Nuclear Power Plant Multiple Choice Questions
Here we shared the basic nuclear power plant multiple choice questions and answers (MCQ).
1. The efficiency of a nuclear power plant in comparison to a conventional thermal power plant is
(a) same
(b) more
(c) less
(d) may be less or mote depending on size
(e) unpredictable
Ans: c
2. Isotopes of same elements have
(a) same atomic number and different masses
(b) same chemical properties but different atomic numbers
(c) different masses and different atomic numbers
(d) different chemical properties and same atomic numbers
(e) same chemical properties and same atomic numbers
Ans: b
3. Atomic number of an element in the periodic table represents the numbers of
(a) protons in the nucleus
(b) electrons in me nucleus
(c) neutrons in the nucleus
(d) electrons in the atom
(e) neutrons in the atom
Ans: a
4. The mass number of a substance represents the sum of total number of
(a) protons and neutrons in an atom
(b) protons and electrons in an atom
(c) neutrons and electrons in an atom
(d) protons and neutrons in a nucleus
(e) protons and electrons in a nucleus
Ans: d
5. Which is not identical for an atom and an isotope
(a) mass number
(b) atomic number
(c) chemical properties
(d) position in periodic table
(e) all of the above
Ans: a
6. Amongst the following, the fissionable materials are
(a) U233andPu239
(b) U23iandPu233
(c) U235andPu235
(d) U238andPu239
(e) U243andPu235
Ans: a
6. A nuclear unit becoming critical means
(a) it is generating power to rated capacity
(b) it is capable of generating much more than rated capacity
(c) there is danger of nuclear spread
(d) chain reaction that causes automatic splitting of the fuel nuclei has been established
(e) it generates no heat
Ans: d
7. Moderator in nuclear plants is used to
(a) reduce temperature
(b) extract heat from nuclear reaction
(c) control the reaction
(d) cause collision with the fast moving neutrons to reduce their speed
(e) moderate the radioactive pollution
Ans: d
8. The most commonly used moderator in nuclear plants is
(a) heavy water
(b) concrete and bricks
(c) graphite and concrete
(d) deuterium
(e) graphite
Ans: e
9. The nuclear energy is measured as
(a) MeV
(b) curie
(c) farads
(d) MW
(e) kWhr
Ans: a
10. The total energy released in fission of U is
(a) 5 MeV
(b) 10 MeV
(c) 199 MeV
(d) 168 MeV
(e) 11 MeV
Ans: c
11. Breeder reactor has a conversion ratio of
(a) unity
(b) more than unity
(c) less than unity
(d) zero
(e) infinity
Ans: b
12. Boiling water reactor employs
(a) boiler
(b) direct cycle of coolant system
(c) double circuit system of coolant cycle
(d) multi pass system
(e) single circuit system
Ans: b
13. Fast breeder reactor uses
(a) boiler
Ans: c
14. One gram of uranium will produce energy equivalent to approximately
(a) 1 tonne of high grade coal
(b) 4.5 tonnes of high grade coal
(c) 10 tonnes of high grade coal
(d) 100 tonnes of high grade coal
(e) 1000 tonnes of high grade coal
Ans: b
15. Which of the following nuclear reactor does not need a heat exchanger for generation of steam
(a) gas cooled
(b) liquid metal cooled
(c) pressurised water
(d) boiling water
(e) none of the above
Ans: d
16. The number of isotopes of hydrogen are
(a) 1
(b) 2
(c) U
(c) 3
(e) 0
Ans: c
17. The commonly used material for shielding is
(a) lead or concrete
(b) lead and tin
(c) graphite or cadmium
(d) thick galvanized sheets
(e) black carbon papers
Ans: a
18. The main interest of shielding in nuclear reactor is protection against
(a) X-rays
(b) infra-red rays
(c) a, P, and y rays
(d) neutrons and gamma rays
(e) electrons
Ans: d
19. Reflector in nuclear plants is used to
(a) return the neutrons back into the core
(b) shield the radioactivity completely
(c) check polllution
(d) conserve energy
(e) is not used
Ans: a
20. The energy required to be applied to a radioactive nucleus for the emission of a neutron is
(a) 1 MeV
(b) 2.4 MeV
(c) 4.3 MeV
(d) 7.8 MeV
(e) 20 MeV
Ans: d
21. Which of the following are ferrite materials
(a) U233andPu239
(b) U
(c) U238andPu239
(d) U238andTh239
Ans: b
22. Ferrite material is
(a) the most fissionable material
(b) the basic fuel for nuclear paints
(c) basic raw material for nuclear plants
