Identify the “high” and “low” ports on this pneumatic differential pressure transmitter, and explain your reasoning:
Pneumatic DP Transmitter
Also, explain how this transmitter will respond to an increasing pressure at each of its two ports, including the operation of the bellows feedback mechanism.
Answer:
Port “A” is the “high” pressure port on this transmitter, and port “B” is the “low” pressure port.
Remember: an increasing pressure applied to the “high” port causes an increasing signal out of the transmitter.
Conversely, an increasing pressure applied to the “low” port causes a decreasing signal out of the transmitter.
Note: These are very old models and obsolete now.
- DP Transmitter Interface Level
- DP Transmitter Application
- DP Transmitter Problem
- Errors of DP Transmitter
Credits: Tony R. Kuphaldt
