safety PLC in the “Instructions” task card. See picture 1.
Picture 1 – Basic instructions in Safety PLC
Also, there are special safety functions, like two-hand monitoring, discrepancy analysis,
Muting function, emergency STOP, safety door monitoring, and feedback monitoring that we talked about in previous articles. These built-in functions are already built in such a way that is safe and complies with safety standards. See picture 2.
Picture 2 – Built-in Safety Functions
When programming a safety function for your process, you will most likely be using some of the built-in safety instructions available with the safety PLC and also you will need other basic instructions to complete your logic.
A safety PLC comes with many advantages and built-in features to help ensure safety for your code, but if your programming is sloppy, these features can have negative effects on your code, such as CPU stops and long compilation times.
The following recommendations will help you create optimal code for your process.
These recommendations consider in mind the Siemens S7-1200/s7-1500 safety PLCs with TIA Portal software, but you can use these tips with any other PLC brand.
The following are the best recommendations for safety PLC hardware configuration and selection of equipment.
To better select your safety plc you should have a clear idea about the following points:
  • Required response time of your safety function.
  • The number of inputs and outputs required.
  • The number of safety modules required.
  • Required memory of your code.
These points will help you choose the best CPU for your application.
A long cycle time of your safety program will slow down the response time of your safety functions.
And a short cycle time of your safety program increases the response time of your safety functions but will affect the time for processing the standard user program. So you should design your code with these points in your mind.
You should always assign password protection for your safety PLC, to prevent any unauthorized modification to your safety program.
Some safety PLCs have the feature of consistently uploading your safety code from automation.
This can help avoid errors and reduce service time and effort.
Follow the below-mentioned best practices when writing a Safety PLC program.
Try to divide your program code into separate parts depending on their function like detection, evaluation, or reaction. Or divide your code depending on machine sections.
This will make your code more simple and easy to understand, it will also help reduce programming errors, and make it easier to reuse program parts many times in your code.
Siemens safety PLCs allows a maximum of eight call levels for your safety program, other brands may allow for more or less, an error will be present if when exceeding this limit and your safety code will not work. Keep that point in mind.
In your safety program, you will have different blocks for different functions like communication between safety modules, logic operation, and evaluation of inputs.
There is a recommended sequence of calling your blocks to ensure the PLC always uses the latest values.
The sequence is as follows:
  • Receive information from other CPUs (if there is more than one safety plc in your process).
  • Error acknowledgment or reintegration of safety modules
  • Evaluation block of the sensors
  • Operating mode evaluation
  • Logic operations, calculations, evaluations, etc.
  • Control blocks for safe actuators
  • Send information back to other CPUs (if there is more than one safety plc in your process).
Safety PLCs allow the use of UTDs of user data types, it is recommended to structure your tags using these data types so that a change in a PLC data type is automatically updated in all points of use in your safety program.
Use Proper Comments
In the block comment of your block, enter all formal information about the block like; the last block modification, date, and signature, or the functionality of this block. This makes it easier to track functional changes in the block
In practice, a safety function is described using this terminology: “When a safety door is opened, drive XY must be safely shut down.”
However, safety programs are usually programmed as a release signal, not a shutdown signal. This is due to the fact that safety interconnections are designed based on the closed-circuit principle. If, for example, a safety door is closed, it gives the enable to switch on a safe actuator.
So, it is recommended to Define a uniform name for the variables. That will reflect the meaning and purpose of that variable in your code. For example, SafetyDoorEnable or ConveyorSafetyRelease.
In addition to the logic for evaluating an input safety sensor of logic for controlling an output actuator, some other functionality is often necessary (e.g., edge evaluation, time functions, acknowledgment, etc.)
So, it will be useful to create and reuse modular blocks for sensor evaluation, and controlling actuators.
Create a separate function block for each sensor type (e.g., emergency stop command device, safety door, light curtain, etc.) that combines the evaluation of the sensor and the necessary auxiliary functions. Use this sensor block for other sensors of the same type.
Some of the necessary auxiliary functions may include:
  • reset
  • restart interlock
  • time functions
  • edge evaluation
  • startup test
You usually need to transfer data in your code between your safety program and your standard program. In order to move non-safety-related data to the standard user program, you have to define an interface between your safety program and your standard program. Global Data Block is that interface.
It is recommended to define a standard global data block to transfer your data and it is best recommended to make it two separate global data blocks, to separate between data written into the standard program and data read from the standard program. See picture 3.
PLC user program and safety program
Picture 3 – Data exchange between standard user program and safety program
If a safety hazard condition is present the safety function should stop your process.
However, your safety program should not allow your process to automatically restart once the safety condition is cleared; instead, the process should wait for a restart signal from the standard program (operator) before restarting the process. See picture 4.
Locking process control with release signal
Picture 4 – Release signal from safety code
As you can see from picture 4 the process will stop if the release signal from the safety program is interrupted. But the process will only start when the start signal from the Process control function in the standard program is available
Automatic reintegration of your safety modules is also not recommended. You can either manually acknowledge all safety modules for reintegration at the same time, using the Global Acknowledgement function which we discussed in a previous article. Or you can manually acknowledge each safety module separately using ACK_REI tags of the respective safety module data blocks:
Conclusions
Previously mentioned PLC recommendations and many others that you can find in programming guidelines’ manuals are presented to help create an optimal program for your process safety.
Not all provided recommendations can be applied at the same time, it will depend on you to decide what to do, based on your process requirements.
Following these PLC tips and recommendations will come with many benefits:
  • To be able to reuse standard blocks of your code.
  • Easier to review your code, detect errors and perform corrections.
  • Your code will be easier to read and understand.
  • Reduce the runtime of your safety program.
  • PLC Feedback Monitoring
  • Safety Interlock PLC Program
  • Industrial Automation Solution
  • Automation Project Investment
  • Motor Feedback Fail Logic in PLC
Oil and Water Separation Process using PLC Programming
How to Connect a Solenoid Valve with PLC?
Types of Interrupt OB in Siemens Tia Portal
PLC Programming Example for Motor Forward and Reverse Control
Rules for Writing SCL Language in Tia Portal
How to Password Protect HMI in Siemens TIA Portal?
EasyBuilder Pro Online Simulation of Mitsubishi FX3U PLC
What is SCADA System?
Types of Expressions in the SCL Language of the Tia Portal
PLC Trainer Demo Download
#6 PLC Best Practices – Validate Timers and Counters
Omron PLC for Product Painting with Integrated Weighing System
Omron PLC Logic for Washing Machine Automation
Top 100 PLC Objective Questions and Answers
Timer STL Programming
Timers using Statement List (STL) PLC Programming
PLC Program for Conveyor Motor
PLC Conveyor Motor Ladder Logic
Manual sequential logic in Schneider PLC
Programming Schneider PLC Manual Sequential Machine
Allen Bradley PLC Interview Questions & Answers
Allen Bradley PLC Interview Questions and Answers
PLC Programmer Salary and Future Career Scope
Analog Measurement using Ladder Logic
Cyclic Interrupts TIA Portal
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
Retro-Reflective Sensor
PLC Programming for Pumping and Draining System
Wet Contacts and Dry Contacts in PLC Systems
Metering pumps
Metering Pumps
Optical Fiber Size
Fiber Optic Cable Connectors, Routing, and Safety
Unspecified CPU in Tia Portal
How to Add Unspecified CPU in Tia Portal?
Electrical Motor Failures
Most General Reasons for the Electrical Motor Failures
Series-Wound DC Generator Principle
Series-Wound DC Generators
