Reading: Failing Weigh Feeders and Mechanical Variable Speed Drives (VSD)
Inst Tools > Blog > Root Cause Analysis (RCA) > Failing Weigh Feeders and Mechanical Variable Speed Drives (VSD)
Root Cause Analysis (RCA): Within few weeks failing weigh feeders mechanical variable speed drives (VSD).
Last updated: October 17, 2023 3:14 pm
S Raghava Chari
8 Min Read
Root Cause Analysis (RCA): Within Few Weeks Failing Weigh Feeders Mechanical Variable Speed Drives (VSD).
Weigh Feeder Salient InformationWeigh Feeder ProblemAuthor SolutionMore on Variable Speed Drive (VSD)VSD Installation, Wiring and TubingHow the VSD eliminates the Pneumatic Speed transmitter besides the MVSD?Weigh Feeders VSD Drives Benefits
Note: This is a real scenario that happened way back in the olden days during pneumatic transmitters times. With the advancement of technologies now we have smart transmitters and advanced VFD drives in industrial plants.
These articles will help you to improve your troubleshooting skills and knowledge.
Weigh Feeders are short conveyor belts. 2.5 kW 1480 RPM 400 V 50 Hz motor drives the conveyor belt at low speeds via a Mechanical Variable-speed Drive (MVSD; fig 1).
A load cell below the belt outputs 3-15 psi pneumatic signals proportional to the kg/m belt loading. Flanged to MVSD casing speed transmitter outputs pneumatic signal proportional the output shaft RPM i.e., the belt speed m/H.
Housed in a nearby box an analog computer outputs (kg/m)*(m/H) = kg/H pneumatic signal.
The panel mounted Weight Recording Controller (WRC; fig 2) controls the feed rate at set point by commanding an actuator that pulls / pushes the MVSD’s a lever to change the weigh feeder belt speed.
The dusty and harsh environs located MVSD and the pneumatic RPM transmitter of many moving and sliding parts rotating at RPMs as high as 2000 failed too often.
Repairing these delicate items was mostly unsatisfactory; hence, both failed repeatedly within weeks. Even the too expensive and long delivery vendor spare parts lives were poor; consequent local substitutions even poorer!
Thus, the 9 Nos. weigh feeder availabilities were 70-80% only and reduced NPK production 10-15%.
Author Solution
A visiting sales person demonstrated Frequency Converter aka electronic variable speed drive abbreviated (VSD), so impressed the author that he instantly recognized it as ‘dream became true’ MVSD replacer and the 3 yearlong problems solver.
Hence, he retained the demonstration model ignoring the sale engineer protests and requested the purchase officer to give him a purchase order and the finance department to pay him immediately.
Figs 1 & 2, the author’s scheme shows how the low cost indigenous highly reliable VSD and another bought out item, the P/I converter replaced  the MVSDs and pneumatic speed transmitters – both imported and pain in the neck very high cost items.
The P/I converter converts the standard 3-15 psi pneumatic instrument signals into standard 4-20 mA instrument current signals.
The VSD, a 1980s debuted solid state electronic device converts the standard 400 V 50 Hz 3 phase power into set e.g. 0 to 80 Hz frequency adjustable 3-phase power proportional to standard 4 to 20 mA control current signal.
Most VSD’s offer constant V/f relationship; this way the motor output shaft torque is constant at all RPMs. However, the VSD output volt saturates to supply volt at frequencies above the supply frequency.
Table 1 below shows a VSD powered 4-pole induction motor RPM for 4 20 mA signals:
VFD Drive Calibration
Table 1
The column with label number 1 shows the 4mA, 8mA, 12mA, 16mA, and 20 mA current signals.
The column with label number 2 shows the frequency in steps of 0Hz, 20Hz, 40Hz, 60Hz, and 80 Hz.
The column with label number 3 shows the voltage in steps of 0 volts, 100 V, 320 V, 400V.
The column with label number 4 shows the motor speed in steps of 0,, 600, 1200, 1800, and 2400 rpm.
Weigh Feeder Drive
Figure 1: Electronic VSD Replaces Mechanical VSD Installation
A mechanical, electrical and instrument crew team fitted a spare flanged motor and GB to a shop made stand (fig 1), coupled them as before, fixed the VSD in the substation, fixed a spare analog computer and P/I converter at instrument panel back and laid the necessary wiring and tubing without plant shutdown (SD).
