Reading: RTD Testing Methods in Calibration Laboratory
Inst Tools > Blog > Calibration > RTD Testing Methods in Calibration Laboratory
Last updated: September 28, 2020 10:47 pm
Calibration Temperature Measurement
3 Min Read
Here we discuss the brief overview of different In-House testing methods carried out for RTD assemblies in the Calibration Laboratory.
RTD Testing Methods1. Calibration2. Insulation Resistance Test at ambient (room temp.) at 500 VDC3. Insulation Resistance Test at 3200 C at 100 V DC4. N2 leakage test5. Response time test6. Special test7. Continuity Test8. Sheath Integrity Test9. Response time test with RTD connected to the pipe10. Self-heating error test
RTD Testing Methods
The below list shows the different testing methods.
1. Calibration
RTD calibration can be done as per IEC 751 / DIN 43760 Class A & B.
Normally test is conducted for two points (i.e. 00 C & 1000 C), 3 point calibration or more can be followed.
It should be more than 100 M ohms.
IR should be more than 2 M ohms. More than 20 M ohms also can be offered.
4. N2 leakage test
For the RTD sensor, after cap welding, the N2 leakage test should be carried out no leakage should be observed at 40 kg/cm2.
Response time test as per IEC 751 – (63.2% step change from ambient to 800C).
For RTD without transmitter – 6 to 9 sec up to 6 mm OD of sheath.
For RTD with thermowell – the response time will be 35 to 45 sec.
6. Special test
Autoclave test – RTD kept in steam @ 1250C & at 1.2 kg/cm2 for about 1 hour.
IR should be more than 5 M Ohms.
7. Continuity Test
By using continuity tester/multimeter – This test is used to confirm the element is connected properly to the RTD transducer cable.
Water Immersion test – To check the sheath integrity of thermocouple / MI RTD cable.
Response time test for RTD with RTD connected to pipe on its outside surface to which water is flowing @ 20 ltrs. per second & @ 800C. The acceptance norm is less than 20 seconds.
It is in accordance with IEC 751
source: Prisma Instruments
  • Formulas of RTD
  • Calibration of RTD
  • Four-wire RTD Circuit
  • Terminations of RTD
  • RTD Wheatstone Bridge
  • Different Standards for RTD
  • Temperature Error of RTD
  • Lead Wire Resistance Error
  • Interview Questions on RTD
Difference between PT100, PT1000, Nickel RTD and Balco RTD
What is calibration?
Calibrating Level Transmitter with Remote Seals
Difference between Accuracy and Precision
Stroke Checking Procedure for GCV, SRV, IGV, and LFBV
Components of RTD
  • Mukesh Sharma says:
    February 13, 2021 at 11:50 am
    This is very important my knowledge
Instrument Errors – Zero, Span, Linearity
Smart Transmitter Calibration Tutorial Part 1
Thermocouple and its Principle
Laws of Thermocouples
Why Thermocouple Reference Junction Compensation Required ?
What is a Dead Weight Tester?
Thermocouple Calibration
Questions on Thermocouple and Pyrometer
Technologies for Oxygen Gas Measurement
How to Calibrate Oxygen Analyzer? – O2 Sensor Testing Procedure
Temperature Transmitter with Thermocouple
Thermocouple Extension and Compensating Cables
Turbidity Sensor Calibration Procedure
Closed-tank-DP-Level-Transmitter-with-wet-leg-elevation-zero-direct-mount-Calibration
Closed tank DP Level Transmitter with wet leg elevation zero direct mount Calibration
Four Wire RTD Circuit
What is a Four-wire RTD ?
Gas Detectors Bump Testing
What is Bump Testing ?
high-accuracy voltmeter
Electrical Standards
Difference Between RTD, Thermocuples and Thermistors
Difference Between RTD, Thermocouple and Thermistor
Electrical Heating Objective Questions and Answers
Gas Detection System Abbreviations
Basic Electricity Objective Questions and Answers
100+ Basic Electricity Objective Questions and Answers
VFD Commissioning and Testing Procedure
3-way globe valve
What is Mixing or Diverting Valve ?
Feedforward Control
Feedforward Vs Feedback Control
Single Excited Electric Field Systems Quiz
Definitions of Electrical Grounding
