Reading: What is Motor Jogging ?
Inst Tools > Blog > PLC Tutorials > What is Motor Jogging ?
Last updated: March 4, 2021 3:31 pm
3 Min Read
Jogging refers to repeated starting and stopping of a motor in short bursts to perform a particular movement such as moving a crane to a particular location. The motor is operated on full power.
Jogging and InchingJogging OperationJogging Operation in AC motorApplication or Purpose of jogging a motor
Jogging is moving the motor in small increments.
Inching is similar to Jogging and the two are often confused with each other. Inching involves short thrusts of motion at reduced power. The motor is made to run at a reduced voltage.
Jogging and Inching
The definition of jogging or inching as described by NEMA is “the quickly repeated closure of a circuit to start a motor from rest for the purpose of accomplishing small movements of the driven machine.”
The term jogging actually means to start a motor with short jabs of power at full voltage. The term inching means to start a motor with short jabs of power at reduced voltage.
Although the two terms mean different things, they are often used interchangeably because both are accomplished by preventing the holding contacts from sealing the circuit.
Jogging Operation
Jogging should not be done more than 5 times in a minute. This is because jogging can cause the motor to overheat.
If Jogging is to be done frequently, the starter of the motor should be derated.
Can be operated by using a Simple Push Button, or a Control Relay, or a Selector Switch
Repeated starts and/or jogs of induction motors generally reduce the life of the motor winding insulation. A much greater amount of heat is produced by each acceleration or jog than by the same motor under full load.
The purpose of jogging a motor is to align some other part of a machine or to slowing advance a machine through its sequence of operation. This is usually done during a repair or maintenance operation.
An example of jogging or bumping a machine might be when greasing linkages the machine is bumped over so as to position the linkages for access so they can be greased.
Motor STAR – DELTA Starter
Variable Motor Speed Control
What is Motor Actuator ?
4-Wire, 3-Phase Delta Wiring
Parallel Operation of Alternators
Basics of Motion Controllers
Establishing a Modbus Driver for SCADA Indusoft Web Studio
DCS
Mitsubishi PLC Programming Tutorials
STAR DELTA Programming using PLC Controller
Troubleshoot the Status of a PLC Via CPU Indicators
Motor Control Circuits
How to Configure PID in Siemens PLC?
Why is 24 Volts Commonly used in PLC Systems?
Define the Order of Execution in Functional Block Diagram of Studio 5000
Global Data Blocks in PLC
What is a Data Block? Global Data Blocks in PLC
PLC XOR LOGIC with Ladder Diagram
PLC Logic Functions
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
Siemens CP Module
Communication Processor Module in Siemens PLC
PLC-based mail box automation
PLC Program for Mailbox with Letter Counting & Light Indicators
PLC Program to Control Level of Two Tanks
PLC Level Control of Two Tanks
PLC Math instructions
Inductive Time Constant
DP type Flow Transmitter Calibration
DP type Flow Transmitter Preventive Maintenance and Calibration
Instrumentation Cyber Security
Instrumentation Cyber Security Glossary
Instrumentation Engineering Students Test
Procedure for the Repair of Control Valve
Basic Steps and Procedure for the Repair of Control Valve
Control Valves - Repeat Actuator Diaphragm Bursts
Control Valves – Repeat Actuator Diaphragm Bursts
Thyristors Objective Questions and Answers
Top 100 Electrical Machines Projects for Electrical Engineers