Figure 2: Electronic VSD Replaces Mechanical VSD – (Wiring & Tubing)
During a fortnightly 4 hour housekeeping SD, the team bolted the stand to the base-plate, terminated the tube and cable connections, completed all necessary tasks according to figs 1 & 2 and switched on the VSD driven weigh feeder successfully.
A week after the first feeder successful run, the author confirmed the order for balance items for other weigh feeders and one spare set. Within a week of their arrival the team commissioned all VSD driven weigh feeders.
The VSD eliminates the Pneumatic Speed transmitter besides the MVSD thus: The motor speed and hence belt speed is proportional to the frequency i.e. to the VSD input signal current, which is proportional to WRC pneumatic output.
The newly bought P/I convertor renders the WRC 3-15 psi signals into proportional 4-20 mA standard instrument current signals, which only the VSD accepts. Hence WRC pneumatic output signal is proportional to belt speed.
Hence, the author got WRC output pneumatic signal T-connected as belt speed signal to the pneumatic analog computer.
The analog computer receives belt load signal as before. Hence it outputs kg/H raw materials’ feed rate to WRC as before.
Thus, the VSD not only eliminates the MVSD but also the speed transmitter – both terrible plant availability reducers!
Weigh Feeders New Drives’ Benefits are:
  1. Gone are the most failure prone MVSD and ST, their associated maintenance efforts, long down-times and poor plant availabilities
  2. Re-locating the field installed pneumatic analog computer and locating the new P/I converter at instrument panel back and the VSD in the substation (fig 2) – both clean areas – eliminate new VSD system likely problems and increase its reliability even more
  3. Thanks to this and many other modifications weigh feeders availabilities touched 100% and the plant produced higher than rated capacities. This is a practical ‘design out maintenance’ example
  4. Weigh feeder drive and other maintenance costs became negligible
  5. The VSD and P/I converters paid for themselves in less than a day! Often replaced MVSDs each cost $ 3000, STs $ 1800 – 80s figures. On the other hand each never replaced VSD costs Rs 25000 and P/I converter Rs 1500 only. Revenue from higher than rated production a handsome bonus!
Author: S. Raghava Chari
  • Servo Motor Drives
  • DC Motor Speed Control
  • Single Loop Controller Questions
  • Interview Questions on Load Cell
  • Advantages of Variable Speed Drives
Cooling Tower Fans Frequently Failing
Welding Machine Fail in Dusty and Corrosive Areas
Butterfly Valve Failure Caused Serious vicinity Heavy Fire
Less than 40% available Plant Air Compressors made available 100% for Operations
Supplied Screen Vibrators Perennial Problems
Multistage Flash Drums Erratic Level Readings
Burst Transformer – Electrical Problem Solved
CO2 Absorber Corroded Wall Thickness & Weld Building
CO2 Stripper Collapsed Internals Revamp
Panel and Field Pneumatic Controller’ Bumpless Transfer Issues
Seal Level Differential Pressure Transmitter Problems
Fasteners and General Corrosion of Electrical Motors
Antifriction Bearings Caused Machine Changeovers Posed Outages
Carbamate Plunger Pump Packing Problems Eliminated
Thermocouples Problem
Fire burnt Ammonia Converter Thermocouples Problem
Erratic Radar Level Gauges
Erratic Radar Level Gauges Delays a Refinery Commissioning
Plunger Pump Drive
Too Low Efficiency Torque Converter Elimination Attempt
Vac Residue Tank Electrical Heating Element
Poor Electrical Heating Element Lives – Problem Solved
Thermocouple Extension Lead Minimizer Circuit
Thermocouple Wires and Extension Lead Issues
Solving Critical Control Valve Hunting
Solving Control Valve Hunting: Instrument Troubleshooting
Root Cause Analysis on Hunting of Control Valves
Magnetic Flow Meter Liner Damaged
Magnetic Flow Meter Liner Damaged and Winding Burnt
Communication Protocols in PLC
Various Communication Protocols in PLC
Which instrument is at fault in this system
Which Instrument is at Fault in this System?
Example of Automated Guided Vehicle with PLC
thermal imaging instrument
Thermal Imaging Temperature Measurement
Single Block and Bleed Valve Manifold
Single Block and Bleed Valve Manifold Operation
Types of Pressure
Types of Pressure – Instrument Questions and Answers
CAN Protocol with the OSI Model
Basics for CAN Bus Protocol – Controller Area Network
