Reading: How to Use Diagnostic Buffer for SIEMENS PLC?
Inst Tools > Blog > PLC Tutorials > How to Use Diagnostic Buffer for SIEMENS PLC?
Today we are going to speak various helpful PLC tools such as the Diagnostic Buffer for Siemens PLC for troubleshooting Simatic S7 problems.
Last updated: September 28, 2022 2:23 pm
Hussien Ghareb
Welcome back with SIEMENS PLCs, today we are going to continue discussing the different PLC troubleshooting techniques, if you are interested in such topics you have to read these topics:
Advantages of the Diagnostic BufferDiagnostic Buffer for SIEMENS PLCSiemens PLC Example
  • the Hardware Troubleshooting of PLC
  • the Software Troubleshooting of PLC
Today we are going to speak about various helpful PLC tools such as the Diagnostic Buffer, how to use it, and how it can help us that is what we are going to speak about.
The function of the Diagnostic Buffer at SIEMENS PLCs?
The operating system of the PLC processor enters the errors detected by the CPU and the diagnostics-capable modules into the diagnostics buffer in the order in which they occurred.
This includes the following events:
  • Every mode change of the CPU (POWER UP, change to STOP mode, change to RUN mode)
  • Every hardware and diagnostic error interrupts
  • After the CPU has changed to STOP mode, you can evaluate the last events prior to the STOP so that you can locate and identify the cause of the STOP.
  • You can detect and eliminate the causes of errors more quickly and thus increase the availability of the system.
  • You can evaluate and optimize the dynamic system response.
Before going through that tool, you have to go online to open and deal with the diagnostic buffer to determine the status of your PLC.
If you do not know how to go online with your PLC please check the previous article (here)
Now and after going Online click on “Online & diagnostics” on the project tree as shown in the next figure.
Online and Diagnostics of Siemens PLC
As we can see in the next figure here are some of the system events that are ordered with the date and time that is occurred in.
Note
The diagnostics buffer is a ring buffer. With the S7-1200 CPUs, the maximum number of entries is 50.
When the diagnostics buffer is full and a further entry needs to be made, all existing entries are shifted one position (which means that the oldest entry is deleted) and the new entry is made at the first position that is now free (FIFO principle: first in, first out).
How to use Diagnostic Buffer for SIEMENS PLC
Siemens PLC Example
Here we will see a simple example to know how a diagnostic buffer can help us in troubleshooting.
We have here a situation that after some time of PLC running, the PLC goes to STOP mode by itself and after resetting the PLC it occurs again.
PLC Running and Stop Mode
Download: PLC Program
After going to the PLC diagnostic buffer, we will see what is really happing inside
As we can see in the next figure the PLC goes to STOP mode because of the cycle time exceeded the limit of the scan cycle time, and that forced the CPU to go to the STOP mode by itself.
Read Diagnostic Buffer in a CPU of Simatic S7
If you still cannot understand what is going on you can click on “Help on the event” in the previous figure to open the Help dictionary.
We will see that there might be an infinity loop in our PLC code, or there is any reason that pushes the cycle time over the limit of the scan cycle time.
Simatic S7 Help on the event
So, if we go back again to our code, we will find out that by mistake (obviously not) we have made an infinity loop in our code as we can see in the next figure.
Siemens PLC diagnostic buffer
So, after going back to our code and editing that mistake, we will have a healthy PLC performance again.
Thanks for being here and wait for more Automation articles.
  • Yokogawa DCS Tutorials
  • PLC System Cabinet Health Checks
  • Communication Protocols in PLC
  • SFC Language in PLC Programming
  • DCS in Industrial Automation
Up Down Counter Instruction in PLC
Use of Regions in SCL Language
PLC Example with Switches
Data Handling Instructions in PLC Programming
How a PLC do the Scaling for a Sensor ?
What are User Defined Function Blocks in PLC?
Introduction to PLC Ladder Diagrams
CW and CCW Operation of Motor from Same Push button
PLC Compressor Control Ladder Logic
Troubleshooting PLC Permissive Inputs
How to Configure IP Address in Rockwell PLC?
Yokogawa DCS
Yokogawa DCS and SIS System Architecture
Comparator used in Siemens S7-1200 PLC.
Siemens PLC Comparator Logic
Open Platform Communication (OPC)
PLC Motor Control Ladder Logic
PLC Program for Star Delta Motor Starter
Scaling in PLC
How to do Scaling for Analog Input in RSLogix 500?
PLC Karnaugh maps
How to Simplify PLC Coding Using Karnaugh Maps?
Car Parking System PLC Program Example
Schneider Electric: Car Parking System with Calculations in PLC
Basic Concepts of the Safety Relay
Force Measurement Objective Questions
EasyBuilder Pro Weintek HMI Software
EasyBuilder Pro Online Simulation of Mitsubishi FX3U PLC
Simple Conveyor Control PLC Program
XG5000 Example of Simple Conveyor Control PLC Program
Questions and Answers in Electrical Machines
Yokogawa DCS
float-type level switch control a pump
PRV
Cable Drum Handling
What is Cable Drum Handling? – Transportation & Storage
