Reading: Electrical Feeder Automation in Smart Grid
Inst Tools > Blog > Electrical Basics > Electrical Feeder Automation in Smart Grid
Electrical feeder automation in smart grid is an important part of electrical engineering substations and switchgear panels.
Last updated: May 24, 2023 1:28 pm
Electrical Basics
Electrical feeders are an important part of electrical engineering panels. Electrical panels come in different categories like control panels, PCC panels, MCC panels, etc. They have a large number of electrical components which help in managing the control of the electric power supply properly.
Electrical FeederElectrical Feeder Automation in Smart Grid
Electrical components have a large number of data in them which can help in gaining information about the electrical flow accurately. This data can be used with industrial automation technologies, to help control, manage, and secure the data.
In this post, we will learn about the various industrial automation technologies used in electrical feeders.
Electrical Feeder
A feeder is an electrical distribution network system, which does the job of supplying power from a main source to various loads requiring electricity.
Electrical power from a main transformer or substation is fed to an electrical bus bar of a feeder panel. This bus bar distributes three phase supply to various small cabinets, requiring power.
The electrical cabinets have control circuits in them which are used to supply power in a controlled manner to various loads like motors, lighting, industrial machinery, PLC control panels, etc. This means, each cabinet housing is connected to a corresponding electrical load, and these loads get power from the bus bar which has supplied mains power to their corresponding cabinets.
In this way, a feeder controls electrical power by first taking the input and then giving the output through various controls.
Let us have a look at some of the automation technologies used in electrical feeders:
  1. Smart RTUs are available in the market which detects overcurrent faults or broken conductors or voltage loss. Basically, electrical faults are dangerous in nature and any delay in detecting it can damage the whole circuit quickly. So, with modern automation tools, various faults by current and voltage can be detected quickly. This reduces outage time because a prolonged outage in the feeder can hamper the electrical loads.
  2. After a fault occurs, it is required to restore the electrical network quickly. So, after an issue occurs, automation in controllers quickly restores the network. This too helps in reducing the outage time to a great extent, as the user quickly gets to use the system.
  3. When the neutral wire is cut out mistakenly or accidentally from the transformer supply, it can damage the electrical circuit quickly. So, there are solutions in the devices to detect neutral cut-outs in the network.
  4. Modular automation solutions allow remote control of the electrical devices, which helps in managing and controlling data, allows software updates of devices easily, reduces maintenance time of the personnel working on it, manages load shedding, and provides proper monitoring of the electrical environment.
  5. The devices come with enhanced cybersecurity features, which help in protecting data securely. Also, the SCADA systems once integrated with these devices, can help in additionally securing the data by co-ordinating with them on networking.
  6. Smart solutions in feeder automation help in load break switch monitoring, volt var optimization, blown fuse detection, thermal transformer monitoring, and LV load flow monitoring.
  7. Mostly, apart from SCADA monitoring and control, the main advantage of automation in it comes from fault detection. Fault detection was discussed earlier too; but it is to be noted that all these devices employ various communication protocols which are compatible with modern PLCs, to help them communicate data easily.
  • List of Electrical Drawings
  • Bus Coupler in Electrical Panel
  • Types of Stepper Motors
  • Electrical Conduit Seal
  • Electric Components Overheating
What is Floating Neutral? – Electrical Engineering Basics
Things to Know When Measuring Voltage
Introduction to Protective Systems
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Difference between Soft Starter and VFD
Partial Discharge in Power Lines and its Detection through Sensors
  • Linos sinkala says:
    June 11, 2023 at 11:00 pm
    Looking forward to hear more from you.and thankyou for the knowledge
What is an Instrument Transformer? – Types, Principle, Advantages
How Do Electrical Shorts and Ground Faults Trip Circuit Breakers?
Difference between Signal Cables and Control Cables
What is a Magnetic Contactor? – Principle, Types, Advantages
What is Megger Test?
What is a Ground Rod?
How do AC Drives Work? – Variable Frequency Drive (VFD)
Types of Tripping Protection in MCCB
Electrical Equipment Selection in Hazardous Area
Safety Tips When Working With Electricity
4-20mA VFD Drive Formula
4-20mA Linear Conversion Calculation for VFD Drive (Formula)
Automatic Motor Forward and Reverse Control using Timer
DOL Starter Testing
DOL Starter – Working, Circuit, Advantages, Disadvantages, Applications
Difference Between Wattmeter and Energy Meter
Burst Transformers Root Cause Analysis
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
Difference between MCB and RCBO
Difference Between MCB and RCBO
Accelerometer Arduino Sensor
What are Micro Electro-Mechanical Systems (MEMS)?
Pressure Regulators vs Pressure Control Valves
Pressure Control Valves vs Pressure Regulators
Voting Logic in Safety Instrumented System (SIS)
Compressor Did Not Trip
RCA – Compressor Did Not Trip on Suction Pressure Low Low
Complementary Split Range Control
What is Complementary Split Range Control (CSRC)?
Captive Power Plant Trip Root Cause Analysis
phototransistor-circuit
Phototransistor Circuit Example
