Reading: What are FIFO and LIFO Sequences in PLC?
Inst Tools > Blog > PLC Tutorials > What are FIFO and LIFO Sequences in PLC?
In this article, we will learn the LIFO and FIFO sequence concepts in PLC programming.
Last updated: May 17, 2023 11:22 am
Sequential logic is of great use in PLC programming. It helps in sorting out things easily. A wide range of applications that use PLC has some or the other sequential logic written in it.
FIFO Sequence in PLCLIFO Sequence in PLC
Two of the most widely used sequences are LIFO and FIFO. You must have heard the names in electronics when used for stacking and sequencing. These types of sequential logic are available in PLC too.
FIFO stands for first in first out. The meaning of this sequence can be understood easily from its name. The thing that comes first will go out first. You input one element; and when you request an element, the first one that is entered will be given to you. This same logic works in PLC programming for the FIFO sequence.
In programming, a logic block is assigned named FIFO. It can store up to 16 words or more, depending on the PLC. It contains three types of inputs – reset, storage, and retrieval.
On a rising edge of the reset input, the sequence is reset and made empty. On a rising edge of the storage input, the word present at the input is stored in the block. The block will memorize the sequence of words received.
On a rising edge of the retrieval input, the word entered first will be given in the destination word configured by the PLC programmer. It has two outputs – empty and full. If the empty bit is true, then it indicates that the storage is empty, and if the full input is true, then it indicates that the storage is full.
LIFO stands for last in first out. The meaning of this sequence can be understood easily from its name. The thing that comes last will go out first. You input one element; and when you request an element, the last one that is entered will be given to you. This same logic works in PLC programming for the LIFO sequence.
In programming, a logic block is assigned named LIFO. It can store up to 16 words or more, depending on the PLC. It contains three types of inputs – reset, storage, and retrieval. On a rising edge of the reset input, the sequence is reset and made empty.
On a rising edge of the retrieval input, the word which entered last will be given in the destination word configured by the programmer. It has two outputs – empty and full. If the empty bit is true, then it indicates that the storage is empty, and if the full input is true, then it indicates that the storage is full.
These sequences are pretty easy to operate. The programmer has to take care that any inputs are not given simultaneously to the storage blocks. The block will then not do any action in this case. Only one input has to be given at a time. It is also to be noted that different PLCs function differently on warm restart or cold restart.
Generally, in a PLC cold restart, for example, the register will be reset and in case of a warm restart, the register will be intact as it is. It depends on manufacturer to manufacturer.
  • Find the Best PLC for Your Project
  • HMI Screens on a Mobile or Tablet
  • Top Automation Vendors in World
  • Tia Portal Interrupt Organization Block
  • Timers in Siemens PLC Programming
PLC Ladder Logic Questions and Answers
#13 PLC Best Practices – Disable Unused Communication Ports
PLC Programming: Sorting and Distribution of Boxes by Height
Produced Tags and Consumed Tags in Studio 5000
PLC Analog Input Card Resolution Effects on Accuracy
PLC System Documentation
Communication Processor Module in Siemens PLC
What is Contextual HMI? – HMI Screens on a Mobile or Tablet
How to Communicate with Excel from RsLinx?
Ethernet IP Commissioning Tool software
How to Configure IP Address in Rockwell PLC?
Multi Way Switches using PLC
Making Multi Way Switches using PLC
PLC Programmer Tools
Field Instruments
#11 PLC Best Practices – Instrument for Plausibility Checks
Current to Voltage Conversion Circuit
How to Convert Current to Voltage using Resistor ?
PLC Program for Analog Input Sampling
PLC Analog Input Sampling Ladder Logic
Do’s and Don'ts in PLC
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
Difference between Compact PLC and Modular PLC
Creating CNC Program
Steps Followed Before Creating CNC Program
ORP-sensor-calibration
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
CNC Programming - Definition, Types, and Tips
CNC Programming – Definition, Types, and Tips
Dissolved Oxygen Analyzers Interview Questions
Dissolved Oxygen Analyzer Interview Questions & Answers
Sox Nox Analyzer
Sox Nox Analyzer
Program to implement T Flip Flop logic
T Flip Flop PLC Ladder Diagram
Solve Pressure Control System Problems
