Reading: What is Interface Module in Siemens PLC?
Inst Tools > Blog > PLC Tutorials > What is Interface Module in Siemens PLC?
In this article, we will learn about the interface module (IM) used in the Siemens PLC for data transfer between I/O modules or between PLCs.
Last updated: March 4, 2021 11:18 am
In this article, we will learn about the interface module (IM) used in the Siemens PLC.
The data transfer between I/O modules or between higher levels of PLCs takes place via an interface module.
I know that many people have heard this word remote I/O, this is achieved by installing an interface module.
Remote I/O is used to reduce long wire run, reduce complexity while troubleshooting, and provide a cost-effective solution.
Let’s assume that in the plant we have to install a bunch of field devices that are far away from the control room.
In such a case instead of pulling wires from field to control room can increase the cost significantly and also make troubleshooting of a system more difficult.
To make things simple, first, move all the I/O modules to the field area and add interface module with it.
Now, connect supported communication port from the control room’s CPU to interface module to establish communication with each other.
This way you only require one cable for communication between devices, which reduces the cost of wiring and complexity.
As you can see in the below image that how an interface module is used to transfer data over a long distance.
In the case of a critical system, you can pull one more communication cable as a redundant system to prevent an unexpected shutdown.
Redundant system communication cable
There is one more way to use the interface module in the control panel.
In s7-300 series of CPU support three rack and eleven module configurations.
If you have a larger system than you may require more than one rack to communicate with other racks, Here, you need an interface module.
Check out the below image to know how an interface module is added on the rack to communicate with the CPU.
As you can see Interface module is added to the second slot of a first rack and in the first slot of the second rack.
Pull PROFIBUS cable from the first IM to the second IM. This way it can communicate with the rack through two Interface modules.
This way you can add the third rack and do follow the same step to establish a connection.
On the software side, you can find many different types of interface modules. You can choose as per your application and hardware.
You can connect an interface module through PROFINET or by PROFIBUS method to communicate.
Siemens Interface Module
Author: Suhel Patel
  • Electrical Ground Loop
  • Components of PLC
  • Fieldbus Coupling Devices
  • PLC Sinking and Sourcing
  • Test and Process Modes
PLC based Gas Detection System using Ladder Logic Project
PLC Programming Videos
CX-Programmer Products Sorting & Counting – Omron PLC
Exhaust Fan Control: Example of PLC Timer Programming
Introduction to PLC – Advantages of PLC
Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
Communicating Delta PLC Software to Simulator
How to Communicate with Excel from Intouch SCADA?
ON Delay Timer using PLC
PLC Programming for Train Detection and Gate Operation
How-to do Security of SCADA Systems?
Structured Text PLC Code for Sequential Process Data Storage
PLC Electric Motor Interlocks
How to Create DFB in Schneider PLC? – Derived Function Block
Siemens PLC-to-PLC Communication Project
How to Program Sequential Outputs in PLC
Create an Application in HMI using Tia Portal
PLC Best Practices
#1 PLC Best Practices – Split PLC Code into Modules
PLC Raw Count Calculation formula for Pressure Transmitter
PLC Raw Count Calculation for Pressure Transmitter
CODESYS HMI Interface
Instrument Technician Questions and Answers
Relay Types
Types of Relays – Questions and Answers
Replace Failed Motors Quickly and Easily
Siemens Process Mode
Test and Process Modes in Siemens PLC
Instrumentation Loop Diagram
Loop diagram and System Inspection Lab Exercise
Open Loop Control Block Diagram
Center Tap Full-Wave Rectifier
Full-Wave Rectifier Circuit
Robotic Process Automation
What is Robotic Process Automation? Advantages, Applications
