Reading: How to Design a Motor Faceplate in Graphics? – SCADA Tutorials
Inst Tools > Blog > Control Systems > How to Design a Motor Faceplate in Graphics? – SCADA Tutorials
Learn how to design a motor faceplate in SCADA or HMI graphics. These SCADA tutorials help you to optimize the PLC projects.
Last updated: August 15, 2023 6:49 am
Control Systems PLC Tutorials
7 Min Read
When you design a SCADA or HMI system, there are instances when many screens tend to repeat themselves, due to the same information everywhere.
What is a Faceplate?Motor Faceplate Design
For example, if there are 10 motors and every motor has the same information in it, many programmers create 10 different screens for them. But, there also comes a feature in HMI or SCADA, called a faceplate. It is a common screen where you have to indirect address the motors by linking the variables, and the corresponding motor data will be communicated. You need not have to create multiple screens for them.
A motor is the most commonly used equipment in industrial automation, and it is important to see how you design a motor faceplate in the graphics. This can help the user provide relevant information.
In this post, we will learn how to design a motor faceplate in SCADA or HMI graphics.
First of all, let us understand what a faceplate is. A faceplate can be termed as a common screen or popup, in which indirect addresses are defined. Whenever you call one faceplate of an object, its corresponding values are moved and shared with the faceplate. And when you call the faceplate of suppose the fourth object, then its corresponding values are moved and shared with the faceplate.
In short, the SCADA screen is the same; just need to create multiple instances and tag the corresponding variables in it. Whenever an instance is called, the tags in it are shared with the faceplate. This reduces the need to design multiple screens and popups for the same.
Because you create only a single screen or popup, the programming size also reduces, and indirectly, the programming work also reduces. Because, if suppose there are 20 objects having the same data to be shared; then there is no use to create 20 screens or popups of the same. It is an utter waste of time and energy. Instead, just create a single screen and link internal variables in it. These internal variables will be overwritten by external variables upon calling it through any instance.
This concept is very similar to a library you create in PLC programming. When the logic is the same for many types, you just create a single library for that type, instead of writing the logic multiple times. This saves time and energy in writing logic.
Refer to the below image for understanding. As you can see, all the general information is present in the faceplate.
How to Design a Motor Faceplate in Graphics - SCADA Tutorials
Let us have a look at some of the most common data that can be shown in the popup:
  • Title – This is the first and foremost data required in the faceplate. In the image, the title name is given as RO High-Pressure Pump, ROHPP-01A. This is important because it shows which motor faceplate has been opened by the user.
  • Manual Command – This button is used to turn on the motor in manual mode. Instead of providing a separate screen for turning on all the motors, just give this button in the faceplate and you can individually control all the motors from here.
  • Motor Status – This status is used to show whether the motor is running or stopped.
  • Run Feedback – This feedback comes from the motor contactor or thermal overload relay. It shows whether the motor is running or stopped.
  • Trip Feedback – This feedback too comes from the electrical panel and is used to denote whether the motor is tripped or not.
  • Local Remote Feedback – MCC panels mostly have a local/remote switch in them. It gives the option to either run the motor locally through the electrical panel or run the motor through PLC logic in a remote way. This switch feedback is thus used to denote whether the motor is in local or remote mode.
  • Pump Analog Output – If the pump has an analog output for speed control, then this information shows how much the current analog output is given by the PLC to the motor.
  • Pump Speed Reference – When an analog input is taken in the PLC from the motor, this data is used to how much is the current speed of the motor.
  • Manual mode speed – This setting is used to feed the motor with a fixed speed in manual mode.
  • Speed selection – This selection is used to define the speed operation in either auto or manual mode. In manual mode, the motor will take manual mode speed reference, and in auto mode, the motor will take reference from either PID or some other type of logic written.
  • PID values of set and current – If PID logic is used for motor speed control, then this shows the PID reference set value, current value, and also the PID output from the motor.
These are some of the most general types of data shown in the motor faceplate. There are other data too, like alarm status, running hour status, motor temperature, or energy consumption data. It varies on programmer to programmer and what is the client requirement.
  • Overview of SIEMENS PLC
  • HMI and VFD Control System
  • Sequential PLC Pneumatic Valves
  • HMI Screen Design for Hazardous
  • S7-1200 Hardware Configuration
PLC Ladder Logic for Lube Oil Pump Motor
PLC Level Control of Two Tanks
PLC Motor Operation based on Time Cycle Sequence – Program
1oo2 Evaluation Safety Instruction in Safety PLC
PLC Program Examples
Difference between PLC and HMI
Two Element Drum Level Control System
Difference Between PLC and CNC Machine
PLC Timer Instructions
How to Convert an Electrical Diagram into PLC Program?
Automated Test Bench – Complex PLC Programming Examples
Wet Contacts and Dry Contacts in PLC Systems
Control Loop
What is a Control Loop ?
PLC Program using One Shot Rising Instructions
One Shot Rising and One Shot Falling Instructions in PLC
VPN for Control Engineers
How Important is VPN for Control Engineers?
Difference Between Batch Process and Continuous Process
Types of Limit Switches
Types of Limit Switches – Principle, Advantages, Disadvantages
SCADA
Top 100+ SCADA Questions
Rotary UPS or Dynamic UPS
Comparison of Temperature Sensors - Industrial Process Control
Loop Diagram
Example Program Logic in Allen Bradley PLC
PLC Programming Examples on Industrial Automation
Control Panel Instruments
Control Panel Instruments Problem Threatened Plant Shutdown
Diode Rectifier
Automation in laboratory
Automating Lab Data Reconciliation: Key Steps to Success
Types of Transfomer Cooling Methods
Digital Electronics MCQ
Binary Coded Decimal (BCD) Objective Questions
