An oil sump for a hydraulic system is equipped with a float-type level switch for sensing low oil level and providing automatic shut-down capability for the hydraulic system:
Float-type Level Switch
The flow rate of oil through the sump is quite high, and this presents a problem.
With the oil being so turbulent, the float does not rest gently on the oil’s surface.
Instead, it is tossed to and fro on the choppy surface, which can make the level switch “think” the float has gone down further than it actually has, thus causing needless shutdowns.
One solution to this problem is a stilling well. Describe what a “stilling well” is, how you might make one for this application, and why it works to prevent the problem.
Answer
A stilling well is a vertical pipe placed in the process liquid, designed to produce a calm (“still”) liquid surface for a level-sensing instrument to measure.
They are especially useful when sensing the level of a flowing stream of liquid, where anything placed within that flowing stream will be pushed laterally by the force of the moving liquid.
A simple piece of pipe works great as a stilling well.
One must take precautions that the float cannot get “hung up” inside the pipe, but otherwise the selection and installation of the pipe should be rather simple.
Would an ultrasonic level switch be immune to the turbulence? Explain why or why not.
Share your answers & explanation with us through the below comments section.
- Open Tank Level Measure
- Level Transmitter Errors
- Practical Level Sensors
- Sump Tank Level Transmitter
- Guided Wave Radar Level Sensor
Credits: Tony R. Kuphaldt
Yes.ultrasonic level sensor can immune turbulance.