(d) the material which absorbs neutrons and undergoes spontaneous changes leading to the formation of fissionable material
Ans: d
23. Enriched uranium is one in which
(a) %age of U235 has been artificially in-creased
(b) %age of U has been artificially in¬creased
(c) %age of U234 has been artificially in-creased
(d) extra energy is pumped from outside
(e) all impurities have been removed
Ans: a
24. Which of the following particles is the lightest
(a) nucleus
(b) electron
(c) proton
(d) meson
(e) neutron
Ans: b
25. Which of the following is the heaviest
(a) neutron
(b) proton
(c) atom
(d) electron
(e) nucleus
Ans: c
26. In fast breeder reactors
(a) any type of moderator can be used
(b) graphite is used as the moderator
(c) heavy water is used as the moderator
(d) moderator may or may not be used
(e) moderator is dispensed with
Ans: e
27. In nuclear fission each neutron that causes fission releases
(a) no new neutron
(b) at least one new neutron
(c) one new neutron
(d) more than one new neutrons
(e) many-fold neutrons
Ans: d
28. The breeding gain in case of thermal breeder reactor as compared to fast breeder reactor is
(a) same
(b) lower
(c) higher
(d) unity
(e) higher/lower depending on the size of reactor
Ans: b
29. Gas cooled reactor uses following materials as moderator, and coolant
(a) graphite, C02
(b) graphite, air
(c) heavy water, C02
(d) lead, H2
(e) concrete, N2
Ans: a
30. A nuclear fission produces energy of following order in MeV
(a) 20
(b) 200
(c) 2000
(d) 20,000
(e) 2 x 105
Ans: b
31. The process by which a heavy nucleus is splitted into two light nuclei is known as
(a) splitting
(b) fission
(c) fusion
(d) disintegration
(e) chain reaction
Ans: b
32. A nuclear fission is initiated when the critical energy as compared to neutron binding energy of the atoms is
(a) same
(b) more
(c) less
(d) there is no such criterion
Ans: b
33. The fast breeder reactor uses the following moderator
(a) demineralised water
(b) carbon dioxide
(c) heavy water
(d) graphite
(e) no moderator is used
Ans: e
34. The first unclear power plant in India is located at
(a) Kota
(b) Kalapakkam
(c) Tarapur
(d) Baraeilly
(e) Kerala
Ans: c
35. The nuclear power plant at Tarapur has the following reactor
(a) fast breeder
(b) pressurised water
(c) boiling water
(d) sodium graphite
Ans: c
35. Boiling water reactor uses the following as moderator, coolant and working fluid
(a) ordinary fluid
(b) heavy water
(c) molten lead
(d) hydrogen gas
Ans: a
36. Ideally the neutron flux in reactor should be
(a) maximum in centre and zero at side
(b) maximum at side and zero in centre
(c) uniform throughout
(d) zero throughout
Ans: c
37. Enriched uranium may contain fissionable contents of the order of
(a) 1-99%
(b) 1-25%
(c) 1-50%
(d) 1-75%
(e) 1-90%
Ans: a
38. U235 will undergo fission by
(a) high energy (fast) neutrons alone
(b) low energy (slow) neutrons alone
(c) either fast or slow neutrons
(d) medium energy neutrons
Ans: c
39. U238 will undergo fission by
Ans: a
40. A reactor capable of converting a ferrite material into fissile isotopes is called
(a) regenerative reactor
(b) fast breeder reactor
(c) breeder reactor
(d) boiling water reactor
(e) ferrite reactor
Ans: a
41. Hydrogen is preferred as better coolant in comparison to C02 because former
(a) is lighter
(b) is inert
(c) has high specific heat
(d) is a good conductor
Ans: c
42. Natural uranium is made up of
(a) 99.282% U238, 0.712% U235, 0.006% U234
(b) 99.282% U235, 0.712% U238, 0.06%’ U234
(c) 99.282% U234, 0.712% U238, 0.006% U235
(d) 99.282% U235, 0.712% U234, 0.006% U238
Ans: a
43. The risk of radioactive hazard is greatest in the turbine with following reactor
(a) pressurized water
(b) boiling water
(c) gas cooled
(d) liquid metal cooled
Ans: b
44. Plutonium is produced
(a) as basic raw material
(b) by neutron irradiation of Uz
(c) by neutron irradiation of thorium
(d) artificially
(e) in high capacity furnace
Ans: b
45. Electron-volt is the unit of
(a) atomic power
(b) energy
(c) voltage
(d) radio activity
(e) there is no such unit
Ans: b
46. Pick up the wrong statement
(a) In a heterogeneous or solid-fuel reactor, the fuel is mixed in a regular pattern within moderator.
