Reading: ICS System Design Considerations
Inst Tools > Blog > Control Systems > ICS System Design Considerations
Design Considerations that drive design decisions regarding the control, communication, reliability, and redundancy properties of the ICS system.
Last updated: March 4, 2021 11:09 am
Control Systems PLC Tutorials
In the previous topic, we discussed the introduction and the basic components of an ICS, the design of an ICS, including whether a SCADA, DCS, or PLC-based topologies are used depends on many factors.
ICS System Design ConsiderationsControl Timing RequirementsGeographic DistributionHierarchyControl ComplexityAvailabilityImpact of FailuresSafety
ICS System Design
This section identifies key factors that drive design decisions regarding the control, communication, reliability, and redundancy properties of the ICS.
Because these factors heavily influence the design of the ICS, they will also help determine the security needs of the system.
ICS processes have a wide range of time-related requirements, including very high speed, consistency, regularity, and synchronization. Humans may not be able to reliably and consistently meet these requirements; automated controllers may be necessary.
Some systems may require the computation to be performed as close to the sensor and actuators as possible to reduce communication latency and perform necessary control actions on time.
Systems have varying degrees of distribution, ranging from a small system (e.g., local PLC controlled process) to large, distributed systems (e.g., oil pipelines, electric power grid).
Greater distribution typically implies a need for wide-area (e.g., leased lines, circuit switching, and packet switching) and mobile communication.
Hierarchy
Supervisory control is used to provide a central location that can aggregate data from multiple locations to support control decisions based on the current state of the system.
Often a hierarchical/centralized control is used to provide human operators with a comprehensive view of the entire system.
Control Complexity
Often control functions can be performed by simple controllers and preset algorithms.
However, more complex systems (e.g., air traffic control) require human operators to ensure that all control actions are appropriate to meet the larger objectives of the system.
Availability
The system’s availability (i.e., reliability) requirements are also an important factor in design.
Systems with strong availability/up-time requirements may require more redundancy or alternate implementations across all communication and control.
Impact of Failures
The failure of a control function could incur substantially different impacts across domains.
Systems with greater impacts often require the ability to continue operations through redundant controls, or the ability to operate in a degraded state. The design needs to address these requirements.
Safety
The system’s safety requirements are also an important factor in design. Systems must be able to detect unsafe conditions and trigger actions to reduce unsafe conditions to safe ones.
In most safety-critical operations, human oversight and control of a potentially dangerous process is an essential part of the safety system.
Reference: National Institute of Standards and Technology Special Publication 800-82, Revision
  • Instrumentation Design
  • Types of System Architecture
  • Automation and Control System
  • System Reference Model
  • System Remote Connectivity
Identify Instruments in Piping and instrumentation Diagram
Test and Process Modes in Siemens PLC
PLC Trainer Demo Download
PLC System Site Acceptance Test (SAT)
What is Loop Checking?
What is the DDE Protocol?
Difference between Feedback, Feedforward, and Cascade Control?
PLC Instruction List for Motor Reverse and Forward Direction
HMI Handbook
Structured Text PLC Programming for Automatic Gate Control
What is Wellhead Control Panel?
How to Create Faceplate in FactoryTalk View Studio?
Cars Garage Counter From the Same Door PLC Logic
Scaling in PLC
PLC Ladder Logic for Sensor Scaling with Offset
How to troubleshoot the PLC Hardware faults
Save to Memory Card
How to Save a PLC Project to a Micro Memory Card?
How to Detect Speed of Conveyor in PLC
How to Detect Speed of Conveyor in PLC?
Rotary UPS or Dynamic UPS
What is Hot Standby in PLC
What is Hot Standby in PLC?
Innovative Segment Orifice
Pitot-tube Replaced with Innovative Segment Orifice Plate
Flow Switch Working Principle Animation
Working Principle of Flow Switch with Animation
Multistage Flash Drums Erratic Level Readings
Functional Block Diagram in PLC for Oil and Water Process
Current-to-Percentage-Conversion
Formula for Current 4-20ma to Percentage Conversion
absorption-type optical analyzer
Absorption Type Optical Analyzer
What is calibration?
Type E thermocouple
Type E thermocouple Calculations
