Reading: Door Lock with Delay PLC Exercise Problems
Inst Tools > Blog > PLC Tutorials > Door Lock with Delay PLC Exercise Problems
Design a control system for automatic door lock with delay using PLC programming and motion sensor.
Last updated: April 22, 2024 1:43 pm
Design a control system for automatic door lock with delay using PLC programming.
Door Lock with DelayPLC Exercise ProblemsInputs & OutputsLogic SolutionProgram ExplainedWhen Sensor gets activated or Sensor detects someone approachingWhen Sensor deactivates or (When sensor does not detect anyone for 5 seconds)
Note: This PLC program was created for the persons for learning the PLC programming with simple problems.
Problem Statement:
We are using one Sensor to control the Door Lock.
The Motion Sensor detects when someone approaching the door should wait for 10 seconds and then open it. If no one is detected for 5 seconds, the door should close.
This video explains the PLC programming for automatic door lock with delay logic.
PLC Programming Exercise - Automated Door with Delay
Inputs & Outputs
Digital Inputs:
Sensor: I0.0
Digital Outputs:
Door Lock: Q0.0
Logic Solution
Program Explained
We have used Normally Open Contact for Sensor (I0.0).
We have used Normally Closed Contact for Memory Bit 1 (M0).
In Rung 0:
  1. Normally Open Contact is used for Sensor  (I0.0) to Turn ON Memory Bit 1 (M0).
  2. Timer type TON is used to delay the turning ON time of Memory Bit 1 (M0) for some time.
  3. Timer type TOF is used to delay the turning OFF time of Memory Bit 1 (M0) for some time.
In Rung 1:
  1. Normally Closed Contact is used for Memory Bit 1 (M0) to Turn ON and OFF the output Door Lock (Q0.0).
When Sensor  (I0.0) gets activated or (Sensor detects someone approaching), the Memory Bit 1 (M0) will turn ON after 10 seconds as Timer Function Block TON is used to delay the turning ON time of Memory Bit 1 (M0). The time is set to 10 seconds. After 10 seconds, Memory Bit 1 (M0) will turn ON.
When Memory Bit (M0) turns ON in Rung0, Normally Closed Contact used for Memory Bit 1 (M0) in Rung1 will be True state and does not allow the signal to pass through it and the output Door Lock (Q0.0) will turn OFF or (Doors will Unlock).
When Sensor (I0.0) deactivates or ( Sensor does not detect anyone approaching), Memory Bit 1 (M0) will turn OFF after 5 seconds as Timer Function Block type TOF is used to delay the turning OFF time of Memory Bit 1 (M0). The time is set to 5 seconds.
After 5 seconds, Memory Bit 1 (M0) will turn OFF. When Memory Bit 1 (M0) turns OFF in Rung0. Normally Closed Contact used for Memory Bit 1 (M0) in Rung1 will be false state and allow the signal to flow through it and the output Door Lock (Q0.0) will turn ON or (Doors will Lock).
After 10 seconds, Memory Bit 1 (M0) will turn ON. When Memory Bit (M0) turns ON in Rung0.
Normally Closed Contact used for Memory Bit 1 (M0) in Rung1 will be True state and does not allow the signal to pass through it and the output Door Lock (Q0.0) will turn OFF or ( Doors will Unlock).
Door Locking Ladder Logic
sensor can be programmed to open the door
Design of PLC Control System for Automatic Door
  • PLC Example Switch Program with Timers
  • Heater and Cooler PLC Exercise Problem
  • Automated Garage Gate PLC Programming
  • Pumping and Draining PLC Ladder Logic
  • Curtain Control PLC Programming Solution
ESG in Industrial PLC Automation Systems
PLC Instruction List for Motor Reverse and Forward Direction
Example PLC Program to Control a Pump based on Level Sensors
PLC Conveyor Ladder Logic Program
PLC Interlock Logic with First Input Priority
Heating and Mixing of Products using PLC Example Tutorial
PLC Scan Time
SCADA System Vulnerabilities
Tia Portal – OB30 Cyclic Interrupt Organization Block
ON and OFF a Group of Outputs by One Push button PLC Logic
Draw a Ladder Logic to control a bulb using push buttons in PLC
Concept of Latching in PLC
FIFO in STL Language in Siemens PLC
How to Code a FIFO Queue in STL Language in Siemens PLC?
How to Use the Shift and Rotate Instructions in PLC
How to Use the Shift and Rotate Instructions in PLC?
Classic Control Circuits
AI AO DI DO Questions
Loss in Weight Liquid PLC System
Dosing Pump PLC Logic
PLC Motor Control Circuit-3
Basics of PLC Programming
Elevated Span and Suppressed Span
DP Level Transmitter Elevation and Suppression Corrections
Electrochemical Methods for Oxygen Analysis Questions & Answers
Difference Between Remote IO and Distributed IO Systems
Wiring in PLC System
Wiring in a PLC Control Panel
Power Electronics Diode Circuits Questions and Answers
Control Valve in Nutshell - Valve Design and Selection Factors
Control Valve in Nutshell – Valve Design and Selection Factors
PLC Program for Automatic Mixing Controlling in a Tank
Electrical Circuit Breaker Quiz
100 Electrical Circuit Breaker Quiz
