Reading: What is Mixing or Diverting Valve ?
Inst Tools > Blog > Control Valves > What is Mixing or Diverting Valve ?
Last updated: March 21, 2019 11:50 am
Control Valves
1 Min Read
Another style of globe valve body is the three-way body, sometimes called a mixing or a diverting valve.
Mixing or Diverting ValveThree-way Globe Valve
This valve design has three ports on it, with the plug (in this particular case, a cage-guided plug) controlling the degree to which two of the ports connect with the third port.
3-way globe valve principle
This dual illustration shows a three-way valve in its two extreme stem positions. If the stem is positioned between these two extremes, all three ports will be “connected” to varying degrees.
Three-way valves are useful in services where a flow stream must be diverted (split) between two different directions, or where two flow streams must converge (mix) within the valve to form a single flow stream.
A photograph of a three-way globe valve mixing hot and cold water to control temperature is shown here:
Articles You May Like :
What is 3-way Solenoid Valve ?
Control Valve flow coefficient (Cv)
Split Range Control Valves
Basics of Globe Valves
What is Lift Check Valve ?
What is a Spool Valve? – Types, Configurations, Applications
What is a Servo Valve? – Principle and Advantages
Free Control Valve Software Download
Rotork Motor Operated Valve Basic Configuration
How Diaphragm Valves Work ?
Fluid Power Systems
What is Gate Valve ?
Emergency Shutdown Valve : Advantages
What is Swing Check Valve ?
What is Port-guided Globe Valve ?
Flow Control Valves Interview Questions
Purpose of 100% and 30% Feed Control Valves in a Power Plant
What is Instrument Air Manifold ?
Pneumatic Valves Questions & Answers
Control Valve Cv Formula
Control Valve Cv calculation
Globe Control Valve Animation
ball Valve Animation
Basics of Ball Valves
Ball Valve Pictures
How Ball Valves Work ?
Full Bore or Reduced Bore Valves
When to choose Full Bore Valve or Reduced Bore Valve ?
ON OFF Valve Parts
ON OFF Valve Preventive Maintenance and Testing Procedure
What is Directional Control Valve (DCV)?
trip solenoid installed on a control valve appears
SIS Final Control Elements
Input function blocks
FF Function Blocks
PLC Program using START & STOP Buttons
PLC Program using START and STOP Buttons
Differential Pressure (DP) Flow Meters Range Calculation Methods
factorytalk view studio hmi
How to Create Templates in FactoryTalk View Studio?
Synchronous Machine Multiple Choice Questions
How to Select a SCADA for New Project
How to Select a SCADA for New PLC Project?
Calculate Power in Series RL Circuit
Strain Gauge Pressure Transducer
Resistance Type Pressure Transducers Principle
