Reading: Motor Classic Control Circuits using Single Push button
Inst Tools > Blog > Animation > Motor Classic Control Circuits using Single Push button
An Automation Engineer mindset cannot be perfect without a deep understanding of motor classic control circuits using push buttons.
Last updated: January 4, 2023 12:52 pm
Hussien Ghareb
Animation Electrical Basics PLC Tutorials
Relay Logic or “Classic Control” as we call it nowadays, is the birth and beginning of Industrial Automation Technology.
Functional Design Specification (FDS) of our applicationMotor Classic Control Circuit ExplanationMain IdeaCircuit De-energizedCircuit EnergizedInterlocking between two RelaysLatching on both Relays
Relays
“PLCs” are the most commonly used devices these days, and also it is invented to overcome and replace the use of complicated classic control circuits.
However, an Automation Engineer mindset cannot be perfect without a deep understanding of classic control circuits.
So, today we are going to experience a classic control application that is used in most factories, and also it is a common interview question.
A major part of any factory is a Three-Phase Induction Motor, it is commonly used for most industries so you might find a sector in a factory that contains many motors.
The simplest way to handle the operation of these motors is by Start/Stop control circuit, it is a simple circuit and it uses two push buttons (NO one for start & NC for stop).
But you have to consider that a panel with many pushbuttons may be confusing for the operators.
So, what we need is to make a circuit that can handle a motor with just NO push-button:
  • On the occurrence of the first press… the motor will run.
  • For the second press, the motor will stop… and so on.
Here you can see in Fig. (1) the classic control circuit that can execute our task, and we will understand this circuit in simple steps.
Motor Classic Control Circuits using Push button
Figure 1
Main Idea
As you can see in Fig. (1) we are using a single NO push-button, two relays, and a motor contactor.
The main idea of this circuit stands behind the two relays, the NO push button is made to handle the two relays (one relay for starting the motor contactor and the other for stopping).
Motor Classic Control Circuit Animation
Also, the contact that is taken from (KM1) as you can see in Fig (1) if the motor is off the start relay will be ready to be energized, and if the motor is running its contact will change so, the stop relay will be ready to be energized.
As you can see in Fig. (2) when the circuit is de-energized the logic flow goes towards the start relay (R1).
Motor Handling Using One Push-Button
Figure 2
So, in case of pressing on the NO push button, the start relay will be energized to operate the motor.
Circuit Energized
As you can see in Fig. (3) when we press the NO push button and the circuit is energized the logic flow goes towards the stop relay (R2).
Motor control circuit tutorial
Figure 3
In this case, the motor is running but as you can see if we press the NO push button the stop relay (R2) will be energized and the motor will stop.
In Fig. (4) we can see that there is an interlock between the two relays, this interlock prevents the two relays from overlapping.
Interlocking between two relays
Figure 4
These latches on the start/stop relays that are presented in Fig. (5) also prevent the two relays from overlapping while we are pressing the NO push button.
Figure 5
  • Scan Cycle in SIEMENS PLC
  • Cloud-Based SCADA Projects
  • PLC-based Gas Detection System
  • Create New Project in Studio 5000
  • Rockwell Allen Bradley PLC Projects
Why is IGBT used in VFD?
PLC Structured Text Program for Output Generation via Equations
PLC Counter Instructions
Why is Phase Failure Relay Required in LV Panels?
Equivalent Logic Gates using PLC Ladder Diagrams
PLC Programming for 3 Motors control in Ladder logic
Geothermal Energy Power Plants
PLC Valve Control Ladder Logic Programming
What is Function Module in Siemens PLC?
PLC Motor Control Ladder Logic Programming
Difference Between Core and Shell Transformers
Floating Neutral - Electrical Engineering Basics
What is Floating Neutral? – Electrical Engineering Basics
Program to implement T Flip Flop logic
T Flip Flop PLC Ladder Diagram
PLC Program for Fish Feeding System
Semiconductor Fuse
What is a Semiconductor Fuse?
Traces in TIA Portal
What is Trace Function in Tia Portal?
PLC Example on Manufacturing Line Assembly
Switch NO or NC Contact
Normally-open and Normally-closed Switch Contacts
Energy Meter Data in PLC using Modbus Communication
Modbus Communication between PLC and Energy Meter
Why we use -24vdc in vibration measurement
Why we use Negative Voltage in Vibration Measurement ?
CNC Programming - Definition, Types, and Tips
CNC Programming – Definition, Types, and Tips
Fixed Gas Detectors vs. Portable Gas Detectors
Siemens PLC Device and Network
Difference Between PLCSIM and PLCSIM Advanced? – Siemens PLC
Electrical Equipment Selection in Hazardous Area
3 Phase Bridge Inverter MCQ
Installation of Proximitor
Determine Lifting of Shaft using Proximity Sensor
Battery in Vehicle
Why is a Battery used in a Vehicle?
