Reading: How to Delete the Siemens CPU Memory?
Inst Tools > Blog > PLC Tutorials > How to Delete the Siemens CPU Memory?
We will learn about a method to delete a Siemens CPU memory in the PLC. To reset the memory first put your CPU into the STOP mode.
Last updated: March 4, 2021 11:20 am
2 Min Read
In this article, we will learn about a method to delete a CPU memory in the PLC.
When you use a selector switch on the CPU of the PLC you must know what it reset within a memory.
When you reset or delete a memory, it only deletes a memory variable values and not whole memory.
Delete Siemens CPU Memory
Now, move your selector switch to “MRES” mode and keep it till the STOP LED starts to blink.
As LED stops to blink, put your CPU into the STOP mode again.
You have successfully reset the memory.
But as you know that it only deletes memory variable values and not whole memory.
To delete the whole memory, do follow the below steps.
Step 1:
Open TIA PORTAL or Simatic Manager. Open Block section.
Step 2:
To delete it hit ctrl + A on your keyboard. Uncheck system data. Click on “delete”.
Step 3:
Hit “yes” to delete.
Siemens Memory Card Delete
Step 4:
The whole memory is deleted now which you can confirm by looking at the block window.
CPU Memory Reset
Author: Suhel Patel
  • Siemens CPU Execution
  • Factory Acceptance Test
  • Run Motors in Sequential
  • Allen Bradley Architecture
  • Save PLC Project to Card
How to Work with Allen Bradley RsLogix Emulator?
Connecting Blocks in Functional Block Diagram – Studio 5000
PLC Ladder Program for Automatic Car Wash using Siemens TIA Portal
How to Install GSD File in Step 7 PLC using Simatic Manager?
Types of Limit Switches – Principle, Advantages, Disadvantages
PLC Program for Food Processing Industry
PLC Digital Signals Wiring Techniques
Siemens PLC Mathematics Instructions
Will PLCs become obsolete?
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
PLC Analog Signals Wiring Techniques
PID with Practical Example
Loss in Weight Liquid PLC System
Dosing Pump PLC Logic
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
Alarm and Trip Documentation
PLC Program using START & STOP Buttons
PLC Program using START and STOP Buttons
Start Stop of one Motor from same Push button PLC program
AI AO DI DO Signals
What are AI, AO, DI, and DO? – Definition, Examples, Purpose
Masked Move Instructions
How to use Masked Move Instruction in PLC
Top 30 Interview Questions on Pressure Measuring Devices
Industrial Instrumentation Quiz
Energy Meter Data in PLC using Modbus Communication
Modbus Communication between PLC and Energy Meter
Radiation based Level Sensor Principle
Relay Internal Parts
Relay Operation, Types, Symbols & Characteristics
Automated Test Bench - Complex PLC Programming Examples
Automated Test Bench – Complex PLC Programming Examples
Safety Instrumented Systems Tutorials
High Reliability of Safety Instrumented Systems