(b) Slow or thermal neutrons have energy of the order or 0.025 eV
(c) Fast neutrons have energies above 1000 eV
(d) Fast reactor uses moderator
(e) Most serious drawback in using water as coolant in nuclear plants is its high vapor pressure.
Ans: d
47. The unit of radio-activity is
(a) electron-volt
(b) electron-ampere
(c) curie
(d) MeV
(e) AMU
Ans: c
48. Pick up the wrong statement Fast breeder reactors
(a) operate at extremely high power densities.
(b) are liquid-metal cooled
(c) produce more fuel than they consume
(d) are unmoderated
(e) use water as coolant
Ans: e
49. Uranium-233 is produced
(d) artificially
(e) in high capacity furnaces
Ans: c
50. Plutonium-239 is produced
(b) by neutron irradiation of IT
(d) artificially
Ans: b
Also Read : Power Plant Interview Questions
51. Which of the following type of pump is used in liquid metal cooled reactor for circulation of liquid metal
(a) centrifugal
(b) axial
(c) reciprocation
(d) electromagnetic
(e) diaphragm
Ans: d
52. Which of the following is the primary fuel
(a) Ulii
(b) U
(c) U238
(d) Pu:
(e) Pu
Ans: b
53. Which of the following is secondary fuel
(a) Th232andU238
(b) U233andPu239
(c) U233andPu238
Ans: c
54. A pressurized water reactor employs pressurizer for the following application
(a) to maintain constant pressure in primary circuit under varying load
(b) to Supply high pressure steam
(c) to increase pressure of water in primary circuit
(d) to provide subcooled water at high pressure
Ans: a
55. Which of the following can be used as a coolant in nuclear plant
(a) light or heavy water
(b) molten lead
(c) carbon dioxide
(d) freon
(e) carbon tetrachloride
Ans: a
56. Reactors for propulsion applications use
(a) natural uranium
(b) molten lead
(c) any form of uranium
(d) thorium
(e) plutonium
Ans: b
57. The function of control rods in nuclear plants is to
(a) control temperature
(b) control radioactive pollution
(c) control absorption of neutron
(d) control fuel consumption
Ans: c
58. Breeder reactors employ liquid metal coolant because it
(a) acts as good moderator
(b) produces maximum steam
(c) transfers heat from core at a fast rate
(d) breeds neutrons
(e) increases rate of reaction in core
Ans: c
59. In triggering fission, which type of neutrons are more effective
(a) fast
(b) slow
(c) in bulk
(d) static
(e) activated
Ans: b
60. For economical operation of a nuclear plant
(a) used fuel should be reprocessed
(b) moderator should be used
(c) coolant should be employed
(d) control rods should be used
(e) reflector should be used
Ans: a
61. The size of the reactor is said to be critical when
(a) chain reaction can be initiated
(b) it becomes uncontrollable
(c) it explodes
(d) it produces no power
(e) it produces tremendous power
Ans: a
62. When a reactor becomes critical, then the production of neutrons is
(a) infinite
(b) zero
(c) exactly balanced by the loss of neutrons through leakage
(d) initiated
(e) stopped
Ans: c
63. In the breeder reactors the generation of new fissionable atom is
(a) at the lower rate than the consumption
(b) at a higher rate than the constuption
(c) at an equal rate of the consumption
(d) depends on other considerations
(e) unpredictable
Ans: b
64. The energy produced by a thermal reactor of same size as a breeder reactor is
(a) almost same
(b) slightly more
(c) slightly less
(d) much less
(e) much more
Ans: d
65. Reactors designed for propulsion applications are designed for
(a) natural uranium
(b) enriched uranium
(c) pure uranium
(d) any type of uranium
Ans: b
66. Superheated steam is generated in following reactor
(a) boiling water
(b) gas cooled
(c) pressurized water
(d) all of the above
Ans: b
67. Solid- fuel for nuclear reactions may be fabricated into various small shapes such as
(a) plates
(b) pallets
(c) pins
(d) any one of the above
Ans: d
68. Which of the following is more appropriate for a moderator. One which
(a) does not absorb neutrons
(b) absorbs neutrons
(c) accelerates neutrons
(d) eats up neutrons
(e) regenerates neutrons
Ans: a
69. A fission chain reaction in uranium can be developed by
(a) slowing down fast neutrons so that Uz fission continues by slow motion neutrons
(b) accelerating fast neutrons
(c) absorbing all neutrons
(d) using moderator
