Reading: DP Transmitter Located 10 feet Beneath the Vessel
Inst Tools > Blog > Practical Questions > DP Transmitter Located 10 feet Beneath the Vessel
Determine the LRV and URV of a DP transmitter located 10 feet beneath the vessel and connected to it with capillary tubing.
Last updated: November 16, 2020 7:34 pm
Practical Questions
3 Min Read
Determine the LRV and URV points for a transmitter measuring water level in this vessel, with the DP transmitter located 10 feet beneath the vessel and connected to it with capillary tubing and a remote seal filled with silicone fill fluid (SG = 0.934).
Be sure to show all your mathematical work so that your instructor will be able to check the conceptual validity of your technique(s).
A good way to check to see if you’re solving the problem correctly is to check that each and every one of your intermediate calculations (i.e. the results you get mid-way during the process to arrive at the final answer) has real physical meaning.
If you truly understand what you are doing, you will be able to identify the correct unit of measurement for every intermediate result and also be able to show where that number applies to the scenario at hand.
More Questions
1. Demonstrate how to estimate numerical answers for this problem without using a calculator.
2. When calculating hydrostatic pressures, there are two common methods: one is to use the formula P = γh and another is to translate inches of vertical liquid height directly into PSI using the known relationship between water and PSI (1 PSI = 27.68 inches of water). Demonstrate both methods applied to this problem.
3. Identify some realistic situations that would justify the use of a remote seal on a pressure transmitter.
4. When using filled impulse lines (un-sealed), it is important to use a fill fluid denser than the fluid inside the process vessel. Is this a requirement when using a remote (sealed) diaphragm?
5. Should the “low” side of the DP transmitter be vented or sealed?
6. What would happen if a technician inserted a pipe plug into the formerly open “L” port of the transmitter, sealing it off from atmospheric pressure? What would happen if the capillary tube developed a leak?
7. Explain why this level transmitter does not require a compensating leg.
Share your answers and explanation with us through the below comments section.
  • Purge Level Transmitter
  • ΔP transmitter Calibration
  • Calculate Specific Gravity
  • Heat Detector Testing
  • Factory Acceptance Test
Credits: Tony R. Kuphaldt
Differential Pressure Measurement across Baghouse
Analytical Control System of Heat Exchanger Questions
PLC connected to Three Pushbutton Switches
Baffle Nozzle Assembly Sensitive Mechanism
A Question on Density Gauge
Pressure Switch Questions
Programmable Logic Controller (PLC) Questions and Answers – 1
Questions on Pneumatic Control Loop
Questions on Dip Tube Type Level System
Find Thermocouple Ouput Voltage
Hydrostatic Pressure of a vertical column of Acetic Acid
LRV and URV of PT for Extreme Limits of Empty and Full
Programmable Logic Controller (PLC) Questions and Answers – 10
Solenoid Valves Questions & Answers – 3
Drum Level differential pressure transmitter
Calculate Differential Pressure Sensed by Level Transmitter
Manometer Measures Differential Pressure
How Manometer Measures Differential Pressure for Different Fluids?
level control system
Practical Process Control System Questions & Answers – 10
Identify which lamp in the following ladder-logic diagram
Identify High Flow Alarm and Low Flow Alarm?
simple motor start-stop circuit
Liquid Level Switch Control Logic
Calculate Total Hydrostatic Pressure at Bottom of Vessel
Calculate voltage across RTD
Resistance Temperature Detector (RTD) Questions – 2
Allen-Bradley MicroLogix 1000 PLC
Questions on Allen-Bradley MicroLogix 1000 PLC
PLC Sizes and Applications
DP Level Measurement Problems
Pitot tube
Pitot Tube Flowmeter Calculations
11 kV, 3.3 kV, and 400 V systems insulation resistance (IR) Problems
Circuit Control Devices Multiple Choice Questions
Circuit Control Devices Multiple Choice Questions & Answers
RTD Calibration
RTD Calibration
Components of Electrical Motor
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
S84 - IEC 61511 Standard for Safety Instrumented Systems
S84 / IEC 61511 Standard for Safety Instrumented Systems
