Reading: What is a Feedback Control System? Types & Advantages
Inst Tools > Blog > Control Systems > What is a Feedback Control System? Types & Advantages
Last updated: December 14, 2022 3:09 pm
Control Systems
Be it instrumentation, electronics, or electrical engineering, a feedback control system plays a very important role. As the name implies, it is a system that controls anything based on feedback. You can also call it a closed-loop control.
What is a Feedback Control System?Types of FeedbackAdvantages of Feedback Control System
Anything which takes feedback into consideration and then controls the output is called a feedback control system. Let us have a look at this post at its detailed working principle.
A feedback control system basically has five components – input (set value), output (process variable), process being controlled, sensing devices, and actuating / control devices. Have a look at the below figure.
Let me explain this with a simple example of an air conditioner.
Consider the following things –
  1. Temperature Setpoint set by the remote controller – Input
  2. Temperature – Output
  3. Temperature sensor – sensing device
  4. AHU – process being controlled
  5. Compressor – control device
Now, relate this to the concept we are trying to explain. You set the temperature at 26 °C. You start the AC. On starting, it is found by the sensor that the current temperature is 32 °C. Based on this feedback, the controller inside will start the compressor. The compressor will try to bring down the temperature.
Simultaneously, the sensor is continuously giving its feedback to the controller. When the current temperature has finally reached its set point, the compressor will turn off. Based on the turning-off condition, two cases can then happen – either the temperature will increase or will continue to decrease.
If the temperature is again found to be increasing, then the compressor will again turn on to bring it down. And, when the temperature is decreasing, then no action will be taken unless the temperature increases again. This is the basic concept of the feedback control system.
It is found that the calculation is mainly dependent on two main factors – required value and current value. The resulting difference between them is called the error. Based on this error, the controller decides how to manipulate the controlling device so that it will try to bring the error to zero after a certain stage. This is what the feedback control system works on. It is a real-time calculation. You have to control one process, but if you know how the process is currently running, then you will be accurately able to handle it.
A very popular example is PID (proportional integrative and derivative). PID controls the process either by digital output or analog output. The example we discussed earlier was a digital output (compressor – on or off). In the analog output, the output is varied proportionally to get more control in the system (like an actuator valve or VFD).
Types of Feedback
  1. Positive feedback: – In this type, the feedback signal is added with the input signal in the controller. It is a very least used type, as it has less control over the error.
  2. Negative feedback: – In this type, the feedback signal is subtracted from the input signal in the controller. It is the most used type, as it has great accuracy and control in the process. The example we discussed earlier was a negative feedback one, which tries to decrease the error by bringing input and output close to each other.
  1. Reduction of non-linear effects, which are most often seen in open-loop systems (without feedback).
  2. Reduction of external noise and disturbance.
  3. Increase in efficiency, accuracy, and quality.
  4. Reduction in instability and process uncertainties.
  5. The transient response can be easily controlled
  6. Improvement in gain and bandwidth.
In this way, we understand the concept of a feedback control system used in many engineering processes.
  • What is Adaptive Control?
  • Download PID Simulator
  • Industrial Automation Levels
  • ICS System Design Factors
  • History of Internet of Things
Ratio Controller Example
Alarm and Trip Systems
What is Feedforward Control ?
Background of Modbus – ASCII and RTU Data Frames
  • David Jordan Sr says:
    December 9, 2022 at 2:47 pm
    Good Stuff!
ON-OFF Controller Principle
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
What is Open Telemetry? – Principles and Benefits
What is the OPC Server?
Control Panels Material Take-Off (MTO) – Engineering Project
Node-RED in PLC Automation
Ratio control
What is Ratio Control ?
Loop Power Indicator Principle
Basics of Loop Powered Devices
Instrument Control Package (ICP)
Package Control and Safety Systems Implementation Methods
What is Static Grounding
What is Static Grounding?
Marshalling Panel
What is Marshalling Cabinet?
System architecture
Types of System Architecture used in Industrial Automation
Ziegler-Nichols closed-loop Formula
Tuning a Temperature Process Control Loop
DP Transmitters Level Measurement Principle
DP Transmitters Level Measurement Principle Video
pid-guidelines-for-pig-receivers
P&ID Guidelines for Pig Receivers
Random Access Memory Objective Questions – Part 1
Averaging Pitot Tubes
Pitot Tube Problems and Troubleshooting Steps – Flow Instrument
Introduction to Fieldbus Function Blocks
Flowmeter Characteristics
Flow Meter Characteristics
Arc Fault Breaker (AFB) Electrical Problem Solved
Industrial Drives Multiple Choice Questions and Answers
