Reading: Instrumentation Calculator
Inst Tools > Blog > Instrumentation Tools > Instrumentation Calculator
Last updated: November 12, 2019 3:40 pm
8 Comments
1 Min Read
Instrumentation Calculator: This tool is used to calculate Transmitter output signal in Percentage, mA & equivalent Process unit using the LRV, URV and Input details of transmitter.
For Mobile users : Click Here to Download the Android App
This calculation tool is used to find out the equivalent Transmitter output using PV,URV & LRV.
Where,
VALUE    =  Process Variable
URV =  Upper Range Value  (Transmitter Max scale value)
LRV =   Lower Range Value (Transmitter Min scale value)
INPUT = Enter equivalent Transmitter input signal
Note:
1.For calculating the equivalent current 4-20ma, we have to enter PV, URV & LRV details.
2.The above calculation tool designed for all standard Transmitter signal conversion.
3.You can convert out of range signal also with the above tool.
(Example: URV = 100, LRV = 0 and PV = 110)
Download : Instrumentation Calculator Android App
Interface Level Measurement using DP Transmitter
0-20 mA Analog Signal to Measurement Converter Tool
Closed tank Density Measurement using DP Transmitter with dry leg & constant level application
Transmitter Current Conversion Tool
Calculate Current (4-20ma) from Process variable PV
Convert Process Variable to Percentage
8 Comments
  • vardaman says:
    August 10, 2015 at 1:58 pm
    Excellent …. Nice Instrumentation Calculator. Its really a great tool for instrumentation engineers.
  • kaushal says:
    October 19, 2015 at 12:51 pm
    Good for inst calculator
  • leet says:
    January 16, 2016 at 4:41 am
    will give me the equation for above converter
    • S Bharadwaj Reddy says:
      January 16, 2016 at 4:43 am
      Hello Leet, Check Formulas & Instrumentation Tools Categories.
  • Gabriel Costa says:
    October 6, 2016 at 6:38 am
    Time to make the download for iphone.
    Thank you
  • basir says:
    February 12, 2017 at 5:55 am
    Excellent……..Instrumentation Tools
  • Omy says:
    March 11, 2017 at 2:43 am
    Need for iPhone, please help me. Very important for mu work
  • T Saidaiah Chary says:
    February 3, 2020 at 9:19 pm
    How to download this articles in PDF format
Level Measurement with Wet leg and Installed Below Tapping Point
Level Measurement with Dry leg and Installed Below Tapping Point
RTD Calculator : Calculate Resistance from Temperature
DP Flow Transmitter Re-Ranging Calculation
4-20 mA to Measurement Converter Tool
Convert current (4-20mA) to Percentage (0-100%)
Measurement Value to 4-20mA Signal Converter
Boiler Drum Level Transmitter Calibration
Density-Measurement-using-DP-Transmitter-for-Closed-Tank-Wet-leg
Density Measurement using DP Transmitter for closed tank with wet leg
Convert Linear mA to Square root mA
Convert Linear Percentage to Square root Percentage
RTD Calculator : Calculate Temperature from Resistance
DP-Level-Measurement-Calculation-Above-Tapping-Point-Open-Tank
Differential Pressure (DP) Level transmitter Installed Above Tapping Point
Convert-Transmitter-Output-in-Percentage-to-Process-Variable
Conversion of Transmitter Output in Percentage to Process Variable
DP-Level-Transmitter-Diaphragm-with-capillary-tube-type
DP Level Transmitter Calibration for Diaphragm Seal with Capillary
Density-Measurement-using-DP-Transmitter-for-open-tank
Density Measurement for Open Tank with Constant Level Application
Control Valve Working Animation
Permanent magnet moving coil instruments (PMMC)
Permanent Magnet Moving Coil Instruments (PMMC)
Four Wire RTD Principle
How a 4 Wire RTD Works ?
Compressor and Compressor valves Maintenance
Compressor & Compressor Valves Maintenance
Free Online Control Valves Course
Free Control Valves Course
Pneumatic Actuators
Self-Actuated Valves, Pneumatic & Hydraulic Actuators
Dual Converters Multiple Choice Questions
