Reading: How to use FIFO Block in TIA Portal? – Siemens PLC Programming
Inst Tools > Blog > PLC Tutorials > How to use FIFO Block in TIA Portal? – Siemens PLC Programming
In this article, you will learn how to use FIFO block in Siemens TIA portal PLC programming. FIFO stands for First In First Out.
Last updated: September 28, 2022 2:22 pm
Hussien Ghareb
First In First Out (FIFO)
Regarding the Programming Engineers, there is always an idiom stating that “It is not about your code result, it is always about how did you make it.”
First In First Out (FIFO)The Function and Application of FIFO BlockSteps for Configuring FIFO Table in TIA Portal
So, today we are going to enhance our programming skills by learning a new tool that will help us to build a (first input first output) register.
But before we are getting started, we need to know why we need such instruction? and when are we supposed to use it? so clear your mind and stay tuned.
FIFO is a structure used in hardware or software applications when you need to buffer data.
Basically, you can think about a FIFO as a bus queue, the people that arrive first is the one who catches the bus first.
Sometimes your input data and field signals are being done faster than the system outputs that you have to make, so in order to handle such a situation you have to make an instruction that slows down the flow of input data and at the same time you have to store these data safely and by its turn.
Simply that is what a FIFO block can do, it outputs the oldest entry of the “FIFO” table as function value then the number of entries is decremented by one and If there are still entries in the table, these are shifted down.
First of all, you have to understand that this operation needs two instructions.
  • One for loading the FIFO table with the unique sequence “ATT” instruction (Add value to table). Shown in Fig. (1)
  • Another one for unloading the FIFO table “FIFO” instruction. As figured in Fig. (2)
Figure 1
fifo instruction in tia portal
Figure 2
Creating the FIFO register (DB)
By pressing the right click on program blocks you can choose Add new block.
Figure 3
Configuring the FIFO database
Then we have to configure the database as illustrated in the next figure. Fig. (4)
  • The first entry in the table specifies the maximum length of the table.
  • The second entry in the table specifies the number of existing entries.
  • The third entry in the table contains the first word of data.
Configuring of FIFO database
Figure 4
Coding the FIFO block in the Main OB
As we can see in the next figure Fig. (5), the first network is responsible for unloading our FIFO table by activating M0.0 automatically the data in turn will be transmitted to MW2.
And for the second network, we can see that it is responsible for loading the table by activating M1.0 automatically the data in MW4 will take its turn into the FIFO table.
Note: the word (P#DB1.DBX0.0) stands for the start address of your table.
FIFO logic in Siemens PLC
Figure 5
  • Ladder Logic Example
  • WinCC Runtime Advanced
  • Why 24 Volts DC Power Supply?
  • Communication in S7-1200 PLC
  • Factory Acceptance Test of PLC
PLC Program for Password Management using Structured Text
Siemens PLC Tia Portal – OB100 Start-up Organization Block
SCADA Software and their Comparison
Compare Online and Offline PLC Programs
PLC Fault Diagnosis – PLC Training Documents
Things to Take Care of When Designing SCADA System
PLC Light Sequence Control using Bit Shift Registers
PLC based Automatic Bell System for a School
Turbine-Compressor System Architecture
PLC Interlock Logic with First Input Priority
DCS versus PLC Architecture
PLC Data Logging and Transmission
Moving Data between PLCs – Siemens Basics – TSEND TRCV
Light ON OFF Control using PLC
PLC Program to Count and Pack Parts from conveyor
Count and Pack Objects from Conveyor using PLC Ladder Logic
PLC Program to Operate Stamping of Parts
PLC Application for Stamping Operation – Example Programming
CODESYS HMI Interface
Fish Farm Automation
Omron PLC Project: Fish Farm Automation Tutorial
PLC Program for Filling Operation
PLC Program for Continuous Filling Operation
Latching and Unlatching in PLC Programming for Beginners
Machine Tool and Coolant Control PLC Ladder Logic
Machine Tool and Coolant Control: PLC Ladder Logic Design
Various Types of Sensors Used in Water Treatment Plant
Various Types of Sensors used in Water Treatment Plant
Dip Tube Type Level System
Questions on Dip Tube Type Level System
Piping and Instrumentation Diagram
P&ID Guidelines for Separator Vessels
Top 1000 Analytical Instrumentation Questions & Answers
H2 S and Total Sulfur Using Lead Acetate Principle
H2S Measurement Using Lead Acetate Principle
Sensors and Transducers Test
