Reading: Latched and Momentary Operation of Motor PLC Program
Inst Tools > Blog > PLC Tutorials > Latched and Momentary Operation of Motor PLC Program
Last updated: March 4, 2021 11:28 am
2 Min Read
Write a PLC program to run a motor in case that when the first Push Button (PB) is pressed the motor runs in a latched mode, when the second PB is pressed the motor will not be in the latched mode and will be in the momentary mode and when the stop PB is pressed the motor should be stopped.
Latched and Momentary Operation of MotorPLC Program Explanation
Note: the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Inputs and outputs:
I0.0: First Push Button (Normally open contact)
I0.1: Second Push Button (Normally open contact)
I0.2: Stop Push Button (Normally Closed Contact)
Q0.0: Motor
M0.0: marker for SR flip flop
M0.1: marker for positive edge
In order to keep the motor latched you can use the SR flip flop where the set branch is energized by positive edge detection from the First_push_button, and the reset branch is energized by either the stop_push_button or the Second_push_button is energized.
The second_push_button is connected to the stop normally open (in this case normally open is the reverse case of the Stop_push_button) in order to not operate the motor in the case of the stop_push_button is pressed.
Author: Karim Ali Anwar
  • Types of Cables
  • Start Stop Motor Logic
  • 100 Motor Quiz Questions
  • PLC and VFD Circuit Problem
  • Run Motors Sequential
PLC Timer Instructions
How to Add Security in InTouch SCADA?
Configuration of Siemens VFD Using TIA Portal Start drive
Why is RTO used in the Place of TON Timer?
Single-acting Pneumatic Cylinder Operation with Limit Switch
Communication between Factory IO and Siemens Tia Portal
Exhaust Fan Control: Example of PLC Timer Programming
Automatic Motor Forward and Reverse Control using Timer
Scaling with Parameters (SCP) Instruction in PLC
PLC based drilling machine
Drilling Process using PLC Program
Conveyor and Puncher PLC Program
Toggle Switch & Sensor: Conveyor and Puncher PLC Program
Smart Drip Irrigation System Using PLC
Boolean Algebra to PLC Logic
From Boolean Algebra to PLC Logic
Machine Indicator Lights PLC Programming Solution
PLC Logic - Control Spray Nozzle, Fans, and Puncher
PLC Program for Selective Execution of the Application
PLC Selective Execution of the Application – Example Program
PLC program for VFD Drive Multiple Speeds
Drive Multiple Speeds with Different Reference using PLC
Digital Input and Output Devices Objective Questions
Digital Input Output Devices Objective Questions
Pros and Cons of Online Educational Services
Pros and Cons of Online Courses
Encode and Decode Instructions
How to Use Encode and Decode Instructions in PLC ?
Creating CNC Program
Steps Followed Before Creating CNC Program
DRUM DB
Siemens Drum block for Sequencer Operation
Electronic Devices & Circuits Quiz – Set 1
Moving Iron Vane Meter Movement
