Reading: Convert Process Variable to Percentage
Inst Tools > Blog > Instrumentation Tools > Convert Process Variable to Percentage
Last updated: November 12, 2019 3:51 pm
1 Min Read
Convert Process Variable to Percentage:
This tool is used to calculate the equivalent transmitter output signal in percentage from process variable, URV & LRV.
This calculation tool is used to find out the equivalent Percentage signal using PV, URV & LRV.
Where,
PV = Process Variable
URV = Upper Range Value (Transmitter Max scale value)
LRV = Lower Range Value (Transmitter Min scale value)
Note:
1.For calculating the equivalent Percentage signal, we have to enter PV, URV & LRV details.
2.The above calculation tool designed for a standard 0-100% signal conversion.
3.You can convert out of range signal also with the above tool.
(Example: URV = 100, LRV = 0 and PV = 110)
Differential Pressure (DP) Level transmitter Installed Below Tapping Point
Density Measurement for Open Tank with Constant Level Application
Level Measurement with Dry leg and Installed Below Tapping Point
Convert current (4-20mA) to Percentage (0-100%)
Convert Percentage (0-100%) to current (4-20mA)
Boiler Drum Level Transmitter Calibration
Interface Level Measurement using DP Transmitter
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
Convert Linear mA to Square root mA
RTD Calculator : Calculate Temperature from Resistance
Convert Linear Percentage to Square root Percentage
Calculate Current (4-20ma) from Process variable PV
RTD Calculator : Calculate Resistance from Temperature
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Wet-leg
Density Measurement using DP Transmitter for closed tank with wet leg
instrumentation-calculator
Instrumentation Calculator
Convert-Transmitter-Output-in-Percentage-to-Process-Variable
Conversion of Transmitter Output in Percentage to Process Variable
DP-Flow-Transmitter-Re-Ranging-calculation
DP Flow Transmitter Re-Ranging Calculation
DP-Level-Transmitter-Diaphragm-with-capillary-tube-type
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
mA-Conversion-Tool
Transmitter Current Conversion Tool
Closed-Tank-DP-Type-Level-Measurement-with-wet-leg-and-transmitter-installed-below-tapping-point
Level Measurement with Wet leg and Installed Below Tapping Point
Create PLC Program based on Logic Circuit
Types-of-diodes
Different Types of Diodes
Parameters of SRT_DINT instruction
Tia Portal – OB20 Time Delay Interrupt Organization Block
Inductively Coupled Plasma Mass Spectrometer
Functional Testing of Control Valve Positioners
Routine Tests of Circuit Breakers
Circuit Breaker Testing – Routine Tests of Circuit Breakers
5-valve manifold
valve actuator yoke
Advantages and Disadvantages of Valve Actuators
