Reading: Heating and Mixing of Products using PLC Example Tutorial
Inst Tools > Blog > PLC Tutorials > Heating and Mixing of Products using PLC Example Tutorial
This is a PLC Program for automatic heating and mixing of products. Learn the PLC programming with this example for engineering students.
Last updated: November 3, 2023 11:56 am
9 Comments
Heating and Mixing of ProductsProblem DiagramProblem SolutionList of Inputs & OutputsPLC Program for heating and mixing of productProgram ExplainedResult
Problem Description
Make an automatic system in which two materials are collected in one tank. All materials are to be mixed till they achieve a predefined set point of temperature.
Make a ladder program in S7-1200 PLC for this application.
Problem Diagram
PLC Program for Automatic Heating and Mixing of Products
Problem Solution
We can solve this problem by using simple logic. For this system consider two separate level switches to detect the level of two different materials (Lets say Material A & Material B).
Also consider one level switch for empty level detection.
For controlling the level we can use single acting valve (fully open and fully close type).
For mixing, agitator is used and it is connected with motor shaft.
Heater and temperature sensor are installed inside the tank.
Here materials are mixed until it reaches the set point of temperature and after mixing, outlet valve (Q0.4) will be operated to drain the mixed products.
Inputs List
  • Cycle START :- I0.0
  • Cycle STOP :- I0.1
  • Level of material B :- I0.2
  • Level of material A :- I0.3
  • Empty level switch :- I0.4
  • Temperature sensor :- I0.5
Outputs List
  • Inlet valve 1 :- Q0.0
  • Inlet valve 2 :- Q0.1
  • Agitator motor :- Q0.2
  • Heater :- Q0.3
  • Outlet valve :- Q0.4
M Memory
  • M0.0 :- Cycle ON
PLC Heating
PLC Mixing
PLC Heating Materials
PLC Mixing Materials
Program Explained
In this problem, we will consider S7-1200 PLC and TIA portal software for programming.
Network 1:
This network shows simple latching circuit for cycle ON and cycle OFF. Normally Open (NO) contact of cycle START button (I0.0) and NC contact of cycle STOP button (I0.1) for cycle activation.
Network 2:
This network is to operate Inlet Valve 1(Q0.0). It is operated when Low Level of the tank is detected (I0.4). And it is closed when Level Material A is detected by a switch with address (I0.3). START PB (I0.0) also connected in parallel so if low level not detected, inlet valve can be started by pressing START PB (I0.0).
Network 3:
This network is to operate inlet valve 2 (Q0.2).It is operated when material A is filled with its desired level. When cycle is running and level of material A is detected, inlet valve 2 (Q0.1) will be ON.
Network 4:
This network is to operate agitator motor and heater. When tank is full with material A and material B, heater (Q0.3) and agitator motor (Q0.2) will be ON.
Network 5:
When entire mixing process and heating are completed, outlet valve (Q0.4) will be ON. NC contact of empty level switch (I0.4) is used to stop the outlet valve when tank is empty.
Note :- Above logic is for explanation of certain application only. The diagram is for representation purpose, actual system might be different form this system.
Result
Author: Bhavesh
  • PLC Star Delta Motor Starter
  • Thermostat Temperature Control
  • PLC Interposing Relay
  • Flow Totalizer using PLC
  • Burglar Alarm Security System
What is RS Linx? Types of Software in Rockwell Automation
CW and CCW Operation of Motor from Same Push button
Create an Application in HMI using Tia Portal
How-to do Security of SCADA Systems?
How to Configure PID in Siemens PLC?
9 Comments
  • Junaid says:
    July 17, 2018 at 7:29 pm
    Excellent informative
  • Ahmed says:
    July 24, 2018 at 9:23 am
    A level switch missing in Network 2
    • JPS says:
      August 5, 2018 at 8:08 am
      yes I notice it too, I thought it was part of the problem
  • Frankline says:
    August 10, 2018 at 6:41 pm
    I will like to get a copy
  • rajaram says:
    August 20, 2018 at 11:08 pm
    this one is a good logic . But a real time industrial logic will be very useful . and if the solutions will be using those blocks which are used by professional programmers than that will make my day . 🙂
    thanks to admin and publisher
  • Amir says:
    September 9, 2018 at 2:36 am
    Thanks for the example!
    But what will close Valve 1?
    Shouldn’t it close once Level Material A has been reached?
  • Manishkumar Prajapati says:
    October 5, 2019 at 3:43 pm
    The program has been written very good expect one thing. When tank is emptying and the level of the material goes down to the level material B sensor then the valve 2 will open right away same thing will happen with valve 1. To avoid this one you need to make a program in a way so when tank become full empty then and then it starts the whole process again. Just add NC contact of empty level sensor in network 2 and network 3.
    October 5, 2019 at 3:46 pm
    Yes, and you are missing level switch in network 2 as well. You can use either NC of outlet valve or NC of empty level sensor in network 2 and network 3.
    October 5, 2019 at 3:49 pm
    My apology, you can use only NC of outlet valve because if you use NC of empty level switch it will never turn on the valve B for the first cycle so you can use only NC of outlet valve.
Define the Order of Execution in Functional Block Diagram of Studio 5000
#13 PLC Best Practices – Disable Unused Communication Ports
PLC Programming Example on Timers Function Block
Troubleshooting PLC Permissive Inputs
Implement UDT in PLC Programming: User-Defined Data Type
FactoryTalk View Studio – Import and Export Tutorial
PLC 1 Push Button to Turn ON or OFF 1 Output
What is Siemens TDC - Siemens Control System
What is Siemens TDC? – Siemens Control System
PLC railway crossing program
Automatic Railway Crossing Gate Control PLC Program
PLC Software Redundancy
Software Redundancy in Siemens PLC – Hardware versus Software
PLC Counters Simulation
Example of Using a Counter in Omron PLC
Omron PLC increment and decrement
Increment & Decrement Instructions in CX-Programmer (OMRON)
Mixing Tank Relay Circuit
PLC Program for Mixing Tank
Open User Communication in Siemens Tia Portal - PLC to PLC
Open User Communication in Siemens Tia Portal – PLC to PLC
Comparison of Pressure Instruments - Industrial Instrumentation
Comparison of Pressure Instruments – Industrial Instrumentation
Electrical Resistance Temperature Curves of RTD
Resistance Temperature Detectors (RTD) Construction
Magnetic Float Level Switch Principle
Magnetic Float Level Switch Installation Techniques
controller integral wind-up
Limit Controls : High Limit & Low Limit Functions
SIS Fault Tolerance
SIS Hardware Fault Tolerance – Methods to Overcome HFT issues
Safety Questions and Answers
temperature compensation circuit for PMMC
PMMC Temperature Compensation
