  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Difference Between Wifi and Industrial Wireless
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > Difference Between Wifi and Industrial Wireless
In this post, we will understand the use difference between Wi-Fi and industrial wireless used in factory automation.
Last updated: September 28, 2022 4:14 pm
6 Min Read
In this post, we will understand the use difference between Wi-Fi and industrial wireless.
Industrial Wireless and WifiAmount of Data (Data Volume)Battery LifeSecurityReliability and Accuracy
Communication is an important part of industrial automation. There are many protocols and mediums available in an automation device to support large-scale communication. Out of these, there is one type of Ethernet.
Traditionally, it is the best medium of communication available in an automation device, due to its high-speed connectivity and ease of wiring connection.
Industrial Wireless
Now, apart from wired Ethernet medium, one more technology called IIoT (Industrial Internet of Things) has been developed and is used widely nowadays. It is nothing but wireless technology.
The wireless technology used in industrial automation is widely different than the wireless communication used at home or office. We will understand here the differences in both technologies.
Let us understand the terms in which they operate and we can then differentiate.
Home or our day-to-day systems that use Wi-Fi are designed to handle data such as web surfing, video viewing, downloading files, etc. These are a large amount of data and the domestic wireless system is used for controlling such type of data usage.
But, a wireless technology used in industrial systems does not require a large amount of data. They handle a small amount of data.
Consider a simple temperature sensor. The data exchanged from it can simply be its process variable and tag name. This is just an example.
Different manufacturers have different types of parameters set inside the sensor, which can be used for exchanging data. But, typically, it is not as huge as the one that is used for domestic purposes.
This shows a small amount of data transfer is handled in industrial wireless as compared to Wi-Fi system used for domestic purpose.
Battery Life
A domestic wireless handles large amount of data and due to it’s large time consumption, the devices which are used will consume a lot of battery in a short period of time.
Due to this, the devices which work on domestic wireless will require a lot of charging due to a large amount of power consumption.
Now, if you see industrial automation devices, they are involved in a very small amount of data exchange as discussed earlier.
So, they consume less power and in short, the battery life of such devices (sensors or actuators) last longer. This is very big advantage of industrial wireless devices.
Also, as it is implemented in the field, it would not be helpful if you are required to charge the device every now and then. So, a longer battery life helps to use the device in an easy and efficient way.
Security
Domestic wireless systems are more vulnerable to system hacks and attacks, due to unsecured access connections many a times.
Simply, consider like you are sitting in the airport and accessing their Wi-Fi network. A large number of people are using the same network, which is open, and will thus make the data of user more prone to robbery or attacks.
But, in industrial wireless, the security is provided at the highest level and even it is custom coded. The protection layer is much advanced and safe as compared to a domestic wireless system.
Suppose you are using Wi-Fi on your mobile and suddenly a call comes. You were doing something important and all of a sudden, due to incoming call, the work gets interrupted and will take more time than was expected.
Due to low network or connectivity issues, if you are at an important time; it can disrupt the whole process. So, the reliability of this network is low because of such types of problems.
But, in industrial wireless, you cannot operate the system with low accuracy. You are continuously transmitting and receiving data from the device with respect to PLC. The PLC is performing logic based on the data transactions.
So, if communication fails even for a small amount of time, then it can disrupt the logic performance and can also damage the machine if it is critical. It could lead to serious consequences. Industrial wireless is thus designed to communicate in a highly reliable and uninterrupted manner.
These are some of the major differences between domestic wireless and industrial wireless.
  • Network Cabling
  • Digital Outputs in PLC
  • What is Industrial Computer (IPC)?
  • WirelessHART Transmitter With Gateway
  • Interface PLC with SCADA System via OPC UA
What are AI, AO, DI, and DO? – Definition, Examples, Purpose
Programmable Logic Controller Maintenance Check Points
What is a Line Choke or Reactor in a VFD?
PLC SCL Program for Marking Machine
208kSubscribersSubscribe
Recent Comments
Related Articles
Difference Between PLC and RTU
Difference Between PLC and RTU?
PLC Program for Automatic Door Control System
PLC Automatic Door Control System – Programming Example
Siemens Process Mode
Test and Process Modes in Siemens PLC
How to Link SQL With Indusoft Web Studio
How to Use an SQL Server with Indusoft Web Studio?
Siemens PLC Course for Beginners
relay-safety-in-plc
How to Reduce Relay Noise in PLC Systems?
More Articles
Pipe Elbow Sudden Burst
A Pipe Elbow Sudden Burst Fatalities and Wrecked Panel Instrumentation
How to Test a Pressure Switch ?
Single-Phase Half Wave AC-DC Converter Questions
Orifice Construction
How does an Orifice Measures Flow?
Relay Circuit for Hooter with Reset Button
Relay Latching Circuit using Push Button
PLC Demo Software
PLC Trainer Demo Download
Synchronous Machines Power Factor Control Questions
Instrumentation Role during Steam Blowing
