Reading: ElectroMechanical Level Measurement Working Principle
Inst Tools > Blog > Level Measurement > ElectroMechanical Level Measurement Working Principle
Last updated: May 28, 2019 3:35 pm
Level Measurement
3 Comments
2 Min Read
Electromechanical level Measurement Principle
A sensing weight is let down on a measuring tape via a counter wheel. The tensile force of the weight is reduced as it hits the product surface. This is recognized, the direction of rotation of the motor reversed and the tape rewound.
As the sensing weight moves downwards, the revolutions of the wheel are counted using a non-contact method. Every count pulse corresponds to a defined length.
The level is obtained by subtracting this length from the overall length (tank height).
electromechanical-level-measurement-working-principle
Measurement in bulk solids
Old seafarers used a weight on a rope to test the depth to the bottom of the sea. In industrial level measurement, the basic idea of sounding is still utilized in the electromechanical level system.
Where other measurement methods are limited, applications involving bulk solids predominantly use electromechanical level measurements.
Applications:
  • The result of measurement is not affected by environmental factors as sound waves, dust, static electricity, humidity and dielectric etc. Can be widely applied for applications in mining, cement, petrochemical, feeding and power plants.
  • Suitable for different variety of materials as powder, pellet, liquid, and also good for open tanks or sealed tank with no inner pressure inside.
  • Working perfectly with software of material management system, accurately monitoring and managing the level of materials inside the tank.
  • Safe measurement in extremely dusty environments
  • Robust system with high tensile force prevents breakdown due to an immersed weight
Siemens Differential Pressure Transmitter Calculations (Flange Type)
Inductively Coupled Wire Guided Float Detectors
Ultrasonic Level Switch Working Principle
Radiation based Level Sensor Principle
3 Comments
  • Mineshkumar says:
    December 6, 2016 at 6:12 am
    1-What is live zero n dead zero?
    2- And what is the out put of flame detector?
    3- IP -42, IP-62 what is it and where is the use?
    4-what is the use of relay?
    • S Bharadwaj Reddy says:
      December 6, 2016 at 6:20 am
      Hello Minesh, Plz search the website & Forum before posting your queries. I hope all answers available. Also i request you to post your further queries in our ” Forum “. You can find the forum link from the above menu. If you dont get the answers then post your questions in the forum. Thanks
    • Chandan Ojha says:
      March 26, 2023 at 11:35 am
      In Case of 4-20 mA, and 0-20 mA, we calls 4 mA is live Zero, and 0 mA for 0-20 mA is dead zero, but in both case 0-4 mA Instrument will be at 0% Position only.
      For Flp detactor Output will be mV and that mV Conver through amplifiers signal conversion it’s convert to 4-20 mA if the mounted in field for more Automation and electrical information you can visit us on http://www.itsoji.com
Open and Closed Tank Level Calculations
Differential Pressure Level Transmitter Errors
Surface Detector Level Gauges (Plumb-bob)
Conductive Level Switch Principle
Non-Contacting Radar Level Transmitter Working Principle
Why Measure Level
Radar Level Transmitter in Briddle level Measurement
Torque Tube Level Measurement Principle
Ultrasonic Level Measurement Questions and Answers
Radar and Ultrasonic Level Transmitter Problems Troubleshooting
Radar and Ultrasonic Level Transmitter Practical Problems Troubleshooting
RF Admittance Level Transmitter Working Principle
How to Install Ultrasonic Level Transmitters 5
Magnetostrictive instruments
Magnetostrictive Level Measurement
Probe Type Radar Level Transmitter
Contact Type Guided Wave Radar Level Transmitter Working Principle
Paddle Type Level Switch
What is a Level Switch? Types of Level Switches
Stilling wells
Stilling Wells for Level Measurement
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
Fieldbus and Profibus
Difference between Fieldbus and Profibus
Orifice Specifications
RC snubber circuits
How Snubber Circuit works ?
plc-analog-input-card-conversion-formula
Wet Contacts and Dry Contacts in PLC Systems
Difference Between Isolator and Circuit Breaker
bimetallic thermometer working principle
Different Types of Thermometers
