Reading: 3 to 8 Line Decoder PLC Ladder Diagram
Inst Tools > Blog > PLC Tutorials > 3 to 8 Line Decoder PLC Ladder Diagram
Implement 3 to 8 line decoder in PLC using ladder diagram programming language. Learn the PLC tutorials with examples.
Last updated: November 3, 2023 1:43 pm
3 to 8 Line DecoderProblem SolutionList of inputs/outputsPLC Program to implement 3 to 8 line decoderProgram DescriptionResult
3 to 8 Line Decoder
3 to 8 Line Decoder Circuit Diagram
Problem Solution
For this problem, we will use S7-1200 PLC and TIA portal software for programming.
This decoder has three inputs and 8 outputs and these inputs determine which output will be ON.
Here three inputs were used (Input 1-I0.0, Input 2-I0.1, and Input 3-I0.2), and 8 outputs were used (Output 1 to 7, Q0.0 to Q0.7).
If all inputs are OFF, output 1 (Q0.0) will be ON and others are not.
List of inputs
  • Input 1:- I0.0
  • Input 2 :- I0.1
  • Input 3 :- I1.0
List of outputs
  • Output1 :- Q0.0
  • Output 2 :- Q0.1
  • Output 3 :- Q0.2
  • Output 4 :- Q0.3
  • Output 5 :- Q0.4
  • Output 6 :- Q0.5
  • Output 7 :- Q0.6
  • Output 8 :- Q0.7
PLC Program for Decoder Logic
Decoder PLC
3 to 8 line decoder
Decoder Ladder Logic
PLC Decoder Application
PLC Decoder Example
PLC Logic for Decoder
PLC Decoder Program
Program Description
For this application, we used S7-1200 PLC and TIA portal software for programming.
Network 1:
If all inputs are OFF (I0.0=0, I0.1=0 and I0.2=0), Output 1 (Q0.0) will be ON.
Network 2:
If input 1 (I0.0) and input 2 (I0.1) are OFF and input 3 (I0.2) is ON, Output 2 (Q0.1) will be ON.
Network 3:
If input 1 (I0.0) and input 3 (I0.2) are OFF and input 2 (I0.1) is ON, Output 3 (Q0.2) will be ON.
Network 4:
If input 2 (I0.1) and input 3 (I0.2) are ON and input 1 (I0.0) is OFF, Output 4 (Q0.3) will be ON.
Network 5:
If input 2 (I0.1) and input 3 (I0.2) are OFF and input 1 (I0.0) is ON, Output 5 (Q0.4) will be ON.
Network 6:
If input 1 (I0.0) and input 3 (I0.2) are ON and input 2 (I0.1) is OFF, Output 6 (Q0.5) will be ON.
Network 7:
If input 1 (I0.0) and input 2 (I0.1) are ON and input 3 (I0.2) is OFF, Output 7 (Q0.6) will be ON.
Network 8:
If input 1 (I0.0) and input 2 (I0.1) and input 3 (I0.2) are ON, Output 8 (Q0.7) will be ON.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of 3 to 8 line decoder, we can use this concept in other examples also.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications. Also all interlocks are not considered in the application.
Result
3 to 8 Line Decoder
Author: Bhavesh
  • PLC 3 Phase Asynchronous Motor Control
  • Energize & De-energize the Outputs using PLC
  • PLC Level Control of Parallel Tanks
  • GE PLC Ladder logic program download
  • Allen Bradley PLC Subroutines
Yokogawa DCS and SIS System Architecture
SAVE and BR Memory Instructions in Siemens PLC Programming
Parallel Tanks Level Control using PLC Ladder Diagram Tutorial
Advanced PLC Conveyor Control: Forward and Reverse Rotation
PLC vs PAC – Understanding the Key Differences and Similarities
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
Redundant Automation Systems – Need and Advantages
CW and CCW Operation of Motor from Same Push button
Push button Motor PLC Logic
#17 PLC Best Practices – Log PLC Uptime and Trend it on HMI
Free Allen Bradley PLC Ladder Logic Training Course
PLC Programming Example with Pushbutton and Motor
Mitsubishi PLC Counter Tutorial Using GX-Works2
Open Loop and Closed Loop System Questions
Instruction List in PLC Programming
What is an Instruction List? – PLC Programming
How Weigh Feeder Works
How Weigh Feeder Works ?
Loop Diagram
PLC based drilling machine
Drilling Process using PLC Program
Difference between Signal Cables and Control Cables
AC generator Voltage Regulators
AC Generator Voltage Regulators
Selection Guidelines for Cable Glands
Instrumentation Inspection and Quality Control Questions
PID-Controller-Simulator-graph
PID Controller Tunning Parameters Simulator
What is calibration?
Difference Between Clamp Meters and Digital Multimeters
Difference Between Clamp Meters and Multimeters
Furnace Draft Control System
VFD Torque Boosting
What is Torque Boosting in Variable Frequency Drive (VFD)?
