Reading: PLC Program for Water filling and Discharging Process
Inst Tools > Blog > Guest Articles > PLC Program for Water filling and Discharging Process
PLC ladder logic for water filling and discharging process. Learn the program description with an explanation and solution.
Last updated: November 3, 2023 10:37 am
Guest Articles PLC Tutorials
This is a PLC Program for the Water filling and discharging process using S7-1200 PLC.
Water filling and Discharging ProcessDiagramPLC SolutionPLC Inputs and OutputsPLC Water Filling and Discharging ProcessPLC Program ExplanationRuntime Test Cases
Problem Description
In many industries or plants, there are lots of manual water filling systems are used for water storage.
In the manual system, there are so many disadvantages such as Accuracy, time delay problems, loss of liquids, and Time consuming.
And due to the manual system, we have to arrange an operator for machine operation. Water wastage occurs due to manual system
Here we are discussing a semi-automatic system.
Diagram
PLC Solution
To solve this problem, we will use S7-1200 PLC for programming.
Here we use two sensors for level measurement, one is for High level and second is for low level.
We use feeding valve (MV1) for filling Cycle of the tank and discharge valve  (MV2) for discharging cycle of the tank. Both will be controlled according to sensor logic.
So when the water level goes below low level then feeding valve will turned ON automatically and when water level reaches high and the it senses by high level sensor, then discharging process will be turned ON automatically.
When high level is detected then buzzer will turn ON for alarm purpose. Cycle will stop if user will press stop button from the control panel.
Digital Inputs
  • Start PB: I0.0
  • Stop PB: I0.1
  • TLB 1: I0.3
  • TLB 2: I0.2
Digital Outputs
  • Cycle ON: Q0.0
  • Valve MV1 (Feed): Q0.1
  • Valve MV2 (Discharge): Q0.2
  • Agitator/Mixer M: Q0.3
  • Buzzer: Q0.4
PLC Filling Ladder Logic
  • For this application, we used S7-1200 PLC and TIA portal software for programming.
  • In Network 1 we used latching circuit for cycle ON (Q0.0) output. It can be started by pressing START PB (I0.0) and stop by pressing STOP PB (I0.1).
  • When cycle will be started then system will check level of the tank. If tank level is low then then feeding process will start and tank level is high then Discharge cycle will start.
  • Here we have taken NO contact for both sensors in the program for simplicity. It can be done by relay logic in field or you can use such type of sensors.
  • When tank will detect low level then TLB 2 (I0.2) will be activated and then feeding cycle will be ON. Here we have taken NC contact of TLB1 (I0.3) so when PLC will detect high level then it will stop Feeding cycle.
  • When tank will detect high level then TLB 1 (I0.3) will be activated and discharging cycle will be ON. Here we have taken NC contact of TLB2 (I0.2) so when PLC will detect low level then it will stop discharge cycle cycle.
  • Mixer M (Q0.3) should be ON during discharging cycle for mixing purpose.
  • Here we also considered an alarm for high level to inform operator. When TLB 1(I0.3) will be detected then buzzer (Q0.4) will be activated.
  • During all function, cycle should be ON.
Runtime Test Cases
PLC Water Filling Program
Note: The above PLC Logic provided for basic idea about application of PLC in Water filling and Discharging Process. The Logic is limited and not complete application.
Author: Bhavesh
  • Liquid Mixing PLC Logic
  • Siemens PLC Instructions
  • Safety Control System Basics
  • Instrumentation Control System
  • Encoder Multiple Choice Questions
Which Connection is Best for PLC? – Sinking or Sourcing
PLC Counter Instructions
How to Convert Voltage to Current using Resistor ?
Real-time PLC Projects – Industrial Automation
PID Block in RSLogix 500
  • k says:
    March 18, 2021 at 12:48 pm
    when TLB2 are in normal position then filling valve is operate and continue this will happen when level is below 0.1% to HI level.
Difference Between NO and NC Contacts
How to Use the Shift and Rotate Instructions in PLC?
PLC Motor Control Ladder Logic Programming
Difference Between Microcontroller and PLC
PLC Program for Automatic Parameter Initialization When Power UP
Water Fountain Control Logic – PLC Exercises and Solutions
Retrieve from memory card
How to Retrieve PLC Project From Memory Card?
Studio 5000 Programming Three Motors with Fixed Priorities
Studio 5000: Programming Three Motors with Fixed Priorities
PLC program to control pump
Troubleshooting PLC Permissive Inputs
PLC Logic - Control Spray Nozzle, Fans, and Puncher
SCADA in Cloud
Cloud-Based SCADA Projects – Try Free Demo Account
A typical wiring diagram from Field Transmitter to Control Room
How to Wire a Field instrument to Control Room with Example
Modbus in Industrial Networks
Twisted Pair Cable Noise Supression
Why We use Shielded Cable and Twisted Pair Cables ?
Functional Block Diagram of XNOR Logic Gate
PLC Functional Block Diagram for Logic Gates
RTD Accuracy
What is RTD Accuracy ?
Sample Raw DataSheet for Pressure Calibration
DC Machines Excitation Quiz
Thin Client in SCADA
What is Thin Client in SCADA? – Purpose, Advantages
Supermarket HVAC Ventilation System
Supermarket Ventilation System – HVAC Basics
