Reading: Guided-wave Radar Asset Management Parameters
Inst Tools > Blog > Practical Questions > Guided-wave Radar Asset Management Parameters
Examine the different configuration parameters for a guided-wave radar transmitter asset management software.
Last updated: January 12, 2021 6:47 pm
Practical Questions
1 Min Read
Examine the different configuration parameter fields for a guided-wave radar transmitter shown in this screenshot (taken on a personal computer running Emerson AMS software, interrogating a Rosemount model 3300 level transmitter), and explain the importance of each one:
1. Do you think it is realistic to set the span of a GWR transmitter equal to its probe length? Why or why not?
2. What does the selection “Interf w. imrsd prb” mean, especially in comparison with the other measurement mode options?
3. What significance does the “Probe Angle” setting have?
Share your answers and explanation with us through the below comments section.
  • Signal Strength of Guided-wave Radar Level Instrument
  • Guided-Wave Radar Instruments Diagnostics
  • Level Instruments Measuring Velocity
  • Guided Wave Radar Questions and Answers
  • Process Control Automation PLC Quiz
Credits: Tony R. Kuphaldt
Determine Effect of Each Fault for Pneumatic Force-balance System
Determine Calibration Range of Pneumatic Pressure Transmitter
Identify High and Low Ports on Pneumatic DP Transmitter
Simple Pressure Repeater
Programmable Logic Controller (PLC) Questions and Answers – 10
Stilling Well in Interface Level Measurement System
Practical Process Control System Questions & Answers – 7
Example PLC Program
Define Normal Status of a Process Switch ?
Calculate LRV and URV for 4-20 mA Loop-powered DP Transmitter
Electronic Force Balance Pressure Transmitter
Questions on Radar LT Loop Diagram
Which Instrument is Faulty? Transmitter, Recorder, or Controller
Practical Process Control System Questions & Answers – 1
PLC program pushbutton switches
Remote Seal Pressure Transmitter Temperature
Importance of Temperature in Remote Seal Pressure Transmitter
Double Block and Bleed Valves Opening or Closing Sequence
Solenoid Valves Questions
Solenoid Valves Questions & Answers – 3
DP Transmitter Wet Leg Compensating Impulse Line
Questions on DP Transmitter Wet Leg Compensating Impulse Line
PLC program to control pump
Troubleshooting PLC Permissive Inputs
Calculate Hydrostatic Pressure of a vertical column of Acetic Acid
Purpose of Stop in a Pressure Measuring Instrument
Type C Chopper Objective Questions
PLC program to control a water pump
PLC Program to Control a Water Pump
control of level in three cascaded Loops
Multiple Lags (orders)
PLC Program to Control Level of Series Tanks
Series Tanks Level Control using PLC Ladder Programming
Sorting PLC Program Simulation
Sorting & Distribution Line PLC Programming – Advanced Logic
magnetic-level-gauge-principle
Magnetic Level Gauge Working Principle Animation
Reproducibility in Measurement
What is Reproducibility?
Relation Control
Relation Control System
