Reading: Kirchhoff’s Laws
Inst Tools > Blog > Electrical Theory > Kirchhoff’s Laws
Kirchhoff’s Laws
Last updated: July 23, 2018 4:27 pm
Electrical Theory
2 Min Read
Kirchhoff’s two laws reveal a unique relationship between current, voltage, and resistance in electrical circuits that is vital to performing and understanding electrical circuit analysis.
Kirchhoff’s Laws
In all of the circuits examined so far, Ohm’s Law described the relationship between current, voltage, and resistance. These circuits have been relatively simple in nature. Many circuits are extremely complex and cannot be solved with Ohm’s Law. These circuits have many power sources and branches which would make the use of Ohm’s Law impractical or impossible.
Through experimentation in 1857 the German physicist Gustav Kirchhoff developed methods to solve complex circuits. Kirchhoff developed two conclusions, known today as Kirchhoff’s Laws.
Law 1:
The sum of the voltage drops around a closed loop is equal to the sum of the voltage sources of that loop (Kirchhoff’s Voltage Law).
Law 2:
The current arriving at any junction point in a circuit is equal to the current leaving that junction (Kirchhoff’s Current Law).
Kirchhoff’s two laws may seem obvious based on what we already know about circuit theory. Even though they may seem very simple, they are powerful tools in solving complex and difficult circuits.
Kirchhoff’s laws can be related to conservation of energy and charge if we look at a circuit with one load and source. Since all of the power provided from the source is consumed by the load, energy and charge are conserved. Since voltage and current can be related to energy and charge, then Kirchhoff’s laws are only restating the laws governing energy and charge conservation.
The mathematics involved becomes more difficult as the circuits become more complex. Therefore, the discussion here will be limited to solving only relatively simple circuits.
Read about two laws :
  1. Kirchhoff’s Voltage Law
  2. Kirchhoff’s Current Law
Reading Electrical Schematics
Induction Motor
DC Motor Theory
Types of AC Generators
Induction Motor Torque Versus Slip
DC Motor Torque
Power Factor Meter Principle
AC Generation Analysis : Effective Values, Phase Angle and Frequency
Y and Delta Resistor Network Calculations
DC Machines Terminology
DC Machines Construction
Single Phase Power Wiring Schemes
4-Wire, Three-Phase Delta Wiring System
Single Line Diagram
Three Phase AC Generators
Megger Circuit Diagram
Multimeter & Megger Principle
Electrical Wiring Terminology
Properties of Conducting Materials
Resistivity
Series-Wound DC Generator Principle
Series-Wound DC Generators
Parallel Open Circuit Fault
Parallel Open Circuit Faults
DC Motor Action
DC Motor Speed
Transformer voltage and turns ratio
Transformer Voltage Ratio
Tips to Maintain & Extend the Life of CNC Tools
Tips for Maintaining and Extending the Life of Your CNC Tools
Electric Motors Efficiency Classes
Formulas to calculate ma from PV
Formulas to calculate mA from PV, LRV and URV
How Could FB and FC Make Me Professional PLC Programmer
How Could FB and FC Make Me Professional PLC Programmer?
Wrong Orifice Installation
How Not to Install an Instrument and Wrong Practices
Field Transmitter Range Calculation
Transmitter Turndown Ratio, Set Span and Zero Span
Dry Contact in PLC
What is a Dry Contact? – Basics of PLC Wiring
PLC Instructions
Program Flow Control Instructions in PLC Programming
