Reading: What is a Network Connector? – Types of Connectors
Inst Tools > Blog > Communication > What is a Network Connector? – Types of Connectors
A network connector is a device that links different network segments or devices, enabling data transmission across the network.
Last updated: July 9, 2024 10:30 am
Communication Control Systems
8 Min Read
In networking, there are different types of connectors used for connecting to a network port. All the devices, ranging from computers to optical fiber systems to large servers will have different types of ports. This gives flexibility in connecting cables and also, and each connector has its own pros and cons. So, you get a large variety for choosing the best one for your network.
What is a Network Connector?Types of Network ConnectorsRJ45UTP couplerRJ-11 connectorBNC connectorF-Type connectorDB-9 (RS232) connectorUSB connectorSC connectorST connectorMTRJ connector
A network connector is a device that links different network segments or devices and provides data transmission across the network. Some examples include Ethernet connectors, fiber optic connectors, and wireless adapters.
In your PC, you must have seen Ethernet ports for connecting a LAN cable to it. This port is nothing but a network connector. A network connector can be simply said as a physical interface for connecting a network cable to a network device. Network connectors come in various shapes and designs to enable efficient signal transmission.
Network connectors come in majorly two types – male and female.
Male connectors are jacks and plugs, and female connectors are sockets and ports. The PC example that we explained earlier is a female one, and the LAN cable which will be connected to it is a male one. The connectors vary depending upon the type of network and the cable it is attached to.
The main types of network connectors are listed below.
  1. RJ45
  2. UTP coupler
  3. RJ-11 connector
  4. BNC connector
  5. F-Type connector
  6. DB-9 (RS232) connector
  7. USB connector
  8. SC connector
  9. ST connector
  10. MTRJ connector
RJ45
The RJ45 is by far the most used connector in networks. Refer to the below image. RJ45 consists of an 8-pin metal connector which is then connected to a twisted unshielded cable by means of crimping.
RJ45 has a metal lock as can be seen in the image for locking with the female RJ45 connector in devices. This makes the connector safe for operation and is also very reliable. It is generally made of plastic material.
RJ45 Connector
UTP coupler
UTP stands for unshielded twisted pair. Refer to the below image. UTP coupler is used in cases when the Ethernet cable is too short to run.
In the UTP connector, there are 2 RJ45 female connectors coupled in one assembly with each other. Connect two RJ45 male connector cables to it and you have an extended Ethernet line for the same.
UTP Coupler
RJ-11 connector
The RJ-11 connector looks similar to the RJ45 connector, but it has only 4 pins. Refer to the below image. RJ-11 is small in size and uses the same material as RJ45 for its making.
RJ11 is used extensively for telephonic network connections and is not used for large-scale PC network systems.
RJ-11 connector
BNC connector
BNC stands for Bayonet Neill-Concelman. BNC connector is a traditional coaxial cable connector. You can find it in your TV set-up box. Refer to the below image.
BNC connector is mostly used for video and audio network transmissions, whereas coaxial cables are used for their high resistance to electromagnetic interference noise. They are an older technology as compared to other high-speed video and audio connectors, which use optical fiber and Ethernet protocols.
BNC connector
F-Type connector
The F-type connector is another type of connector used for coaxial cables. The F-type connector is smaller in size as compared to BNC connectors. It is threaded in its connection. Refer to the below image.
The F-type connectors are generally used in cable modems, dish TV, satellite internet, and CCTV cameras.
F-Type connector
The DB9 is a serial-type connector, used only for serial line communication. Refer to the below image. It is specifically designed for the RS232 protocol.
A serial line is only preferred for shorter distances, but then it provides a high speed of transmission with high resistance to noise. The RS232 connector is used mostly in printers. It has 9 pins and comes in both male and female versions.
USB connector
The USB connector is the most famous type of connector in the world. The USB is used in almost every device, be it a small pen drive or a complex PLC programming port.
The USB is also used in networking as a network USB dongle. Refer to the below image.
USB connector
One main advantage of USB is that it is available in versatile versions, like USB to RJ45, USB to DB232, etc. It means one side will be USB and the other will be a different version. This makes it useful for many applications.
computer connectors
Various computer connectors
SC connector
The SC connector is also called as standard or square connector. It comes under an optical fiber connection. Refer to the below image.
The SC connector is a push-pull type. But there are chances sometimes that the latch becomes loose. This makes it a less favorable option for optical fiber connection.
SC connector
ST connector
The ST connector is called a straight-tip connector. The ST connector comes under an optical fiber connection. Refer to the below image.
The ST connector is a metallic locking assembly, which makes it a robust connection type. This connector is the most used one for optical fiber connections.
An ST connector connects to a terminating device by pushing the connector into the terminating equipment and then twisting the connector housing to lock it in place.
ST connector
MTRJ connector
MRTJ stands for mechanical transfer register jack. The MTRJ connector is an extension of the SC connector. Removing the demerits of only push-pull, it comes with a latch on the top as shown in the figure below.
This makes it a very reliable option for use. It is also a tough competitor to ST connector due to this simple advantage and easy-to-use technology.
MTRJ connector
  • Fiber Optic Cable Testing
  • How to make an RJ45 cable?
  • Fiber Optic Cable Routing and Safety
  • PLC Ladder Logic Motor with Toggle Switch
  • Why were many PLC Languages Developed?
Configuration of PlantPAx Library in Factory Talk Studio
PID Controller Selection
Types of Control Systems
How Valve Positioners act as Cascade Control Systems in a Loop?
RS485 Serial Communication
Distributed Control System Interview Questions
Process Control Instrumentation
Ziegler-Nichols Closed-Loop Method (Ultimate Gain)
What is Instrument Hook Up Diagram ?
Instrumentation Cyber Security Glossary
7 OSI Layers of Communications
OPC-OLE-for-Process-Control
What is OPC ?
Basic Control Systems Questions
14 Basic Control Systems Questions for Interview Preparation
Control Loops
Fieldbus and Profibus
Difference between Fieldbus and Profibus
Junction Box Wiring
4-20mA Junction Box versus Fieldbus (FF) Junction Box
Voting System in PLC
Voting Concept in Package Safety System
Simulating Level Sensor and the Pump Logic in PLC
PLC Basics – Manual Control, Closed Loop, ON-OFF with Hysteresis
Flow Switch Symbol
Principle of Flow Switch
Side Mounting Float Switch Working Principle
Fixed Gas Detectors vs. Portable Gas Detectors
Derivation-of-Ohms-Law
Basics of Ohm’s Law
Programmable Logic Controller (PLC) Questions and Answers – 1
Relay Motor Logic Circuit
Motor Control Circuits
Measuring Circuit Voltage
Voltmeters
