Reading: Rotary Stem Valves
Inst Tools > Blog > Control Valves > Rotary Stem Valves
Rotary Stem Valves
Last updated: March 21, 2019 4:27 pm
Control Valves
1 Min Read
A different strategy for controlling the flow of fluid is to insert a rotary element into the flow path. Instead of sliding a stem into and out of the valve body to actuate a throttling mechanism, rotary valves rely on the rotation of a shaft to actuate the trim.
An important advantage of rotary control valves over sliding-stem designs such as the globe valve and diaphragm valve is a virtually obstruction-less path for fluid when the valve is wide-open.
Rotary Stem Valves
Rotary Stem Valves
Of course, gate valves also offer obstruction-less flow when wide-open, but their poor throttling characteristics give most rotary valve designs the overall advantage.
Components of Shutdown Valve
Air Filter Regulator Working Principle Animation
What is Reducing Valve ?
What happens when Fluid Flow Reversed through Control Valve?
How Diaphragm Valves Work ?
How Valve Positioners act as Cascade Control Systems in a Loop?
Pressure Relief Valve Terminology
How Ball Valves Work ?
Rotork Motor Operated Valve Basic Configuration
Pneumatic Valves Questions & Answers
Purpose of 100% and 30% Feed Control Valves in a Power Plant
Pilot-operated Relief Valve Principle
Valve Seat Leakage Test
Types of Check Valves
Identify Valve Parts Quiz with Answers
Direct Acting Actuators
Effect of Differential Pressure on Control Valve Lift
Needle Valve Body Design
What is Needle Valve ?
On Off Valve Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
single-acting-vs-double-acting-control-valve-actuators
Single Acting Vs Double Acting Actuators
Current to Pressure Converter Principle
Current to Pressure (I/P) Converter Principle
Flow Control Valves Interview Questions
Cage-guided globe valves
What is Cage-guided Globe Valve ?
Transistor as an Amplifier in Common Emitter
Interlock Philosophy
Types of Interlocks
Instrument Air Quality
Auto Recloser Circuit Breaker in Power System
Digital Electronics Objective Questions – Set 9
Instrumentation Engineers Interview Questions & Answers
Liquid Level Control using Flow Loop
Simple Conveyor Control PLC Program
XG5000 Example of Simple Conveyor Control PLC Program
