Reading: Forcing and Modifying PLC Logic
Inst Tools > Blog > PLC Tutorials > Forcing and Modifying PLC Logic
Last updated: March 4, 2021 12:39 pm
7 Min Read
In this article, we will be discussing the function of forcing and modifying in the PLC programming and its effects on the Siemens program logic.
Forcing versus ModifyingForcing in Siemens PLCModifying in Siemens PLC
Forcing and Modifying is the software facility (feature) that works differently in s7- 300 and s7- 400 PLCs.
In the process industries, processes run for long hours 24×7 365 days, in such a situation if any fault occurs then the whole process interrupts or stops depends on the criticality of the fault occurs.
Now let us consider that there is a fault in the pump (say some failure) and unable to run the pump. Due to this fault, PLC won’t allow other processes to run (as depends on pump run feedback), in such condition we can force the feedback of the pump to ON, so PLC understands that there is no fault now and allow other processes to complete the task. (Take all precautions before forcing logics, if we do forcing without cross-checking then it may lead to equipment failure or production loss)
In our example, there is some failure in the pump, so it is not starting. Because of this we are not receiving the pump run feedback. Say, we have a situation that, we want to run the remaining process even though the pump may not run but this remaining process runs only when we receive this pump run feedback. So now we are forcing the pump run feedback, thus making the PLC believe that the pump is running in the field by forcing. In actual condition, the pump is not running.
Siemens PLC Force LED
Now question is that how we get to know that someone has a force input or output? You can see in the above figure of CPU of siemens, it has a LED indication with label “FORCE”. Whenever this LED is ON means inputs or outputs forced in the logic.
Let’s discuss some of the differences between forcing and modifying :
1. For force, there is LED indication is available on CPU whereas there is no such thing available for modifying.
2. To do force, you have to connect PC with PLC, now after forcing any facility, if you disconnect PC from PLC forcing will remain active whereas in modifying if you disconnect PC from PLC we lost all the modifications we have done.
3. While working on forcing, if you lost power all the changes you have done will remain the same but in modifying you lost everything which you have modified.
4. We can only force input, output in s7-300 and s7-400 PLCs and can force memory in s7-400 PLCs but we can’t force timer, counter and data blocks whereas in modifying we can modify everything which is above stated.
— Now let learn where to find forcing facility in siemens PLCs. —
1. In the project tree Go to “watch and force table” and double click on the “force table”.
Force Table in Siemens PLC
2. The following window will popup.
Here let us take our old program of conductivity level switch we are going to force one of the output here.
Force variable in PLC
Here we will use one of the networks of our program.
I am going to force the PUMP. So in the above window, you can see there is an address section where I will put an address of the PUMP.
Siemens Pump Logic
3. As shown in the below window you can see I have to enter the address of the pump.
Now write “TRUE” in the force value table then click on the below shown icon to activate forcing.
Force Icon
One thing to note that we must connect your PC with PLC to make things work. In forcing you only can connect by staying online with actual PLC connected with it, you can’t force it with the simulator.
Now let’s talk about how to use modifying.
In modifying it works like forcing but we all know what difference is between them.
To open modify facility,
1. in the project tree Go to “watch and force table” double click on it and a new icon named “watch table_1” will be generated.
Watch and Force in PLC
2. By clicking on “watch table_1” the following window will popup.
Watch Table Siemens PLC
Let consider the following example of a motor control program as shown in the figure, one of the connections of the stop button gets to loosen up or disconnected. Here STOP button is NC due to that reset button stays active which won’t allow the motor to run.
Now due to a problem, we don’t want to stop the whole process. By connecting PC to PLC we can easily modify it to run till maintenance personnel solve this issue.
Modify PLC Logic Online
3. As you can see in the below window you can modify the value to make it TRUE. If the maintenance process is a bit longer then we have to modify it for “permanent” rather then to select for one scan cycle.
Forcing and Modifying Siemens PLC Programming
4. In “modifying with the trigger” you can set when you want to set your input or output to stay ON and for how much time you want to make it ON.
In modifying we can modify a value in simulator and PLC.
Author: Suhel Patel
  • Ladder Logic Examples
  • PLC, HMI, VFD, and Motor
  • Pulse Generation using Timer
  • Liquid Mixing PLC Logic
  • Two Hand Control Logic
XG5000 PLC Programming for Automatic Exhaust Fan
What is the OPC Server?
STAR DELTA Programming using PLC Controller
Siemens PLC Organization Blocks (OB)
PLC SCADA Engineers Interview Questions and Answers
208kSubscribersSubscribe
Step by Step Guidelines to Download Free Robotics Software
Schneider PLC Example Program for Star-Delta System
How to Control VFD with PLC using Ladder Logic
PLC Programmer Salary and Future Career Scope
Unknown Do’s Need to Know as a PLC Programmer
PLC Program for Water Level Control Logic
PLC Latching Function
Smart Automation Solutions: PLC Logic for Stairway Lighting
Switch NO or NC Contact
Normally-open and Normally-closed Switch Contacts
How to Create Faceplate in FactoryTalk View Studio
How to Create Faceplate in FactoryTalk View Studio?
3 to 8 Line Decoder Circuit Diagram
3 to 8 Line Decoder PLC Ladder Diagram
Case Statement in SCL Language
Check Block Consistency Tools
Check Block Consistency Tools in Simatic Manager
Real-time PLC Projects
Real-time PLC Projects – Industrial Automation
User Defined Function Blocks in PLC
What are User Defined Function Blocks in PLC?
factorytalk view studio hmi
How to Create Templates in FactoryTalk View Studio?
Hot Well Level Control System in Condensing Turbine
X-Ray Spectroscopy Questions & Answers
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 7
Conductive Level Switch Principle
Top 100 LabVIEW Projects for Engineering Students
MCB vs Fuse
MCB vs Fuse Questions and Answers
Variable Air Volume Controller in HVAC
What is Variable Air Volume Controller in HVAC?
Quadrupole Mass Spectrometer
