Reading: Induction Motor
Inst Tools > Blog > Electrical Theory > Induction Motor
Induction Motor
Last updated: August 6, 2018 5:10 pm
Electrical Theory
1 Min Read
Induction Motor
Previous explanations of the operation of an AC motor dealt with induction motors. The induction motor is the most commonly used AC motor in industrial applications because of its simplicity, rugged construction, and relatively low manufacturing costs.
The reason that the induction motor has these characteristics is because the rotor is a self-contained unit, with no external connections. This type of motor derives its name from the fact that AC currents are induced into the rotor by a rotating magnetic field.
Squirrel-Cage Induction Rotor
The induction motor rotor (Figure) is made of a laminated cylinder with slots in its surface. The windings in the slots are one of two types. The most commonly used is the “squirrel-cage” rotor. This rotor is made of heavy copper bars that are connected at each end by a metal ring made of copper or brass.
No insulation is required between the core and the bars because of the low voltages induced into the rotor bars. The size of the air gap between the rotor bars and stator windings necessary to obtain the maximum field strength is small.
Squirrel-Cage Induction Motor
Figure : Squirrel-Cage Induction Rotor
Inductive Time Constant
Calculate Power in Series RC Circuit
AC Motor Theory
DC Motor Connections
Calculate Power in Parallel RCL Circuit
Three Phase Transformer Connections
Starting of DC Motors
Ground Detector Principle
Transformer Operation Under No-Load
Parallel Circuit
Losses in AC Generator
Types of Capacitors
Series and Parallel Inductors
Synchronous Motors
Series - Wound DC Motor
Series-Wound Motor
Three-Phase Wye Wiring System
4-Wire, Three-Phase Wye Wiring System
Current Law
Applying Kirchhoff’s Current Law
Megger Circuit Diagram
Multimeter & Megger Principle
Transformer voltage and turns ratio
Transformer Current Ratio
Basic AC Generator
AC Generator Parts
Resistor Y and Delta Network Calculation
Y and Delta Resistor Network Calculations
Voltage Drop in a Series Circuit
Series Resistance
Load Cell Assembly
Urea Bagging Plant – Process Flow
Electrical & Electronics Measurements Objective Questions – Set 6
PLC Program to Control Level of Series Tanks
Series Tanks Level Control using PLC Ladder Programming
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Calibration setup for a low-range electronic pressure transmitter
Instrument Lab Exercise – Ranging and Manometer Usage
Memory Devices Objective Questions – Part 1
toroidal conductivity probe principle
Conductivity Analyzer Common Problems and Troubleshooting Tips
RF Capacitance Switch Principle
Safety Switches for Controlling Conveyor Operations
