Reading: DC Motor Connections
Inst Tools > Blog > Electrical Theory > DC Motor Connections
Last updated: July 29, 2018 12:07 pm
Electrical Theory
2 Min Read
There are various types of DC motors found in industry today. Each type contains various characteristics that makes it desirable for certain applications.
The below Figure shows schematic- ally the different methods of connecting the field and armature circuits in a DC motor. The circular symbol represents the armature circuit, and the squares at the side of the circle represent the brush commutator system. The direction of the arrows indicates the direction of the magnetic fields.
Figure 7 : DC Motor Connections
Figure 7a shows an externally-excited DC motor. This type of DC motor is constructed such that the field is not connected to the armature. This type of DC motor is not normally used.
Figure 7b shows a shunt DC motor. The motor is called a “shunt” motor because the field is in parallel, or “shunts” the armature.
Figure 7c shows a series DC motor. The motor field windings for a series motor are in series with the armature.
Figures 7d and 7e show a compounded DC motor. A compounded DC motor is constructed so that it contains both a shunt and a series field.
Figure 7d is called a “cumulatively-compounded” DC motor because the shunt and series fields are aiding one another.
Figure 7e is called a “differentially-compounded” DC motor because the shunt and series field oppose one another.
Power Factor
DC Motor Torque
Series Resistance
Battery Hazards
Rectifiers, Forward Bias and Reverse Bias
Battery Operation : Series and Parallel
Series Short Circuit Faults
Capacitance and Capacitive Reactance
Compound Generators
AC Motor Theory
AC Induction Motor Slip
Batteries Theory
Ohm Meter
Electrical Wiring Terminology
AC Generator Operation
Types of AC Generators
Transformer Efficiency
Losses in AC Generator
Transformer Efficiency and Loses Formula
Split Phase Motor
Single Phase AC Induction Motors
Phase angle
AC Generation Analysis : Effective Values, Phase Angle and Frequency
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
Series - Wound DC Motor
Series-Wound Motor
electrical-drives-questions-answers
Electrical Drives Questions & Answers
Needle Valve Schematic
How Needle Valve Works ?
Ziegler-Nichols Closed Loop Tuning Procedure
Fiber Optic Patch Cord
What is a Fiber Optic Patch Cord? – Types, Explained
3-way solenoid valve Normally Open
What is a 3-way Solenoid Valve ?
Temperature Measurement Questions
Interview Questions on Temperature Measurement
MCQ on Measurement and Instrumentation
Series Circuit
Series Circuit
