Reading: Orifice Plate Tapping – Orifice Plate Taps
Inst Tools > Blog > Flow Measurement > Orifice Plate Tapping – Orifice Plate Taps
Different types of Orifice plate Taps are Flange Taps, Corner Taps, Vena contracta taps. This article provides information on Orifice Tapping Location.
Last updated: November 2, 2023 6:02 am
Flow Measurement
2 Comments
9 Min Read
Several standards exist for orifice pressure tap locations. Ideally, the upstream pressure tap will detect fluid pressure at a point of minimum velocity, and the downstream tap will detect pressure at the vena contracta (maximum velocity).
Orifice Plate TappingOrifice Tap LocationFlange TapsVena contracta tapsCorner tapsOrifice Plate TapsOrifice Plate with Flange TapsIntegral orifice plate
In reality, this ideal is never perfectly achieved.
An overview of the most popular tap locations for orifice plates is shown in the following illustration:
Orifice Taps
Orifice Tapping Point
Flange Taps
Flange taps are the most popular tap location for orifice meter runs on large pipes in the United States.
Flanges may be manufactured with tap holes pre-drilled and finished before the flange is even welded to the pipe, making this a very convenient pressure tap configuration.
Most of the other tap configurations require drilling into the pipe after installation, which is not only labor-intensive, but may possibly weaken the pipe at the locations of the tap holes.
Vena contracta taps
Vena contracta taps offer the greatest differential pressure for any given flow rate, but require precise calculations to properly locate the downstream tap position.
Radius taps are an approximation of vena contracta taps for large pipe sizes (one-half pipe diameter downstream for the low-pressure tap location).
An unfortunate characteristic of both these taps is the requirement of drilling through the pipe wall.
Not only does this weaken the pipe, but the practical necessity of drilling the tap holes in the installed location rather than in a controlled manufacturing environment means there is considerable room for installation error.
Corner taps
Corner taps must be used on small pipe diameters where the vena contracta is so close to the downstream face of the orifice plate that a downstream flange tap would sense pressure in the highly turbulent region (too far downstream).
Corner taps obviously require special (i.e. expensive) flange fittings, which is why they tend to be used only when necessary.
Care should be taken to avoid measuring downstream pressure in the highly turbulent region following the vena contracta. This is why the pipe tap (also known as full-flow tap) standard calls for a downstream tap location eight pipe diameters away from the orifice: to give the flow stream room to stabilize for more consistent pressure readings.
Wherever the taps are located, it is vitally important that the tap holes be completely flush with the inside wall of the pipe or flange.
Even the smallest recess or burr left from drilling will cause measurement errors, which is why tap holes are best drilled in a controlled manufacturing environment rather that at the installation site where the task will likely be performed by nonexperts.
Orifice Plate Taps
A photograph of an orifice plate used to measure the flow of natural gas to a large turbine engine is shown here, with a Rosemount model 3051 differential pressure transmitter sensing the pressure drop generated by the orifice:
Orifice Flow Transmitter
Flange taps are used in this orifice installation, with the taps and pressure transmitter located above the pipe center-line to avoid picking up any liquid droplets that may pass through the pipe.
The direction of gas flow in this particular installation is from left to right, making the left-hand pressure tap the “high pressure” side and the right-hand pressure tap the “low pressure” side.
As you can see by the pressure gauge’s indication in the photograph, the static line pressure of the natural gas inside the pipe is over 300 PSI. The amount of pressure drop generated by the orifice plate at full flow, however, is likely only a few PSI (100 inches water column is typical for many orifice plate installations).
This is why we must use a differential pressure transmitter to measure the orifice plate’s pressure drop: only a DP transmitter will sense the difference in pressure across the orifice while rejecting the static (common-mode) line pressure inside the pipe.
A photograph of another orifice plate with flange taps appears here, shown on a vertical pipe. In this example, the pipe and flanges are formed of acrylic (transparent plastic):
Differential Pressure based Flow Transmitter
As is customary with orifice plates mounted in vertical pipes, the direction of flow is upward (from bottom to top), making the bottom tap the “high pressure” side and the top tap the “low pressure” side.
Since this is a liquid application, the transmitter is located below (Note) the taps in order to avoid collecting bubbles of air or other gases in the impulse lines.