(e) enriching U235
Ans: a
70. In triggering fission, the following types of neutrons are desirable
(a) fast moving
(b) slow moving
(c) critical neutrons
(d) neutrons at rest
Ans: b
71. Effective moderators are those materials which contain
(a) light weight atoms
(b) heavy weight atoms
(c) critical atoms
(d) zero weight atoms
(e) there is no such criterion
Ans: a
72. In a fission process, maximum %age of energy is released as
(a) kinetic energy of neutrons
(b) kinetic energy of fission products
(c) instantaneous release of gamma rays
(d) gradual radioactive decay of fission products
Ans: b
73. The following present serious difficulty in designing reactor shield
(a) alpha particles
(b) beta particles
(c) thermal neutrons
(d) fast neutrons and gamma rays
Ans: d
74. In nuclear fission
(a) the original elements change into completely different elements
(b) the electrons of the element change
(c) the molecules rearrange themselves to form other molecules
(d) none of the above
Ans: a
75. In order to have constant claim reaction to produce a constant rate of heat output, the value of ratio of the number of neutrons in one generation to the number of neutrons in the immediately preceding generation must be
(a) greater than 1.0
(b) less than 1.0
(c) equal to zero
(c) equal to 1.0
(e) equal to infinity
Ans: d
75. Each fission of U235 produces following number of fast neutrons per fission
(a) 1 neutron
(b) 1 neutrons
(c) 1 2 neutrons
(d) 2 neutrons
(e) infinite
Ans: d
76. A fast breeder reactor uses following as fuel
(a) enriched uranium
(b) plutonium
(c) thorium
(d) U235
(e) natural uranium
Ans: d
77. A boiling water reactor uses following as fuel
(b) plutonium
(c) thorium
(d) U
(e) natural uranium
Ans: a
78. A fast breeder reactor
(a) uses graphite rods as moderator
(b) has powerful moderator
(c) has no moderator
(d) uses ferrite material as moderator
(e) uses pressurized water as moderator
Ans: c
79. Artificial radioactive isotopes find application in
(a) power generation
(b) nucleonic devices
(c) nuclear fission
(d) nuclear fusion
(e) medical field
Ans: e
80. A fast breeder reactor uses
(a) 90% U-235
(b) U-238
(c) U-235
(d) Pu-239
(e) U-239
Ans: a
81. Half life of a radioactive isotope corresponds to the time required for half of the following to decay
(a) electrons
(b) protons
(c) neutrons
(d) nulceus
(e) atom
Ans: e
82. Pressurized water reactor is designed
(a) for boiling pi water in the core
(b) to use liquid sodium metal as coolant
(c) to use intermediate coolant
(d) to prevent the water coolant from boiling in the core
(e) to eliminate the coolant loop of the pressurized water
Ans: d
83. The coolant used in boiling water reactor is
(a) C02
(b) pressurized water
(c) mixture of water and steam
(d) liquid metal
(e) mercury
Ans: c
84. In boiling water reactor, moderator is
(a) coolant itself
(b) ferrite rod
(c) graphite rod
(d) liquid sodium metal
(e) blanket of thorium
Ans: a
85. The most practical fuel for a thermonuclear reactor, both from economical and nuclear consideration is
(a) plutonium
(b) uranium
(c) deuterium
(d) thorium
(e) lithium
Ans: c
86. The efficiency of a nuclear power plant in comparison to conventional and nuclear consideration is
(a) higher cost of nuclear fuel
(b) high initial cost
(c) high heat rejection in condenser
(d) lower temperature and pressure conditions
(e) nuclear hazard risk
Ans: d
87. The presence of reflector in nuclear power plants results in
(a) increased production of neutrons
(b) complete absorption of neutrons
(c) controlled production of neutrons
(d) decreased leakage of neutrons
(e) decrease of speed of neutrons
Ans: d
88. The fuel needed, with reflector in nuclear power plant, in order to generate sufficient neutrons to sustain a chain reaction, would be
(a) more
(b) less
(c) same
(d) zero
(e) negative, i.e. fuel would be generated
Ans: b
3 thoughts on “Nuclear Power Plant Multiple Choice Questions”
  1. Please send the catalogue for all Instruments like a level , flow temperature & pressure for all application.
    I am waiting for your positive reply.
    regards
  2. Hi,
    The reported answer to the question NO. 85 is wrong, deuterium(hydrogen isotope) is a component of heavy water used as moderator and not a fuel.
