Reading: Pneumatic Valves and Cylinders Sizing – Part 1
Inst Tools > Blog > Instrumentation Design > Pneumatic Valves and Cylinders Sizing – Part 1
Last updated: May 10, 2019 12:56 pm
7 Min Read
Valve and cylinder sizing represents possibly the most important element in the design and specification of any pneumatic system. Carried out correctly, it will ensure that capital and operating costs are minimised, while maximising system performance, reliability and efficiency.
Cylinder Sizing
Cylinder applications can be categorised as either:
  • STATIC, i.e. clamping, pressing, etc. or
  • DYNAMIC i.e. load moving.
In both cases the principle factors which must be considered when calculating the correct cylinder bore size are:
  • Amount of thrust required.
  • Available air pressure.
  • Efficiency of the cylinder
Cylinder Thrust
Cylinder thrust is a function of:
  • Piston diameter
  • Applied air pressure
  • Frictional resistance (efficiency
Required cylinder thrust is generally derived from a known clamping pressure (static) or the force required to move a particular load (dynamic) and is expressed in units of pounds force (lbf), kilogram force (kgf) or newtons (N).
In the case of dynamic applications, consideration must also be given to the decaying pressure on the side of the cylinder piston open to atmosphere.
Pneumatic Cylinder
In order to regulate cylinder speed, the decaying pressure on the side of the cylinder’s piston open to atmosphere, should be approximately 1.5 bar and can be considered to work against the cylinder.
To determine the correct size of cylinder, it is necessary to use the formula:
Thrust = Pressure x Area x Efficiency
Pressure in this instance being the available air pressure, expressed in units of bar, N/m2, lbf/in2 or kgf/cm2, and area being the piston area in units of m2, cm2 or in2. (One bar equals approximately 1 kgf/cm2).
Cylinder efficiency varies between manufacturers, being dependent upon both cylinder construction and the seal technology employed. The general efficiency of cylinders designed with lip seals is considered to be 80% whilst more sophisticated and technologically advanced designs can be as high as 97%.
Example 1:
Determine the size of cylinder (D) required to move a load of 150 kg, given an air pressure of 7.3 bar (7.3 kgf/cm2 ). Assume an efficiency of 90%.
Thrust = Pressure x Area x Efficiency (μ)
therefore, 150 = (7.3 – 1.5) x (Ï€ D2 / 4) x 0.9
Transposing this formula then gives:
D2 = (150 x 4) / [(7.3 – 1.5) x p x 0.9]  = 36.6  = 6.05 cm
Note : The available pressure of 7.3 bar was reduced by 1.5 bar to allow for decaying pressure on the side of the piston open to atmosphere. The example uses on efficiency of 90%
The result is directly equivalent to the diameter of the cylinder required, measured in centimetres. In practice, however, cylinders with the exact calculated bore size are not usually available. It is therefore necessary to specify a cylinder with the next standard bore size. In this case, a 63mm cylinder would be selected.
Clearly, with a larger bore cylinder, a decrease in working pressure can be tolerated; the difference between available air pressure and required system working pressure being the maximum permissible system pressure drop.
The basic formula used above can also be developed to encompass the extending stroke on a single acting cylinder and the retracting stroke on a double acting device.
For the extending stroke on a single acting cylinder:
FE = P x A x μ – FS
Where:
FE represents the extending cylinder thrust
P = available pressure
A = piston area
μ = efficiency
FS = the spring force at the end of stroke
For the retracting stroke on a double acting cylinder:
FR = Ï€(D2 – d2)/4 x P x μ
Where:
FR represents the cylinder thrust to retract
D = piston diameter
d = piston rod diameter
μ = efficiency
Note : In this case, no allowance needs to be made for decaying pressure on the side of the piston open to atmosphere since when clamping, the piston will be static and this pressure will be zero.
Example 2:
Determine the size of a cylinder operating at a pressure of 6 bar (600000 N/m2), which would be capable of generating a clamping force of 1600N.
Based on the extending stroke formula:
FE = P x πD2/4 x 0.9
therefore, 1600 = 600000 x πD2/4 x 0.9
Transposed to give:
D2 = (4 x 1600)/(600000 x π x 0.9)
D =  0.0614 m
D = 61.4 mm
Again, the next standard size of cylinder would be 63mm.
Once these formulae are understood, it is possible to produce a chart on which the theoretical thrust of any given cylinder bore can be shown against any given air pressure. See Figure below.
Cylinder Sizing
Note : If cylinder stroke is excessive and working pressure is near to maximum, final cylinder selection should be made in consultation with manufacturers representatives since rod buckling forces may need to be considered.
This chart does not take cylinder efficiency into consideration since this will vary between manufacturers. Values should, therefore, be multiplied by the efficiency factor to obtain usable thrust.
The graph below, Figure 2, allows an efficiency factor (m) to be obtained for various cylinder bore sizes where the supply pressure is known.
Pneumatic Cylinder Sizing
Note : The data shown on this graph applies to cylinders produced by SMC Pneumatics. Manufacturers of other cylinders should be consulted to obtain efficiencies for their designs.
Also Read : Pneumatic Valves and Cylinders Sizing – Part 2
Source : smc.eu
As per Process Conditions, Find out the Circuit Components Status ?
Role of an Instrumentation Design Engineer for Beginners
What is a Control Loop ?
How to Select a Pressure Gauge
Solenoid Operated Valves and Latching Valves
What is SAMA Diagram?
List of Instrumentation Project Engineering Documents
Pressure Control Valves vs Pressure Regulators
What to Choose RTD or Thermocouple ?
Thermowell Insertion and Immersion Length
Remote Seal Transmitters Temperature Error
Immersion Heaters in Lube Oil Consoles
Competency Factors of Instrument & Control Engineer (Design Engineering)
What are Impulse Lines? – Impulse Line Problems & Solutions
What's the problem with shock and vibration
What’s the problem with shock and vibration ?
Orifice Plate Sizing
Orifice Sizing Guidelines and Thumb Rules with Flowchart
Instrument Air Calculations
Basic Calculations of Instrument Air
Instrument Datasheet
What is Instrument DataSheet ?
Instrumentation Deliverables Generated from 3D Modeling
control-valve-actuators
Control Valve Selection Tips
PLC TB Wiring
Electrical Signal and Control Wiring
Vortex Flow Meters
All About Vortex Flow Meters
Sensors and Transducers Test
What is Transparent Solar Panel
What is Transparent Solar Panel? – Working Principle and Theory
Pros and Cons of Online Educational Services
Pros and Cons of Online Courses
PLC Star-Delta starter with interlock
Schneider PLC Example Program for Star-Delta System
Network topologies
Different Types of Network Topologies
Random Access Memory Objective Questions – Part 2
p-type-semiconductor
N Type and P Type Semiconductors
Galileo thermometer Principle
Galileo Thermometer
