Reading: Difference between Cold Standby and Hot Standby
Inst Tools > Blog > Control Systems > Difference between Cold Standby and Hot Standby
Redundancy in industrial automation systems comes in three types – hot, cold, and warm. Learn the difference between Cold and Hot Standby.
Last updated: March 12, 2023 7:36 am
Control Systems PLC Tutorials
Redundancy is a very important term in industrial automation. If you are working on a very critical process, and if you do not have a backup; then in the event of failure, your system will shut down and totally hamper the process.
What is Cold Standby?What is Hot StandbyDifference between Cold Standby and Hot Standby
If the process is too risky, then it can be life-threatening too. So, it is always necessary to have a backup for critical processes. When the primary system fails, a standby system in the backup will save the system from going down.
Redundancy means a system where a process works in two ways – primary and standby. Redundancy comes in three types – hot, cold, and warm.
In this post, we will learn the difference between hot standby and cold standby.
Suppose you have two PLCs. One PLC is working as a primary one. The same program running in primary PLC is present in standby PLC, but it is not powered on. Also, no communication cables have been connected to it. It can thus be considered as a spare PLC, waiting to come into action when the primary PLC fails.
Now, when the primary PLC fails, the operator will shut down the system, connect the cables to the standby PLC and power it on. The standby PLC will now control the process. This system is called cold standby. The system takes a very long time to get back up again when there is a sudden interruption. So, cold standby systems are useful where the process is non-critical and some downtime can be bearable.
Just you need to have a standby system in place, whenever the primary system fails. Do remember to immediately bring the primary system into a running state once again by either repairing it or replacing it.
Industrial Automation Cold and Hot Standby
Image Courtesy: Siemens
What is Hot Standby
Suppose you have two PLCs. One PLC is working as a primary one. The same program running in primary PLC is present in standby PLC. But, it is powered up and continuously communicating with primary PLC.
Now, when the primary PLC fails, the standby PLC will instantly become primary and take-over the in-charge of the process. It happens in microseconds. This system is called hot standby. It’s a redundant method that runs an identical backup system constantly, bouncing data back super-fast; so in the event of system failure, both sites have identical data and can still deliver optimum quality whilst the primary system recovers.
Once the primary system becomes normal again and when the standby system fails, then the primary will again take-over the in-charge and the cycle repeats itself.
The main differences between hot and cold standby systems are mentioned below.
  • A cold standby system is cheaper than hot standby.
  • A hot standby system is used in critical projects, whereas a cold standby system is used in non-critical projects.
  • Cold standby can be considered as it is taking over the primary system in seconds; but hot standby works in redundancy in microseconds, which is super-fast.
  • A cold standby system requires the presence of operators to bring back the system to normalcy in event of failure; whereas a hot standby system does not require any operator intervention.
  • Cold standby is less reliable than hot standby systems.
In this way, we understand the difference between hot standby and a cold standby system.
  • 1oo2 Safety Logic in PLC
  • Why different PLC Languages?
  • Automation Project Investment
  • Industrial Automation Solution
  • Two Hand Press Control Circuit
Electrical Earthing Calculations
Allen Bradley PLC ControlLogix Hardware
PID Controller Output Types – PID_PWM and PID_Output
Hardwired I/O and Serial I/O – Differences Explained
  • R.JAGAN MOHAN RAO says:
    March 30, 2023 at 10:37 am
    Good information, thank you.
While Do Statement in Structured Text PLC Program
How to Configure IP Address in Rockwell PLC?
Commissioning Documents for Instrumentation Engineers
Parallel Tanks Level Control using PLC Ladder Diagram Tutorial
Interview Questions on PID Controllers
Single-acting Pneumatic Cylinder Operation with Limit Switch
Safety Considerations in PLC System Design
Instrumentation Earthing
car parking example logic
Up Down Counter Instruction in PLC
SCADA and PLC Configuration
Examples of SCADA and PLC Configuration Systems
FF JB Termination
Foundation Fieldbus Installation and Best Practices
DDE Protocol
What is the DDE Protocol?
Liquid Tank Filling and Emptying PLC System
Auto and Manual Liquid Tank System: PLC Program Example
Falling Positive and Falling Negative Instructions in PLC
Positive and Negative Edges using Statement List Language
SCADA in Cloud
Cloud-Based SCADA Projects – Try Free Demo Account
Flow Switch Symbol
Principle of Flow Switch
Types of Wireless Technologies in Industrial Automation
Luft detector
Luft detector Principle
VHDL Projects for Engineering Students
100 VHDL Projects for Engineering Students
Ladder Diagram Example using Memory Bits and Set Coils
Multiplexers Objective Questions – Part 1
Insulation Resistance Test
What is an Insulation Resistance Test? – Types, Applications
Convert Raw Counts to Engineering Units
Raw Counts to Engineering Units : Conversion Formula
