Reading: Magnetostrictive Tank Gauging (MTG)
Inst Tools > Blog > Level Measurement > Magnetostrictive Tank Gauging (MTG)
Last updated: December 21, 2019 9:32 am
Level Measurement
Magnetostrictive Tank Gauging (MTG) technology has been around for a long time and is used primarily for custody transfer on petrol station forecourts.
Magnetostrictive Tank GaugingMagnetostrictive Tank Gauging Probe
In this application of magnetostrictive gauging, the level measurement can be performed to a very high level of accuracy.
However, at this stage of development for a larger scale version for gasoline bulk storage tanks, the accuracy of measurement is yet to be determined, although it is thought that accuracy comparable to radar and servo gauges would be achievable. It is now becoming considered by more storage industry facilities because of the perceived measurement accuracy. This has become possible because technology is available to allow probes of up to 30 m to be manufactured.
This is seen as being an up-and-coming level measurement method for use in the gasoline bulk storage industry.
1. A pulse is transmitted down the sensor wire towards the magnetic float.
2. The transmitted signal reaches the magnetic float, which is floating on the gasoline surface, and the signal is returned back up the transmit wire back to the piezomagnetic sensor. Since the initial transmit time and return time is known, it is possible to calculate the distance at which the float is along the sensor wire and therefore what the gasoline level is within the tank.
The perceived benefits of this type of system are that for small tanks relatively high accuracy measurement is achievable for a relatively low cost. A further benefit of this type of system is that water, gasoline, and pressure can all be measured from just one sensor.
The testing of magnetostrictive systems currently is limited because it is not possible to see the probe since it is entirely contained within the tank. Removal of the probe is not necessarily a trivial matter because the probes can be many meters in length because they span the whole length of the tank.
On the smaller scale fuel forecourt magnetostrictive systems, there are a number of known issues.
These include:
  • Floats getting stuck;
  • Probe getting bent during installation. This will be a prominent issue for larger storage tanks because the probe has to be the same height as the tank. Therefore one of the major drawbacks currently with using this method of level measurement is the difficulty of the initial installation, especially in above-ground tanks.
The magnetostrictive tank-gauging (MTG) probe utilizes magnetostrictive technology to provide users with the same level of reliability, durability, and cost-effectiveness. The MTG probe used with tank gauging controllers monitors product levels, water levels and temperature in both underground and aboveground tank applications.
The MTG probe monitors the following conditions: high-product level, low-product level, and high-water level. To provide the greatest flexibility of use, the probe’s shaft is stainless steel and the floats are available in a variety of materials and sizes. The MTG probe is ruggedly constructed to provide reliable and cost-effective performance.
  • Radar Tank Gauging
  • Radiation Level Sensor
  • P&ID for Storage Tanks
  • Servo Tank Gauges
  • Hybrid Level Sensors
What is the Simple Alternative Vessel Level Indication?
Microwave Barrier Level Switch Working Principle
Zero Suppression and Zero Elevation Calculations
All About Instrumentation Impulse Lines
Level Gauge Design
  • Avaz Abdullayev says:
    September 10, 2024 at 8:54 am
    Yes, magneto strictive level measurement works precisely, particularly in a small tank such as oil export pump lube oil tank. However, it seems that MTG has its own limitation when tank is filled up to 100%. Saying that magneto strictive level transmitter starts given I/O fault when oil level is above 82% of a tank height.
Remote Seal Differential Pressure Transmitters Principle
How to Measure Density using DP Transmitter?
Nuclear Level Detectors Cascade or Master/Slave concept
Pressure Transmitters Leg Compensation Technique
Advantages & Disadvantages of Level Measurement Systems
Point Level Detection Working Principle
Open Tank Interface Level Measurement
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
Hydrostatic interface level measurement Formula
Hydrostatic Interface Level Measurement
Reflex Level Gauge Parts
What is Reflex Level Gauge?
Magnetic Level Gauge Float
Magnetic Level Gauge Float Design
Asymmetric capillary for Level Measurement
Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
DP Transmitter Level Measurement for Closed Tank Wet leg Method
DP Transmitter Dry Leg & Wet Leg Calculations
Capacitance Level measurement principle
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Level-Transmitters-Animation
Level Transmitter Animation
Ultrasonic Tank Gauging
Ground Fault Versus Short Circuit
Difference Between Short Circuit and Ground Fault
Instrumentation Cables Armor
Common Causes of Imperfect Bends
Instrument Tube Fitting Installation – Part 3
Augmented Reality and Virtual Reality in Industrial Automation
DC Machines Excitation Quiz
Flow Measurement Objective Questions
Programmable Logic Controller (PLC) Questions and Answers – 9
How to Remove Control Valve Stem Packing Procedure
The Replacement Procedure for Control Valve Stem Packing