Note : One installation error seen in this photograph is a green plastic impulse tube with a bend extending above the upper flange tap. Any elevated portion of the impulse tube system will tend to collect gas bubbles over time, possibly causing measurement errors.
A better installation would ensure the impulse tubes never extend above the flange tap they connect to on the liquid-bearing pipe.
This particular orifice and flow transmitter (Rosemount model 1151) is used on a process “trainer” unit at Brazosport College in Lake Jackson, Texas.
The transparent flanges, pipes, and process vessels make it easier for students to visualize the fluid motion.
For relatively low flow rates, an alternative arrangement is the integral orifice plate. This is where a small orifice plate directly attaches to the differential pressure-sensing element, eliminating the need for impulse lines.
A photograph of an integral orifice plate and transmitter is shown here, in an application measuring the flow of purified oxygen gas through a copper pipe:
Even smaller integral orifices exist for the measurement of very low flow rates, another type of integral orifice is available. This style uses the pass-through nature of a typical differential pressure transmitter’s capsule flanges to advantage.
Note the paths of fluid flow, as well as the unusual orientation of the three-valve manifold, in these two example illustrations:
integral orifice assembly
In both examples, the third hand valve serves the purpose of bypassing process fluid flow rather than equalizing both ports of the differential pressure transmitter.
Process fluid actually flows through at least one chamber of the DP transmitter’s body. Clearly, this kind of integral orifice plate is practical only for very low rates of flow, typically where the process flow line is no larger than the size of the pressure ports on the transmitter’s body.
The task of properly sizing an orifice plate for any given application is complex enough to recommend the use of special orifice sizing computer software provided by orifice plate manufacturers.
There are a number of factors to consider in orifice plate sizing, and these software packages account for all of them. Best of all, the software provided by manufacturers is often linked to data for that manufacturer’s product line, helping to assure installed results in close agreement with predictions.
Credits: Tony R. Kuphaldt – Creative Commons Attribution 4.0 License
  • Facts About Orifice Flow Meters
  • Compensation for Orifice Meters
  • Flow Transmitters Questions
  • Segmental Wedge Flow Meter
  • Flow Directly Proportional to ΔP
Laminar Flow Meter Working Principle
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
What is Differential Pressure and Pressure Loss?
Why Flow is Directly Proportional to the Square Root of DP?
2 Comments
  • Indrajeet Jadav says:
    January 12, 2018 at 2:31 pm
    Respected sir,
    Please give basic course of Instrument technician level 1
  • Ranjeet Kumar says:
    August 12, 2018 at 8:22 pm
    Dear Sir,
    please give basics of various types of online Gas Chromatographs, processing etc. including various types of detectors in it.
Step by Step Guide for Gas Flow Meter Calibration
Open Channel Flow Measurement Principle
What is Differential Pressure Flow Meter?
Flow Switch : What is it? – Applications
Impulse Line – Purpose & Tapping Point Location
Ultrasonic Flow Meters Working Principle
Factors Affecting the Performance of Ultrasonic Flow Meters
Integral Orifice Parts
What is Integral Flow Orifice Assembly?
Ultrasonic Flow meters Working Animation
Ultrasonic Flow Meters Animation
Electro Magnetic Flow Meter Animation
Weir Flow Meter Principle
Measure Flow rate using Level Sensors
Spring Loaded Variable Area Flowmeter Working Principle
Spring Loaded Variable Area Flow Meter Working Principle
Coriolis mass flowmeter Density Measurement
How Coriolis Mass Flow Meter Measure Density?
Dall Tube Flow Meter Working Principle
Dall Tube Flow Meter – Principle, Advantages, Disadvantages
multiphase-flowmeter-working-principle
What are Multiphase Flow Meters? – Working Principle, Advantages
Anti-static Wrist Straps
Absorber in absorption chiller
What is an Absorption Chiller? – Working Principle
Questions and Answers on Motors and Generators
HT Motor Problem appears after Disassembly and Reassembly
Types of Pneumatic Valves
Types of Pneumatic Valves : Poppet & Spool
Types of Electrical Loads
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
Two-Liquid Manometer Principle
Electric Motor Animation
Electric Motor Working Animation
