Reading: Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Inst Tools > Blog > Flow Measurement > Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
In this article, we will learn the procedure of using SOPAS engineering tool of SICK ultrasonic flare flow meter software.
Last updated: November 6, 2021 7:16 pm
Flow Measurement
2 Min Read
In this article, we will learn the procedure of using the SOPAS engineering tool of SICK ultrasonic flare flow meter software.
Procedure for working with Flare Flowmeter with SICK software.
We can use the SOPAS software for configuration, maintenance, and troubleshooting of SICK flow sensors.
Step 1:
Open SOPAS engineering tool (software).
Flow Sick SOPAS engineering tool
Step 2:
Select connect to new device
Step 3:
Select the standard protocol and USB selection.
Flow SICK Software
Step 4:
Then below screen will be opened and press the Next. (It will show the FT tag number )
Select the required flow meter.
Sick Flow meters
Step 5:
Now go to Login
User Level: service,
Password: service
SICK Ultrasonic Gas Flow Meter
Step 6:
On your Left side, New project -> overview measuring point 1 -> Maintenance -> Maintenance mode.
(Click on this, the below window will open, and there click on the check box and click on set maintenance. Then Maintenance mode bubble will become yellow color)
Flow Meter Maintenance Mode
Step7:
To change Measuring from External value to Constant value or vice versa.
(External value means direct transmitter reading & constant means forcing to some value).
So MCU-P -> Measuring point-1 -> Analog input parameter
Flow computer for gas metering with SICK
Step 8:
Once work has finished save it to desktop with some file name and date.
To disconnect it, Go to Maintenance -> Maintenance mode -> remove selection on check box & click on set maintenance than the yellow color bubble will fade out.
SICK Flow Sensors
Step 9:
Then Logout from the device (CTRL+U)
Flare Ultrasonic Mass Flow Meter
Credits: PLQP Instrumentation Team
  • Flow Meter Calibration
  • Averaging Pitot Tube
  • Flow Meter Verification
  • Heat Tracing Problems
  • Flowmeter Rangeability
Interview Questions on Flow Measurement
Working Principle of Flow Switch with Animation
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Microwave Flow Sensor – Working Principle and Applications
Square-root characteristics of Differential Pressure Flow Meters
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
DP type Flow Transmitter Preventive Maintenance and Calibration
Basics of Restriction Orifice (RO) – Types, Applications, Standards
What is a Turbine Flow Meter?
Laminar Flow Meter Working Principle
Coriolis Mass Flow Sensor Theory
Pressure based Flow Meters
Flow Meters Troubleshooting
Turbine Flow Meters Troubleshooting
Flow Switch Working
Flow Switch : What is it? – Applications
Comparison between Transit time and Doppler Flow Meter
Difference between Transit time and Doppler Ultrasonic Flow Meter
Electromagnetic Flow Meters Working Principle
Oscillating Piston Flow Meters Principle Animation
Turbine Flow Meter
All About Turbine Meters
Metal tube Variable Area Flowmeters Principle
Metal Tube Variable Area Flow Meters Principle
Averaging Pitot Tubes
Pitot Tube Problems and Troubleshooting Steps – Flow Instrument
Water Cut Meter
What is Water Cut Meter?
What Effect on Hydrostatic Level Transmitter if Liquid Density Changes?
Function Block Diagram - Studio 5000 Logix Designer
Define the Order of Execution in Functional Block Diagram of Studio 5000
Pressure Reducing and Desuperheating Station (PRDS)
Pressure Reducing and DeSuperheating Station (PRDS)
Overhead Product Pressure Control Loop
Can a PLC Function Without an HMI or SCADA
Can a PLC Function Without an HMI or SCADA?
PLC Examples for calling functions in SCL
Siemens PLC
Five Types of PLC Programming languages
