Reading: PLC Program to Count Running Hours of any Equipment
Inst Tools > Blog > PLC Tutorials > PLC Program to Count Running Hours of any Equipment
Last updated: March 4, 2021 2:25 pm
4 Comments
2 Min Read
This is a PLC Program to count running hours of any equipment using bit instructions, math instructions, and counters.
PLC Running HoursPLC Programming
PLC Running Hours
In industry, it is sometime necessary to count running hours of any equipment (pumps, compressors, motors) to maintain its efficiency, equipment life as well as periodic maintenance. By using PLC instruction we can prepare a PLC program to count the running hours of any equipment.
PLC Running Hours
PLC Programming
Here is the PLC program to count the running hours of any equipment.
Network 1:
PLC Pump Running Hours
This network adds the 1 second at every 1-second pulse when there is running feedback of equipment and there is no reset bit.
Network 2:
converts seconds into hour in plc
This is the network that converts seconds into the hour.
Network 3:
mod instruction in plc
In this network, we are getting the remaining second by mod instructions and then convert it into minutes.
Network 4:
converts minute into second in plc
This network converts minute into seconds.
Network 5:
CMP instruction in plc
Reset Logic for pump Run Hours
These two networks are for reset logic. When there are 1000 hours in the count it will add count up by 1 and reset all the counting by just moving 0 to an hour, minute and second.
Author: Hiral Patel
  • PLC Logic for Oil Pump Motor
  • PLC Programming for Motor
  • Traffic Light Control using PLC
  • Industrial Conveyor Ladder Logic
  • Lamp Control using PLC Logic
What are Faceplates? How to Create a Faceplate? HMI Visualization
PLC Sequencer Instruction with Example
What is an RTU? – Remote Terminal Unit
Auto Tiffin Box Filling Station
Example of PLC Programming based on Logic Circuit
SCADA System Vulnerabilities
4 Comments
  • Pugazhendi Ramalingam says:
    March 20, 2020 at 6:25 pm
    In case of HT equipment’s, while commissioning after annual overhaul, the motor circuit will be frequently switched on & Off under testing position and this will boost the actual running hours of machines.
    Hence we have corrected this logic instead from motor ON contact, motor current > … Amps will initiate the counter circuit please.
    Thanks for sharing what,why,where concepts of instrumentation to Knowledge World. Congrats.
  • Franklin Ferreira de Lima says:
    August 6, 2023 at 8:54 pm
    Este trabalho é um princípio, de funcionamento para as instalações elétricas, podemos fazer o mesmo, até que às práticas estejam bem direcionadas.
  • Tad says:
    April 24, 2024 at 10:15 am
    will the running hours be resset incase the plc is restarted ?
  • rajesh says:
    May 6, 2024 at 5:30 pm
    if PLC is restarted then running hours will be reset to zero.
How to Create Templates in FactoryTalk View Studio?
FC Function in Siemens PLC
Static and Temp Variables in PLC
CX Programmer Example: Perfume Mixing and Filling System
Studio 5000 Tutorial: PLC Programming for Digital Alarms
PLC Controlled Conveyor and Weighing with Labeling Automation
PLC Example on Switch Program with Timers
How PLC Reads the Data from Field Transmitters
Normally closed input actuator as stop button.
Normally-Closed Contacts for Stop Buttons
PLC Load Memory
What is Resources Tab in the Siemens PLC?
Function Block Program Simulation
PLC program for Latching and unlatched circuit
Example of Automated Guided Vehicle with PLC
PLC Wiring
What is Profinet and How to Configure in Siemens PLC
What is Profinet and How to Configure in Siemens PLC?
Simulating Level Sensor and the Pump Logic in PLC
PLC Basics – Manual Control, Closed Loop, ON-OFF with Hysteresis
Feedforward Control
Feedforward Vs Feedback Control
Laser Diode Working Principle
Thermocouple cold junction compensation
Why Thermocouple Reference Junction Compensation Required ?
Difference Between RCCB and MCCB
11 KV Bus A to Bus B Phase Check Problem
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
ball Valve Animation
Basics of Ball Valves
