Reading: How to implement SR Flip Flop using PLC Ladder Logic
Inst Tools > Blog > PLC Tutorials > How to implement SR Flip Flop using PLC Ladder Logic
This is the PLC Program to implement SR flip flop in PLC. Learn the PLC programming with this example logic.
Last updated: November 3, 2023 12:13 pm
SR Flip Flop using PLC Ladder LogicProblem DiagramPLC SolutionList of inputs/outputsPLC Ladder Diagram to implement SR flip-flopProgram ExplainedResult
Problem Description
Implement a program for SR flip-flop logic in PLC using ladder language.
Problem Diagram
SR Flip Flop Logic
PLC Solution
As we know, more complex systems cannot be controlled with combinational logic alone. The main reason is that we cannot, or choose not to add sensors to detect all conditions. In these cases we can use event to estimate the condition of the system.
SR flip flop is used for Latch on or unlatch – to lock something ON or turn it OFF.
Most PLC has special instruction for SR flip flop function. so no custom logic required for such types of PLCs. SR flip flop first executes SET function and then RESET function.
Note :- Here we are considering simple function of SR flip flop instruction without using special instruction or using latch function. Here we are using simple latching circuit for SR flip flop function.
SR Flip Flop Truth Table
Here as shown in figure two push buttons or two inputs are taken for program implementation.
When user will press SET button or 1 is received at S input, Q output will be ON and if RESET button pressed or 1 received at R input, Q^ will be ON.
Digital Inputs
  • Set Input :- I0.0
  • Reset input :- I0.1
Digital Outputs
  • Q output :- Q0.0
  • Q^ output :- Q0.1
M memory
  • Relay coil 1 :- M0.0
  • Relay coil 2 :- M0.1
SR Flip Flop Ladder Logic
PLC SR Flip Flop
PLC Ladder Flip Flop SR
Program Explained
For this PLC program we use S7-300 PLC and TIA portal software for programming. We can implement this logic by using other PLC also.
Network 1:
Here we used NC contact of relay coil 1(M0.0) so when reset button is pressed, Q output (Q0.0) is OFF.
Network 2:
Here we used NC contact of relay coil 2 (M0.1) so when set button is pressed, Q^ output (Q0.1) is OFF.
Network 3:
Here when we press RESET button (I0.0), relay coil 1(M0.0) will be latched.
Network 4:
Here when we press SET button (I0.1), relay coil 2(M0.1) will be latched.
If both the inputs are low during power up, Q^ output (Q0.1) will go high because of its order. If both the inputs are
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of implementing SR flip function without instruction. we can use this concept in other examples also.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications.
Result
Ladder SR Flip Flop
Author: Bhavesh
  • PLC Pneumatic Circuit Control
  • Blinking Lamp on 5 Seconds Interval
  • Entry and Exit Control of Car Parking
  • Alarm Indication in Process Control
  • Drain Same Products from Two Tanks
CX Programmer Example: Perfume Mixing and Filling System
Concept of Interlocking in PLC
DC Injection Braking in VFD
Siemens TIA Portal Free Version Download
SCADA and HMI Systems – Differences, Similarities, Purpose
Waste-Burning System OMRON PLC Program Example
Statement List (STL) to Find Highest Value
Schneider Electric: Car Parking System with Calculations in PLC
#20 PLC Best Practices – Identify Critical Alerts
How to Configure PID Controller in Various Schneider PLCs?
Yokogawa DCS Tutorials – Configuration of Analog Input (Transmitter)
Configuration of InTouch Scada Trends
Motor Feedback Fail Logic in PLC
Download Modscan software
How to Use ModScan Software for Testing Modbus Communication?
PLC Program Backup in Siemens Tia Portal
How to Take Program Backup from Physical PLC? – Siemens PLC
Two Tanks Filling using PLC
PLC Ladder Logic for Tanks Filling as per Priority
Real-time and historical SCADA Trends
What are Trends in SCADA?
Safety PLC Programming steps
Safety Door Interlock PLC Program
Pumping System in Industrial Automation
Basic Pumping System Application Used in Industrial Automation
PLC Temperature Control using Pulse Width Modulation
PLC Temperature Control using Pulse Width Modulation (PWM)
Quiz on Electrical Drawings and Symbols
264 Quiz on Electrical Drawings and Symbols
Procedure For reading or searching the tag number in Siemens PLC
Procedure for Reading or Searching the Tag number in Siemens PLC
Power Electronics Diode Circuits MCQ
mA-Conversion-Tool
Transmitter Current Conversion Tool
Profibus DP Master
DP Master System Configuration in PLC
Tie rods double acting cylinder
What is a Pneumatic Cylinder?
CNC Machining vs 3D Printer
CNC Machining vs 3D Printer – What is the difference?
Impulse Steam Trap
Impulse Steam Trap
