Reading: Magnetic Flow Meter Animation
Inst Tools > Blog > Animation > Magnetic Flow Meter Animation
A mag meter or electromagnetic flow meter works on Faraday's Law of Electro-Magnetic Induction. See this Magnetic Flow Meter Animation.
Last updated: October 31, 2023 11:26 am
Animation Flow Measurement How It Works
14 Comments
2 Min Read
A magnetic flow meter (mag meter, electromagnetic flowmeter) is a transducer that measures fluid flow by the voltage induced across the liquid by its flow through a magnetic field.
Magnetic Flow MeterPrinciple of Operation
Magnetic Flow Meter
Image Courtesy: Yokogawa
A magnetic field is applied to the metering tube, which results in a potential difference proportional to the flow velocity perpendicular to the flux lines. The physical principle at work is electromagnetic induction.
The magnetic flow meter requires a conducting fluid, for example, water that contains ions, and an electrical insulating pipe surface, for example, a rubber-lined steel tube.
Simply, Magnetic Flow Meters work on Faraday’s Law of Electro-Magnetic Induction.
The Two Blue dots in the animation indicate electrodes. The Copper coils (red blocks – magnets) on top & bottom of the instrument are electro-magnets used to generate a magnetic field.
When there is no fluid flow then the induced voltage between electrodes is Zero.
When a fluid flows through the magnetic field, the two electrodes pick up the voltage and it is proportional to fluid flow rate.
That’s it. Very Simple.
Post your opinions on Instrumentation animations. Share it with your friends.
  • Magnetic Meters Complete Guide
  • Conductive Level Measurement
  • Why do Flow Meter Calibration
  • Flow Meter Square Root Relationship
  • Architecture of Instrumentation
Logic Gates Animation
PID Controller Gains Effect on Manipulated Variable
Design Considerations of Orifice Plate
Square-root characteristics of Differential Pressure Flow Meters
What are Multiphase Flow Meters? – Working Principle, Advantages
Pressure based Flow Meters
14 Comments
  • Dev says:
    July 23, 2015 at 1:42 am
    Five stars for instrumentation Animations and very useful website for instrumentation engineers.
  • pankaj says:
    July 25, 2015 at 11:24 am
    it is useful to us…who work on field……
  • Mohamad says:
    August 8, 2015 at 6:07 am
    When is it recommended to use the magnetic flowmeter? what are the best process conditions to be used for?? thanks
    • S Bharadwaj Reddy says:
      August 19, 2015 at 4:58 am
      One unique aspect of magnetic flowmeters is that they can only measure conductive fluids. They are excellent for water and most other liquids, but they cannot measure hydrocarbon-based fluids.Some advantages of magnetic flowmeters are that they can easily handle dirty liquids, slurries, wastewater, and other hard-to measure liquids.
      Another unique feature of magnetic flowmeters is the number of types of liners available for different applications. These different liners make magnetic flowmeters useful for hygienic applications, for caustic liquids, and for almost any type of water application. Almost any type of conductive liquid can be measured with the right type of liner.
      • Ashish says:
        September 22, 2017 at 10:50 pm
        Conductivity shall be checked with Process. Water conductivity is not very excellent. This was confirmed by Process Engineer. Because water can be many types like Fresh water, Sour water, Sea water etc. Caustic soda for example has very high conductivity.
        • Mahtab says:
          October 5, 2023 at 12:05 pm
          As far as I know the electrical conductivity of the fluid should be more than 5 microsiemens.
  • suresh says:
    November 24, 2015 at 2:18 pm
    Very useful…
  • Shefeek Salim says:
    February 29, 2016 at 5:50 pm
    Magnetic types are very accurate,but if there is any electrical disturbances like as improper earthing etc,that will badly affect the signals from the sensor to transmitter,and transmitter may unable to produce exact output PV.
  • Nishant Sohani says:
    May 23, 2016 at 3:50 am
    Very nice good information I like it
  • Agravat says:
    May 27, 2016 at 12:24 pm
    What type of output current a.c. or D.C.? ??
  • Eduardo says:
    January 22, 2017 at 2:01 pm
    Dear sir. I can’t explain how wonderful and useful your website is. Thank you very much for your work.
    Best regards.
  • Antonio Gingado says:
    December 16, 2017 at 2:52 pm
    simplesmente MARAVILHOSO
    Translated Portuguese to English : just wonderful
  • sunil says:
    July 22, 2019 at 11:40 am
    Your animation explains everything!
    No need for any text!
  • Tushar says:
    April 24, 2021 at 7:04 pm
    Hello
    Very nice animation. I would like to show animation in my college project. I eager to know Which software do you guys use to create such animation?
Beam Detectors Working Principle Animation
What is an Averaging Pitot Tube? – Principle, Advantages
Short Notes on Differential Pressure Flow Meters
Microwave Flow Sensor – Working Principle and Applications
What is an Orifice Flange? – Purpose and Applications
Flow Measurement Objective Questions
Why Flow is Directly Proportional to the Square Root of DP?
What is a Segmental Wedge Flow Meter?
Averaging Pitot Tube Working Principle
Comparison between Transit time and Doppler Flow Meter
Difference between Transit time and Doppler Ultrasonic Flow Meter
Valve Diaphragm Actuator
Spring and Diaphragm Pneumatic Actuators
Step by step guide for Gas Flow Meter Calibration
Step by Step Guide for Gas Flow Meter Calibration
Transistor as Switch Working Animation
How a Transistor Switch Works
flow-meter-accuracy-calculation
Impact of Flow Meter Accuracy
Densitometers Principle
Vibrating Tube Densitometers Working Principle
Open Channel Flow Measurement Animation
Open Channel Flow Measurement Principle
How to Implement Ratio Control in this System
How to Implement Ratio Control in this System?
IoT Project Ideas for Beginners - Internet of Things
100 IoT Project Ideas for Beginners – Internet of Things
Why 4-20mA Standard is so popular
Why 4-20 mA Standard is so popular ?
Orifice Plate Flow Requirements
What are the Orifice Plate Flow Requirements?
DC Machine
DC Generator Internal Losses
Memory Devices Objective Questions – Part 3
Check Block Consistency Tools
Check Block Consistency Tools in Simatic Manager
Instrumentation Books Free Download
Lessons in Industrial Instrumentation
