Reading: Read Gas Composition from Gas Metering System using RS485 Protocol
Inst Tools > Blog > Control Systems > Read Gas Composition from Gas Metering System using RS485 Protocol
How to Get Gas Composition and Process Variables Data from Gas Metering and Regulating Station using RS485 serial communication Protocol?
Last updated: December 14, 2021 12:19 pm
Control Systems Flow Measurement
2 Comments
6 Min Read
Article: How to Get Gas Composition and Process Variables Data from Gas Metering and Regulating Station Using RS485 or RS232 serial communication Protocol?
Gas Metering SystemElectronic Volume Corrector Configuration at MRS PipelineMetering System using RS485 ProtocolFlowSolv SoftwareGasComm SoftwareSCADA System
Read my first article: What is Gas Meter and Regulating Station?
This time we will discuss about how to get gas composition values (like C1, C2, C3,…) and process variables data (like pressure, temperature, flow rate, volume at measurement condition, and volume at the base condition) from gas metering system.
First, we must know about custody transfer metering in the oil and gas industry. The concept is we need to measure the plant oil and gas production using a metering system before transferring to the outside world like power plants, companies, household applications, etc.
Gas Metering System
Here we use an Electronic Volume Corrector (EVC) at Gas Metering and Regulating Station (MRS). This instrument works to convert the gas at the measurement condition (Vm) to the base condition (Vb).
The EVC configuration includes sensors at the MRS pipeline connection is shown in the below picture.
Gas Metering System Using RS485 Serial Communication Protocol
The conversion process at EVC is using American Gas Association 8 (AGA 8) Detail and NX (for Nitrogen and Carbon Monoxide only) calculation. The data for the conversion process by EVC with AGA 8 Detail is from the turbine meter that uses the AGA 7 Calculation.
And what do we need from the EVC? We need a :
  1. Gas Compotition Data
  2. Gas Variables Conditions (P,T,V)
And how we can get the data?
The answer is by checking the EVC manually (via HMI interface) or using an RS485 serial communication protocol.
By using the EVC HMI interface is like the picture below.
Gas Composition PTZ Box
Getting Gas Composition Information using EVC HMI
So we must turn on the EVC and go to the gas composition menu. The gas parameters will be displayed on the HMI as shown in the above image.
We can also read the gas composition using the RS485 protocol and display the data on a laptop or a computer.
Electronic Volume Corrector (EVC) Serial Communication
                      Getting Gas Composition Information using EVC RS232 Port
The below-mentioned tools are required to get the data from the controller and software reads this data using a PC.
The main devices are RS485/RS232 serial communication converters.
As we don’t have dedicated RS 232 or RS 485 serial ports in our laptop or PLC, we use RS485/232 to USB converters to connect to the laptop.
RS 485 to USB Converter
RS485 to USB Converter
RS 232 to USB Converter
RS232 to USB Converter
Now we use these converters to connect the Electronic Volume Corrector to our laptop or PC.
FlowSolv Software
We use a laptop to read the gas composition data. We will connect the USB converter to the laptop. We will open software called “FlowSolv”.
Using the FlowSolv software, we can read the gas composition data and generate a report as shown in the below image.
FLOWSOLV oil and gas fluid and flow calculation software
Flowsolv Software
So by using the Flowsolv Software we will Know about Gas Composition at Meter Regulating Station (MRS).
GasComm Software
Then we use a software named GasComm to get the gas variable conditions details as shown in the below image.
GasComm Software
GasComm Software
From GasComm software, we can make a report about gas composition and other process variables data.
After the gas flow rate has been converted to standard condition, the EVC will send the measurement data using a modem or GPRS communication to the billing server from the oil and gas industry company.
SCADA System
The data can be monitored by the SCADA system by using additional hardware at the system.
Turbine Meter in Gas Metering System
The above figure shows the EVC data Transmission & Configuration to System Billing/SCADA with Turbine Meter.
The below figure shows the transfer of data to the billing system/SCADA.
Billing SCADA
EVC data Transmission to System Billing/SCADA
And to transfer the data to the billing system/SCADA, we use the additional equipment (INT-S3 and EM-1 Module) as shown in the below image.
Custody Metering System SCADA
EVC data Transmission to System Billing/SCADA Using Digital Output Configuration
For additional information, the EVC readout using RS485 is must need external power supply addition.
And for data transfer activity for SCADA or billing system is needed additional batteries inside the EVC box as shown in the below image.
Power Supply of Electronic Volume Corrector
EVC Additional Power Supply Input
Author: Ramadhani Ichlasul Amal
Bachelor of Applied Instrumentation Engineering Sepuluh Nopember Institute of Technology (ITS). And now at Jargas Jombang Operational and Maintenance Team.
Why Viscosity is Not Included in the Orifice Equation?
ICS Control System Security
Process Dynamics and PID Controller Tuning
How to Avoid Bad Grounds ?
Industrial Automation in the Mining Industry
Optical Flow Meter Principle
2 Comments
  • NGUYEN TUAN VU says:
    June 13, 2022 at 12:56 pm
    The difference in Vb(Sm3) on EVC when installing 02 Turbine meter + EVC EK220 of Honeywell (Gas measurement) is about 1km apart. Why is there such a difference? Thank so very much.
  • George Donkor says:
    March 18, 2023 at 4:43 pm
    How can I get a link to download the GasComm software
What is Alarm Management System ?
Pressure based Flow Meters
Ziegler-Nichols Closed-Loop Method (Ultimate Gain)
Proportional-only Control Theory
What is Multi-touch Technology? – Industrial Automation
Ultrasonic Flow Meters Animation
DCS System Cabinet
Yokogawa DCS System Maintenance Procedures
Interlock Philosophy
Types of Interlocks
VFD Commissioning and Testing Procedure
Integral controller eliminates offset error
How Integral Controller Reduces offset error ?
Foundation Fieldbus
Foundation Fieldbus – Advantages, Limitations, Architecture
Digital output block add-on for Variable speed drive
Steps to Import PlantPAx Add-On Instructions in Studio 5000
DCS Program to Maintain Draft in Furnace
Instrumentation and Control General Specifications
Instrumentation and Control (I&C) General Specifications
steadily pour a liquid into vertical tube
Vertical Tube Liquid Level Equilibrium
Digital Electronics MCQ
Digital Integrated Circuits Objective Questions – Part 2
Impulse Tubing Leak Test Checks
solenoid-valves-types-principle-animation
Solenoid Valves Types, Principle & Animation
DC Generators Characteristics Quiz
Differential Pressure Measurement across Baghouse
Schottky Diode Vs PN junction Diode
Difference between Schottky Diode and PN junction Diode
