Reading: pH Monitoring System Triggers an Alarm
Inst Tools > Blog > Analyzers > pH Monitoring System Triggers an Alarm
This pH monitoring system triggers an alarm if the pH value of the process water in the neutralization tank drifts past trip values.
Last updated: February 15, 2022 9:41 am
Analyzers Practical Questions
This pH monitoring system triggers an alarm if the pH value of the process water in the neutralization tank drifts past either of two thresholds (trip) values:
Answer the following questions about this pH alarm system:
1. If a wire breaks loose at TB56-4, creating an “open” fault in the loop circuit, determine what will happen at the alarm unit (AAH, AAL-41) and also where you would expect to measure voltage in the loop circuit and where you would expect to measure no voltage in the loop circuit.
2. If breaker #25 in panel L4 suddenly trips, what will happen in this system? Will an operator still be able to read the pH value of the water in the neutralization tank?
3. If a fire breaks out near the conduit through which cable 52 runs, causing the plastic insulation around the conductors of cable 52 to melt and consequently causing those conductors to short together, what will happen in this system?
Where would you expect to measure voltage in the loop circuit, and where would you expect to measure no voltage in the loop circuit?
Where would you expect to measure current in the loop circuit, and where would you expect to measure no current in the loop circuit?
4. Calculate the loop current value when the pH measures 6.8 inside the neutralization tank.
5. For those who have studied pH measurement, explain why pH “neutralization” is an important control process in the industry.
6. How can we tell from this diagram whether the 4-20 mA output of transmitter AIT-41 is active or passive (i.e. sourcing or sinking)?
Answers:
If a wire breaks loose at TB56-4, creating an “open” fault in the loop circuit, determine what will happen at the alarm unit (AAH, AAL-41) and also where you would expect to measure voltage in the loop circuit and where you would expect to measure no voltage in the loop circuit. The AAL would trip (but not the AAH), and we would expect to measure voltage between the wires of cable 52 but not between the wires of cable 30.
If a fire breaks out near the conduit through which cable 52 runs, causing the conductors inside cable 52 to short together, what will happen in this system? Where would you expect to measure voltage in the loop circuit, and where would you expect to measure no voltage in the loop circuit? Where would you expect to measure current in the loop circuit, and where would you expect to measure no current in the loop circuit?
The AAL would trip (but not the AAH), and we would expect to measure no voltage anywhere in the loop circuit. However, we would still have current at the terminals of the AIT-41 transmitter (although no current to the right of the short).
  • Pressure Actuated Questions
  • Which Instrument is at Fault?
  • PLC Pushbutton Switches
  • Identify Spool Valve Symbols
  • Analytical Process Control Question
Credits: Tony R. Kuphaldt
Ozone Analyzer Working Principle
Oxygen (O2) Measurement in Flue Gas
Programmable Logic Controller (PLC) Questions and Answers – 17
Stripper Overhead Temperature Control System
Mass Spectrometer Working Principle
Questions and Answers on Gas
Pneumatic Level Transmitter Value Struck?
Identify the Purpose of Flow Ratio Controller
Difference Between Absolute and Relative Humidity
Electronic Pressure Sensor with Bourdon Tube and LVDT
Hair Hydrometer Principle
Calculate the appropriate millivoltage values of a Thermocouple
Total Organic Carbon Analyzers Questions and Answers
burner management system P&ID
Solenoid Valves Questions & Answers – 1
Overhead Product Pressure Control Loop
PLC Circuit Answers
PLC connected to Three Pushbutton Switches
Motor ladder Logic
Foxboro pneumatic instruments
Pneumatic Force Balance Instrument
DP Transmitter Located 10 feet Beneath the Vessel
Two pressure switches
Identify Two Pressure Switches Logic
Allen-Bradley MicroLogix PLC Wiring
Programmable Logic Controller (PLC) Questions and Answers – 8
Advantages and Disadvantages of Network Topologies
Advanced PLC Programming Training Course
Thermocouple Types
Types of Thermocouples
Instrumentation in Industries
Why is Instrumentation used in Industries?
Electrical Machines MCQ Series 11
How to Measure Specific Gravity of Battery
Calculate Total Hydrostatic Pressure at Bottom of Vessel
PLC Automation Memory
What is NOR Flash Memory in PLC?
