Root Cause Analysis (RCA): Too noisy & too maintenance intensive granulator drive silenced and made maintenance free.
Article Type: | Root Cause Analysis (RCA) |
Category: | Mechanical |
Equipment Type: | Pipelines and Miscellaneous Problems |
Author: | S. Raghava Chari |
Granulator Drive Details
An NPK plant’s rotary granulator drive consisted of a 400 V, 1500-RPM 150 KW motor flexible coupling coupled to between plummer blocks supported keyed to shaft sprocket chain driving another similar twice dia sprocket (below figure).
The low speed sprocket shaft flexibly couples to a 7.5 reduction gearbox input shaft. Gearbox output shaft flexibly couples to a between plummer blocks supported 13 teeth pinion.
Hence, the pinion speed is 100 RPM. The pinion meshes with the granulator drum attached 143 teeth girth gear to run the granulator at 9 RPM.
Author Modification
He substituted a 15:1 gearbox (GB) and coupled its input shaft to the motor shaft.
He did not rewind the motor for 750 RPM to use the same GB as motor and GB shafts were inadequate for the doubled torque at ½ the RPM.
Modification Benefits including eliminated problems
Below listed are the Modification Benefits:
- Two sprockets, chains, and four plummer blocks vanished. Consequent clutter free roomy area promotes safety and invigorates people working there
- Low tech tasks of frequent chain lubrication, clearing tangled up snapped chains and rejoining, worn chain replacing and chain whips damaged chain guards etc. vanished
- Expensive lube oil consumption, chain splashed lube cleaning housekeeping efforts, annoying chain whip noise and slip hazards risks too vanished
- Thanks to eliminating maintenance prone chain drive, the below <Â 70% granulator availability shot up to 100%.
- Production increased by 15%
- Granulator maintenance efforts and costs reduced by 60%
The freed from low-tech tasks and noisy environs operating and maintenance crew thanked the author. However, they joked, “The silence makes us feel eerie especially in the night shifts.
Author: S. Raghava Chari
- Gas Cooler Re-tubing
- Finned Tube Steam Leaks
- Problems with Demister Pads
- Bucket elevators teeth wear Problems
- Centrifugal Compressor Shaft Vibration
