Reading: PLC Program to Control Gas Pressure using Closed-Loop
Inst Tools > Blog > PLC Tutorials > PLC Program to Control Gas Pressure using Closed-Loop
Last updated: March 4, 2021 3:24 pm
4 Comments
By using AC Drive and Closed-Loop Control Program in PLC, we have to control output gas pressure as per setpoint given in SCADA. Implement this program in PLC using Ladder Logic programming language.
PLC Program to Control Gas PressureProblem Solution:PLC Program:
Problem Solution:
  • To measure gas pressure, Pressure transmitter installed at input as well as output gas pipe line.
  • Range of pressure transmitter is 0-20kPa.
  • Output of this transmitter is in standard electrical signal which is 4-20 mA. Convert this signal into digital signal by connecting level transmitter to AI module of PLC.
  • Blower fan motor is controlled by AC Drive, so we can control the speed of the motor.
  • We can collect the motor rpm feedback and also give the set point to increase or decrease the speed of the motor as per output pressure transmitter feedback using PLC Program.
  • Motor speed feedback from AC Drive and Set point of Speed to AC Drive is in standard electrical signal 4-20 mA. Convert this signal into digital signal by connecting feedback to PLC AI module and set point from PLC AO module to AC Drive.
  • Range of Motor Speed is 3000 RPM.
  • Prepare a proper Closed-loop control logic to control output gas pressure.
PLC Program:
The below table shows different types of inputs and outputs used in the ladder logic.
PLC Closed Loop Inputs and Outputs
Here is the PLC program to control output gas pressure as per setpoint given in SCADA.
Ladder Logic to Convert Input Pressure Transmitter Signal
Ladder Logic to Convert Pressure Sensors into Digital Signal
Ladder Logic to Convert Speed Feedback from Drive
In the first three network, From Network 1 to Network 2 we are converting field signal 4-20 mA into digital signal (0–20 kPa), This is to show actual pressure in SCADA.
And in Network 3 is the conversion of Blower fan motor actual speed which is in 0-3000 rpm.
Ladder Logic to configure Analog Output
Network 4 and 5 does the comparison of Set Pressure, which is given from SCADA, and Output pipe line gas pressure. Based on this comparison it will give output to increase or decrease motor speed.
Ladder Logic for Square Pulse Timer
This Network 6 is the 1 sec square wave which we will use to increase or decrease the speed of motor by 100 rpm at every 1 sec.
Ladder Logic to Increase Speed in Drive
In this Network 7, we are doing the increment in speed of blower fan motor by 100 rpm at every 1 sec only if INCREASE_SPEED bit is high that means output pipe line pressure is low than Set Pressure in SCADA.
If the increment goes beyond the 3000 rpm then it will transfer the 3000 value to set_speed and stop incrementing further.
Ladder Logic to Decrease Speed in Drive
In this Network 8, we are doing the decrement in speed of blower fan motor by 100 rpm at every 1 sec only if DECREASE_SPEED bit is high that means output pipe line pressure is higher than Set Pressure in SCADA.
If the decrement goes below the 500 rpm then it will transfer the 500 value to set_speed and stop decrementing further.
PLC Analog Output to VFD
And lastly in this Network 9, we are converting digital speed into Analog Signal 4-20 mA. Then this signal is given to AC Drive to control the speed of blower fan motor.
Author : Hiral Patel
Troubleshoot Allen Bradley PLC
DeltaV System Configuration
Woodward Governor 505
Derivative Controller Theory
Current Loops Measurement
Push button Motor PLC Logic
PLC Program for Controlling a Water Pump with 3 Power Sources
PLC Programming for Garden Sprinkler System
Peripheral Inputs and Outputs in Siemens PLC
4 Comments
  • Suhel says:
    August 3, 2019 at 8:58 am
    Can anyone help me to know that what is that no. In hi limit and low limit like3.000000e and 003 in some rung????
  • Hiral Patel says:
    August 24, 2019 at 12:09 pm
    That is the high limit and low limit values in which you want to convert your analog output.
    Like for the unscale in Network 9, High limit value is 3000 and low limit value is 0. Now when you want to set your speed at 50% or 1500 rpm then your output should be at 50% or in terms of electrical signal(4 to 20 mA) we can say that it should be 12mA. So that VFD can understant that it have to set RPM at 50% or 1500 rpm.
  • Nelson says:
    December 29, 2021 at 4:33 pm
    Hello there,Sir what kind of communication used in this example ,how ac drive communicate to the plc i hope you reply thanks,
  • Nelson says:
    December 29, 2021 at 4:38 pm
    And also sir ,how you get the set speed feedback Piw260 in network 3 how is that
Glass Cutting and Polishing Machine: PLC Automation Solution
Programmable Logic Controller Maintenance Check Points
PLC based Gas Detection System using Ladder Logic Project
Motion Detection based Street Light: PLC Logic Solution
PLC Cooking Timer Example for Kitchen Automation
Latched and Momentary Operation of Motor PLC Program
What are High-Speed Inputs in PLC?
DRUM DB
Siemens Drum block for Sequencer Operation
What is Fail-safe in Siemens PLC?
Siemens Industrial Laptop (Simatic Field PG)
Connect to the Siemens S7 PLC
Control 3 Motors with Toggle Switch
PLC Ladder Logic Design: Control 3 Motors with Toggle Switch
Does Really a Safety Barrier is Important
Does Really a Safety Barrier is Important? – PLC DCS Systems
Modbus Poll and Modbus Slave
How to Use Modbus Poll and Modbus Slave Software?
PLC and MCC Panel Interface Design
Industrial Automation Cold and Hot Standby
Y Body Globe Valve
Globe Valve Body Design
DCS Quiz
DCS Quiz
CAN Protocol with the OSI Model
Basics for CAN Bus Protocol – Controller Area Network
Connect PLC with SCADA System via OPC UA
How to Connect PLC with SCADA System via OPC UA?
SIS PFD - Safety Instrumented System
SIS PFD – Safety Instrumented System
pH sensor calibration procedure
Robot Anatomy
Robot – Anatomy, Configuration, Reference Frame, Characteristics
Importance of Hysteresis Loop
